    602 Posts 67 Posters 2.3m Views 68 Watching
    • N
      Number_5
      Hello Sam,
      thanks also for the quick response.
      I have changed the address ,but now my mirror shows only a black screen, ;-(
      after correction:
      var config = {
      address: “0.0.0.0”, // Address to listen on, can be:
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipWhitelist: [“”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      before correction :
      var config = {
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      step 7 pm2 flush
      pi@raspberrypi:~/MagicMirror $ pm2 flush
      [PM2] Flushing /home/pi/.pm2/pm2.log
      [PM2] Flushing:
      [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
      [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
      [PM2] Flushing:
      [PM2] /dev/null
      [PM2] /home/pi/.pm2/logs/omx-stream1-error.log
      [PM2] Logs flushed
      step 8 restart MM
      pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] MagicMirror ✓
      │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
      │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 15909 │ 0s │ 2 │ online │ 0% │ 2.4mb │ pi │ disabled │
      │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1189 │ stopped │ 0% │ 0b │ pi │ disabled │
      step 9) check the logs
      pi@raspberrypi:~/MagicMirror $ pm2 logs --lines 200
      [TAILING] Tailing last 200 lines for [all] processes (change the value with --lines option)
      /home/pi/.pm2/pm2.log last 200 lines:
      PM2 | 2020-02-01T21:52:06: PM2 log: Stopping app:MagicMirror id:0
      PM2 | 2020-02-01T21:52:07: PM2 log: pid=15652 msg=failed to kill - retrying in 100ms
      PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
      PM2 | 2020-02-01T21:52:07: PM2 log: pid=15652 msg=process killed
      PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] starting in -fork mode-
      PM2 | 2020-02-01T21:52:07: PM2 log: App [MagicMirror:0] online
      /home/pi/.pm2/logs/MagicMirror-error.log last 200 lines:
      /home/pi/.pm2/logs/omx-stream1-error.log last 200 lines:
      /home/pi/.pm2/logs/MagicMirror-out.log last 200 lines:
      0|MagicMir | [21:52:07.028] [LOG] Shutting down server…
      0|MagicMir | [21:52:07.030] [LOG] Stopping module helper: updatenotification
      0|MagicMir | [21:52:07.031] [LOG] Shutting down MMM-RTSPStream streams that were using undefined
      0|MagicMir | [21:52:07.031] [LOG] Stopping module helper: MMM-PublicTransportHafas
      0|MagicMir | [21:52:07.032] [LOG] Stopping module helper: calendar
      0|MagicMir | [21:52:07.032] [LOG] Stopping module helper: newsfeed
      0|MagicMir |
      0|MagicMir | > magicmirror@2.10.0 start /home/pi/MagicMirror
      0|MagicMir | > ./run-start.sh
      0|MagicMir |
      0|MagicMir | [21:52:12.731] [LOG] Starting MagicMirror: v2.10.0
      0|MagicMir | [21:52:12.739] [LOG] Loading config …
      0|MagicMir | [21:52:12.745] [LOG] Loading module helpers …
      0|MagicMir | [21:52:12.746] [LOG] No helper found for module: alert.
      0|MagicMir | [21:52:12.793] [LOG] Initializing new module helper …
      0|MagicMir | [21:52:12.794] [LOG] Module helper loaded: updatenotification
      0|MagicMir | [21:52:13.749] [LOG] Initializing new module helper …
      0|MagicMir | [21:52:13.749] [LOG] Module helper loaded: MMM-RTSPStream
      0|MagicMir | [21:52:14.002] [LOG] Initializing new module helper …
      0|MagicMir | [21:52:14.003] [LOG] Module helper loaded: MMM-PublicTransportHafas
      0|MagicMir | [21:52:14.003] [LOG] No helper found for module: currentweather.
      0|MagicMir | [21:52:14.004] [LOG] No helper found for module: weatherforecast.
      0|MagicMir | [21:52:14.071] [LOG] Initializing new module helper …
      0|MagicMir | [21:52:14.071] [LOG] Module helper loaded: calendar
      0|MagicMir | [21:52:14.101] [LOG] Initializing new module helper …
      0|MagicMir | [21:52:14.102] [LOG] Module helper loaded: newsfeed
      0|MagicMir | [21:52:14.102] [LOG] All module helpers loaded.
      0|MagicMir | [21:52:14.103] [LOG] Starting server on port 8080 …
      0|MagicMir | [21:52:14.116] [LOG] Server started …
      0|MagicMir | [21:52:14.117] [LOG] Connecting socket for: updatenotification
      0|MagicMir | [21:52:14.118] [LOG] Connecting socket for: MMM-RTSPStream
      0|MagicMir | [21:52:14.119] [LOG] PM2: Stopping all OMXPlayer Streams…
      0|MagicMir | [21:52:14.121] [LOG] Connecting socket for: MMM-PublicTransportHafas
      0|MagicMir | [21:52:14.122] [LOG] Connecting socket for: calendar
      0|MagicMir | [21:52:14.123] [LOG] Starting node helper for: calendar
      0|MagicMir | [21:52:14.123] [LOG] Connecting socket for: newsfeed
      0|MagicMir | [21:52:14.124] [LOG] Starting module: newsfeed
      0|MagicMir | [21:52:14.124] [LOG] Sockets connected & modules started …
      0|MagicMir | [21:52:14.285] [LOG] Launching application.
      0|MagicMir | [21:52:14.407] [LOG] Access denied to IP address: 127.0.0.1
      0|MagicMir | [21:52:14.441] [LOG] PM2: Checking if omx_stream1 is running…
      I changed the address as described above, but in the logfile there is still the same adress.
      Did i change the address in the wrong place?
        sdetweil @Number_5
        @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        No, you didn’t change ipWhitelist to [] as I documented above
        • N
          Number_5
          Hallo Sam,
          sorry i have fixed it now.
          after:
          var config = {
          port: 8080,
          ipWhitelist: [], // Set [] to allow all IP addresses
          After newstart I can see the white frame again. Inside the frame the title “Buck Bunny” and “Aussentür”
          as well as the symbol “play” can be seen. But not the stream.
          step 7 pm2 flush
          pi@raspberrypi:~/MagicMirror/config $ pm2 flush
          [PM2] Flushing:
          [PM2] Flushing:
          [PM2] /dev/null
          [PM2] Logs flushed
          step 8 restart MM
          pi@raspberrypi:~/MagicMirror/config $ pm2 restart MagicMirror
          [PM2] MagicMirror ✓
          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 3001 │ 0s │ 1 │ online │ 0% │ 2.4mb │ pi │ disabled │
          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 57 │ stopped │ 0% │ 0b │ pi │ disabled │
          pi@raspberrypi:~/MagicMirror/config $ pm2 logs --lines 200
          PM2 | 2020-02-02T16:57:52: PM2 log: Stopping app:MagicMirror id:0
          PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
          PM2 | 2020-02-02T16:57:52: PM2 log: pid=2049 msg=process killed
          PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2 | 2020-02-02T16:57:52: PM2 log: App [MagicMirror:0] online
          PM2 | 2020-02-02T16:58:03: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:03: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:09: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:15: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:20: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:26: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:31: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:37: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:43: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:48: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:54: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:58:59: PM2 log: App [omx_stream1:1] online
          PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
          PM2 | 2020-02-02T16:59:05: PM2 log: App [omx_stream1:1] online
          0|MagicMir | [16:58:01.715] [ERROR] TypeError: port or a server must be provided
          0|MagicMir | at new WebSocketServer (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/node_modules/ws/lib/WebSocketServer.js:44:11)
          0|MagicMir | at VideoStream.stream2Socket (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:32:23)
          0|MagicMir | at new VideoStream (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/node-rtsp-stream-es6/src/videoStream.js:27:14)
          0|MagicMir | at Class.startListener (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:74:40)
          0|MagicMir | at streams.forEach (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:524:22)
          0|MagicMir | at Array.forEach ()
          0|MagicMir | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:523:21)
          0|MagicMir | at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
          0|MagicMir | at Socket.emit (events.js:182:13)
          0|MagicMir | at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
          0|MagicMir |
          0|MagicMir |
          0|MagicMir | [16:57:58.071] [LOG] Starting MagicMirror: v2.10.0
          0|MagicMir | [16:57:58.080] [LOG] Loading config …
          0|MagicMir | [16:57:58.086] [LOG] Loading module helpers …
          0|MagicMir | [16:57:58.087] [LOG] No helper found for module: alert.
          0|MagicMir | [16:57:58.134] [LOG] Initializing new module helper …
          0|MagicMir | [16:57:58.135] [LOG] Module helper loaded: updatenotification
          0|MagicMir | [16:57:59.093] [LOG] Initializing new module helper …
          0|MagicMir | [16:57:59.093] [LOG] Module helper loaded: MMM-RTSPStream
          0|MagicMir | [16:57:59.348] [LOG] Initializing new module helper …
          0|MagicMir | [16:57:59.348] [LOG] Module helper loaded: MMM-PublicTransportHafas
          0|MagicMir | [16:57:59.349] [LOG] No helper found for module: currentweather.
          0|MagicMir | [16:57:59.350] [LOG] No helper found for module: weatherforecast.
          0|MagicMir | [16:57:59.417] [LOG] Initializing new module helper …
          0|MagicMir | [16:57:59.417] [LOG] Module helper loaded: calendar
          0|MagicMir | [16:57:59.447] [LOG] Initializing new module helper …
          0|MagicMir | [16:57:59.448] [LOG] Module helper loaded: newsfeed
          0|MagicMir | [16:57:59.448] [LOG] All module helpers loaded.
          0|MagicMir | [16:57:59.449] [LOG] Starting server on port 8080 …
          0|MagicMir | [16:57:59.456] [INFO] You’re using a full whitelist configuration to allow for all IPs
          0|MagicMir | [16:57:59.463] [LOG] Server started …
          0|MagicMir | [16:57:59.464] [LOG] Connecting socket for: updatenotification
          0|MagicMir | [16:57:59.465] [LOG] Connecting socket for: MMM-RTSPStream
          0|MagicMir | [16:57:59.466] [LOG] PM2: Stopping all OMXPlayer Streams…
          0|MagicMir | [16:57:59.468] [LOG] Connecting socket for: MMM-PublicTransportHafas
          0|MagicMir | [16:57:59.469] [LOG] Connecting socket for: calendar
          0|MagicMir | [16:57:59.470] [LOG] Starting node helper for: calendar
          0|MagicMir | [16:57:59.471] [LOG] Connecting socket for: newsfeed
          0|MagicMir | [16:57:59.471] [LOG] Starting module: newsfeed
          0|MagicMir | [16:57:59.472] [LOG] Sockets connected & modules started …
          0|MagicMir | [16:57:59.645] [LOG] Launching application.
          0|MagicMir | [16:57:59.829] [LOG] PM2: Checking if omx_stream1 is running…
          0|MagicMir | [16:58:01.702] [LOG] Transportation fetcher for station with id ‘xxx’ created.
          0|MagicMir | [16:58:01.707] [LOG] Starting WebSocket server on port undefined. Waiting for connections…
          0|MagicMir | [16:58:01.714] [LOG] Whoops! There was an uncaught exception…
          0|MagicMir | [16:58:01.721] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMir | [16:58:01.722] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          0|MagicMir | [16:58:01.744] [LOG] Transportation fetcher for station with id’xxx’ created.
          0|MagicMir | [16:58:01.747] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxxgroup.calendar.google.com/private-xxxc/basic.ics - Interval: 300000
          0|MagicMir | [16:58:01.759] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
          0|MagicMir | [16:58:03.761] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 643,514,1283,874 --live --video_queue 4 --fps 30 --no-osd rtsp://xxx.xxx@xxx.xxx.2.108:80/cam/realmonitor?channel=2&subtype=0
          0|MagicMir | [16:58:03.793] [LOG] Starting PM2 for omx_stream1
          0|MagicMir | [16:58:03.960] [LOG] PM2 started for omx_stream1
          1|omx_stream1 | have a nice day ;)
          PM2 | App [omx_stream1:1] exited with code [1] via signal [SIGINT]
          PM2 | App [omx_stream1:1] starting in -fork mode-
          PM2 | App [omx_stream1:1] online
          What else can I do ?
          Thanks for your help.
          • evroomE
            evroom @Number_5
            If I see it correctly, then you have 2 MMM-RTSPStream modules active in your config and 2 stream1 defined, and therefore are trying to start 2 omx_stream1 processes.
            I would concentrate on 1 config with 1 stream1.
            To see if things works, try it with the BucksBunny config first.
            Then give the other one a try (with the bunny removed).
            I also would give the rtsp stream a go without MM, so standalone.
            Somewhere in this thread there should be a description on how to do this; would need to search my notes for it.
            MagicMirror version: 2.37.0
            • N
              Number_5
              update:
              the test video is now running, thanks. I had left the entry of the IP cam in the config, sorry. Now I see a white frame, unfortunately the camera stream cannot be seen. by clicking on the window you can see the “Play” icon.
              step 7 pm2 flush
              [PM2] Flushing:
              [PM2] Flushing:
              [PM2] /dev/null
              [PM2] Logs flushed
              step 8 restart MM
              [PM2] MagicMirror ✓
              │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 4841 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
              │ 1 │ omx_stream1 │ default │ N/A │ fork │ 4814 │ 3s │ 90 │ online │ 0% │ 2.5mb │ pi │ disabled │
              PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:33:48: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:33:54: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:33:59: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:05: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:11: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:16: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:22: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:27: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:33: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:38: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:44: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:49: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:34:55: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:01: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:06: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:12: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:17: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:20: PM2 log: Stopping app:MagicMirror id:0
              PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:21: PM2 log: pid=2360 msg=process killed
              PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] starting in -fork mode-
              PM2 | 2020-02-02T19:35:21: PM2 log: App [MagicMirror:0] online
              PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:24: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:29: PM2 log: Stopping app:omx_stream1 id:1
              PM2 | 2020-02-02T19:35:29: PM2 log: App [omx_stream1:1] exited with code [0] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:29: PM2 log: pid=4878 msg=process killed
              PM2 | 2020-02-02T19:35:33: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:33: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:39: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:45: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:50: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:35:56: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:36:01: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:36:07: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:36:12: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:36:18: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:36:24: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:36:29: PM2 log: App [omx_stream1:1] online
              PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] exited with code [1] via signal [SIGINT]
              PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] starting in -fork mode-
              PM2 | 2020-02-02T19:36:35: PM2 log: App [omx_stream1:1] online
              0|MagicMir |
              0|MagicMir |
              0|MagicMir | [19:35:27.493] [LOG] Starting MagicMirror: v2.10.0
              0|MagicMir | [19:35:27.503] [LOG] Loading config …
              0|MagicMir | [19:35:27.509] [LOG] Loading module helpers …
              0|MagicMir | [19:35:27.511] [LOG] No helper found for module: alert.
              0|MagicMir | [19:35:27.575] [LOG] Initializing new module helper …
              0|MagicMir | [19:35:27.576] [LOG] Module helper loaded: updatenotification
              0|MagicMir | [19:35:28.715] [LOG] Initializing new module helper …
              0|MagicMir | [19:35:28.716] [LOG] Module helper loaded: MMM-RTSPStream
              0|MagicMir | [19:35:29.021] [LOG] Initializing new module helper …
              0|MagicMir | [19:35:29.022] [LOG] Module helper loaded: MMM-PublicTransportHafas
              0|MagicMir | [19:35:29.023] [LOG] No helper found for module: currentweather.
              0|MagicMir | [19:35:29.023] [LOG] No helper found for module: weatherforecast.
              0|MagicMir | [19:35:29.096] [LOG] Initializing new module helper …
              0|MagicMir | [19:35:29.097] [LOG] Module helper loaded: calendar
              0|MagicMir | [19:35:29.132] [LOG] Initializing new module helper …
              0|MagicMir | [19:35:29.132] [LOG] Module helper loaded: newsfeed
              0|MagicMir | [19:35:29.133] [LOG] All module helpers loaded.
              0|MagicMir | [19:35:29.134] [LOG] Starting server on port 8080 …
              0|MagicMir | [19:35:29.143] [INFO] You’re using a full whitelist configuration to allow for all IPs
              0|MagicMir | [19:35:29.152] [LOG] Server started …
              0|MagicMir | [19:35:29.153] [LOG] Connecting socket for: updatenotification
              0|MagicMir | [19:35:29.155] [LOG] Connecting socket for: MMM-RTSPStream
              0|MagicMir | [19:35:29.156] [LOG] PM2: Stopping all OMXPlayer Streams…
              0|MagicMir | [19:35:29.159] [LOG] Connecting socket for: MMM-PublicTransportHafas
              0|MagicMir | [19:35:29.160] [LOG] Connecting socket for: calendar
              0|MagicMir | [19:35:29.161] [LOG] Starting node helper for: calendar
              0|MagicMir | [19:35:29.162] [LOG] Connecting socket for: newsfeed
              0|MagicMir | [19:35:29.163] [LOG] Starting module: newsfeed
              0|MagicMir | [19:35:29.164] [LOG] Sockets connected & modules started …
              0|MagicMir | [19:35:29.353] [LOG] Launching application.
              0|MagicMir | [19:35:29.596] [LOG] PM2: Checking if omx_stream1 is running…
              0|MagicMir | [19:35:29.597] [LOG] PM2: Stopping omx_stream1…
              0|MagicMir | [19:35:31.438] [LOG] Transportation fetcher for station with id ‘xxx’ created.
              0|MagicMir | [19:35:31.613] [LOG] Transportation fetcher for station with id ‘xxx’ created.
              0|MagicMir | [19:35:31.618] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxgroup.calendar.google.com/private-xxx/basic.ics - Interval: 300000
              0|MagicMir | [19:35:31.639] [LOG] Create new news fetcher for url: https://www.swr.de/~rss/swraktuell/swraktuell-bw-100.xml - Interval: 300000
              0|MagicMir | [19:35:33.506] [LOG] Starting stream stream1 using: omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
              0|MagicMir | [19:35:33.531] [LOG] Starting PM2 for omx_stream1
              0|MagicMir | [19:35:33.676] [LOG] PM2 started for omx_stream1
              Is there still an idea?
              • N
                Number_5 @evroom
                Hello evroom,
                our contribution has overlapped. The stream with BucksBunny works, I deleted it now from the config.
                I would like to follow your suggestion and will look for the description next.
                  sdetweil @Number_5
                  @Number_5
                  Does this work by itself.
                  • N
                    Number_5
                    Hello sdetweil,
                    sorry i am new here. Should i copy this line direkt in config.js ? where exactly?
                    evroomE S 2 Replies Last reply Reply Quote 0
                    • evroomE
                      evroom @Number_5
                      @Number_5
                      Command-line.
                      Better deactivate the module before (this in the config.js):
                      module: "MMM-RTSPStream",
                      disabled: true,
                      etc
                        sdetweil @Number_5
                        @Number_5 that’s the command the module is trying to execute ( from the log)
                        Open a command prompt, cut/paste that and see if it works
                        • N
                          Number_5
                          Hello ,
                          first I deactivated the config module.
                          pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                          -bash: !?1971@192.168.2.108:80/cam/realmonitor?: event not found
                          pi@raspberrypi:~/MagicMirror/config $ pm2 start MagicMirror
                          [PM2] MagicMirror ✓
                          [PM2] Process successfully started
                          │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 30912 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                          │ 1 │ omx_stream1 │ default │ N/A │ fork │ 30880 │ 4s │ 741 │ online │ 0% │ 2.6mb │ pi │ disabled │
                          It does not work, :-(
                          • evroomE
                            evroom @Number_5
                            @Number_5
                            Can you try with quotes (single, double) ?
                            omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0"
                            omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
                            when the command works, but still no video, then add --genlog
                            omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
                            This will creat a log file called omxplayer.log under the directory where you started omxplayer.
                            • N
                              Number_5
                              1. First 1 start magic mirror.
                              2. with 2 qoutes
                              3. with 1 qoute
                              [PM2] MagicMirror ✓
                              │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                              │ 1 │ omx_stream1 │ default │ N/A │ fork │ 8825 │ 2s │ 1000 │ online │ 0% │ 2.5mb │ pi │ disabled │
                              [1]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2
                              pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0”
                              omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0”
                              [2] 9584
                              [3] 9585
                              pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                              have a nice day ;)
                              [2]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2
                              [3] Fertig subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2
                              S evroomE 2 Replies Last reply Reply Quote 0
                                sdetweil @Number_5
                                @Number_5 pm2 stop 0, pm2 stop 1
                                just from the commandline…(ctrl-alt-t) . does a video window open on any of these?
                                • evroomE
                                  evroom @Number_5
                                  @Number_5
                                  Better to stop MM temporarily or disable the module with disabled: true, and a restart of MM.
                                  Also make sure omx_stream1 process is not running.
                                  pm2 status
                                  pm2 stop omx_stream1
                                  pm2 delete omx_stream1
                                  pm2 status
                                  Then do the single quoted command, with logging enabled.
                                  • N
                                    Number_5
                                    Hello ,
                                    1. I started it from the command line
                                    but no windows opens. or I’m doing something wrong.
                                    pi@raspberrypi:~/MagicMirror/config $ --genlog
                                    -bash: --genlog: Kommando nicht gefunden.
                                    pi@raspberrypi:~/MagicMirror/config $ pm2 status
                                    │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 13m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                    │ 1 │ omx_stream1 │ default │ N/A │ fork │ 14967 │ 0s │ 1152 │ online │ 0% │ 2.6mb │ pi │ disabled │
                                    pi@raspberrypi:~/MagicMirror/config $ pm2 stop omx_stream1
                                    [PM2] Applying action stopProcessId on app [omx_stream1](ids: 1)
                                    [PM2] omx_stream1 ✓
                                    │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 14m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                                    │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1156 │ stopped │ 0% │ 0b │ pi │ disabled │
                                    pi@raspberrypi:~/MagicMirror/config $ pm2 delete omx_stream1
                                    [PM2] Applying action deleteProcessId on app [omx_stream1](ids: 1)
                                    [PM2] omx_stream1 ✓
                                    [PM2][WARN] Current process list running is not in sync with saved list. omx_stream1 differs. Type ‘pm2 save’ to synchronize.
                                    pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                                    have a nice day ;)
                                    • evroomE
                                      evroom @Number_5
                                      @Number_5
                                      Could you please post commands and output using the </> tag ?
                                      So, select the command or output and click on the </> symbol.
                                      Does the log say anything useful ?
                                      more omxplayer.log
                                      Pleas do not post the complete log, unless small.
                                      30 lines tops.
                                      head -30 omxplayer.log
                                      • N
                                        Number_5
                                        ok sorry,
                                        in future output and commands in </>
                                        thats the logfile
                                        pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
                                        20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
                                        20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
                                        20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
                                        20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                                        20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
                                        20:14:18 T:1939281594   DEBUG: DBus connection succeeded
                                        20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
                                        20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                        20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
                                        20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
                                        20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
                                        20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                                        20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                                        20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                        20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
                                        evroomE 3 Replies Last reply Reply Quote 0
                                        • evroomE
                                          evroom @Number_5
                                          ok sorry,
                                          Nothing to be sorry for; you are learning as you go :-)
                                          • evroomE
                                            evroom @Number_5
                                            Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
                                            I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
                                            Where you able to open
                                            http://your-mirror-ip:8080/MMM-RTSPStream/config.html
                                            and see the cam there ?
                                            Could try ffmpeg, but there I have to pass.
                                            What camera are we talking about ?
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 30
                                            • 31
                                            • 20 / 31
