    602 Posts 67 Posters 2.4m Views 68 Watching
    • N
      Number_5
      Hello sdetweil,
      sorry i am new here. Should i copy this line direkt in config.js ? where exactly?
      evroomE S 2 Replies Last reply
      • evroomE
        evroom @Number_5
        @Number_5
        Command-line.
        Better deactivate the module before (this in the config.js):
        module: "MMM-RTSPStream",
        disabled: true,
        etc
        MagicMirror version: 2.37.0
          sdetweil @Number_5
          @Number_5 that’s the command the module is trying to execute ( from the log)
          Open a command prompt, cut/paste that and see if it works
          • N
            Number_5
            Hello ,
            first I deactivated the config module.
            pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
            -bash: !?1971@192.168.2.108:80/cam/realmonitor?: event not found
            pi@raspberrypi:~/MagicMirror/config $ pm2 start MagicMirror
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
            [PM2] MagicMirror ✓
            [PM2] Process successfully started
            │ id │ name │ namespace │ version │ mode │ pid │ uptime │ ↺ │ status │ cpu │ mem │ user │ watching │
            │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 30912 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
            │ 1 │ omx_stream1 │ default │ N/A │ fork │ 30880 │ 4s │ 741 │ online │ 0% │ 2.6mb │ pi │ disabled │
            It does not work, :-(
            evroomE 1 Reply Last reply
            • evroomE
              evroom @Number_5
              @Number_5
              Can you try with quotes (single, double) ?
              omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0"
              omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
              when the command works, but still no video, then add --genlog
              omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0'
              This will creat a log file called omxplayer.log under the directory where you started omxplayer.
              • N
                Number_5
                1. First 1 start magic mirror.
                2. with 2 qoutes
                3. with 1 qoute
                [PM2] MagicMirror ✓
                │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 0s │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                │ 1 │ omx_stream1 │ default │ N/A │ fork │ 8825 │ 2s │ 1000 │ online │ 0% │ 2.5mb │ pi │ disabled │
                [1]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2
                pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0”
                omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd “rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2&subtype=0"channel=2&subtype=0”
                [2] 9584
                [3] 9585
                pi@raspberrypi:~/MagicMirror/config $ omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                have a nice day ;)
                [2]+ Angehalten omxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd "rtsp://admin:rolandomxplayer --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2
                [3] Fertig subtype=0’channel=2&subtype=0"channel=2&subtype=0’channel=2
                S evroomE 2 Replies Last reply
                  sdetweil @Number_5
                  @Number_5 pm2 stop 0, pm2 stop 1
                  just from the commandline…(ctrl-alt-t) . does a video window open on any of these?
                  • evroomE
                    evroom @Number_5
                    @Number_5
                    Better to stop MM temporarily or disable the module with disabled: true, and a restart of MM.
                    Also make sure omx_stream1 process is not running.
                    pm2 status
                    pm2 stop omx_stream1
                    pm2 delete omx_stream1
                    pm2 status
                    Then do the single quoted command, with logging enabled.
                    • N
                      Number_5
                      Hello ,
                      1. I started it from the command line
                      but no windows opens. or I’m doing something wrong.
                      pi@raspberrypi:~/MagicMirror/config $ --genlog
                      -bash: --genlog: Kommando nicht gefunden.
                      pi@raspberrypi:~/MagicMirror/config $ pm2 status
                      │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 13m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                      │ 1 │ omx_stream1 │ default │ N/A │ fork │ 14967 │ 0s │ 1152 │ online │ 0% │ 2.6mb │ pi │ disabled │
                      pi@raspberrypi:~/MagicMirror/config $ pm2 stop omx_stream1
                      [PM2] Applying action stopProcessId on app [omx_stream1](ids: 1)
                      [PM2] omx_stream1 ✓
                      │ 0 │ MagicMirror │ default │ 2.10.0 │ fork │ 8843 │ 14m │ 2 │ online │ 0% │ 2.5mb │ pi │ disabled │
                      │ 1 │ omx_stream1 │ default │ N/A │ fork │ 0 │ 0 │ 1156 │ stopped │ 0% │ 0b │ pi │ disabled │
                      pi@raspberrypi:~/MagicMirror/config $ pm2 delete omx_stream1
                      [PM2] Applying action deleteProcessId on app [omx_stream1](ids: 1)
                      [PM2] omx_stream1 ✓
                      [PM2][WARN] Current process list running is not in sync with saved list. omx_stream1 differs. Type ‘pm2 save’ to synchronize.
                      pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd ‘rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0’
                      have a nice day ;)
                      • evroomE
                        evroom @Number_5
                        @Number_5
                        Could you please post commands and output using the </> tag ?
                        So, select the command or output and click on the </> symbol.
                        Does the log say anything useful ?
                        more omxplayer.log
                        Pleas do not post the complete log, unless small.
                        30 lines tops.
                        head -30 omxplayer.log
                        • N
                          Number_5
                          ok sorry,
                          in future output and commands in </>
                          thats the logfile
                          pi@raspberrypi:~/MagicMirror/config $ more omxplayer.log
                          20:14:18 T:1939277143   DEBUG: DllBcm: Using omx system library
                          20:14:18 T:1939278613   DEBUG: DllOMX: Using omx system library
                          20:14:18 T:1939279243   DEBUG: DllAvFormat: Using libavformat system library
                          20:14:18 T:1939280418 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                          20:14:18 T:1939280521 WARNING: DBus connection failed, trying alternate
                          20:14:18 T:1939281594   DEBUG: DBus connection succeeded
                          20:14:18 T:1939282354   DEBUG: Keyboard: DBus connection succeeded
                          20:14:18 T:1939282502   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                          20:14:18 T:1939282604   DEBUG: DllAvUtilBase: Using libavutil system library
                          20:14:18 T:1939282636   DEBUG: DllAvCodec: Using libavcodec system library
                          20:14:18 T:1939282654   DEBUG: DllAvFormat: Using libavformat system library
                          20:14:18 T:1939282994   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                          20:14:18 T:1939283372   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:80/cam/realmonitor?channel=2&subtype=0
                          20:14:18 T:1939283465   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                          20:14:18 T:1939283726   DEBUG: OMXThread::StopThread - Thread stopped
                          evroomE 3 Replies Last reply
                          • evroomE
                            evroom @Number_5
                            @Number_5 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                            ok sorry,
                            Nothing to be sorry for; you are learning as you go :-)
                            • evroomE
                              evroom @Number_5
                              Okay, without getting rid of this error, omxplayer and therefore MMM-RTSPStream using omxplayer will not work for you.
                              I have an Axis cam and there it did not work because to the resolution I used, had to use one of the resolutions that is supported by the cam.
                              Where you able to open
                              http://your-mirror-ip:8080/MMM-RTSPStream/config.html
                              and see the cam there ?
                              Could try ffmpeg, but there I have to pass.
                              What camera are we talking about ?
                              • evroomE
                                evroom @Number_5
                                @Number_5
                                Can you try with another port number (554 iso 80) ?
                                omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                N 1 Reply Last reply
                                • N
                                  Number_5
                                  Hello
                                  it is a,
                                  DAHUA mini-dome Kamera hd-cvi 2 megapixels für indoor/outdoor g ip7. 30 m nightview fixe objektiv 2,8 mm. - AC/DC-Adapter : AC/DC-Adapter 12V 600mA (port 80)
                                  also i have a Luna Hd
                                  L-KA-2601 1 160,00 160,00
                                  IR Bullet-Kamera (HD-CVI), Full HD,
                                  if i open
                                  http://XXX.xxx,x.xxx:8080/MMM-RTSPStream/config.html
                                  I am denied access
                                    sdetweil @Number_5
                                    I am denied access
                                    probably have to use the url syntax for userid and password
                                    http://admin:roland!?1971@example.com
                                    that is going to the magic mirror port
                                    so, in the config.js do you have
                                    address: “0.0.0.0”,
                                    and
                                    ipWHiltelist:[],
                                    • evroomE
                                      evroom @Number_5
                                      @Number_5
                                      Try with port 554, see previous post.
                                      And see
                                      https://github.com/shbatm/MMM-RTSPStream
                                      “Using the module” on the config.html part I was referring to.
                                      The IP there, is the MM IP, or localhost, not your cam IP.
                                      • evroomE
                                        evroom @evroom
                                        See
                                        https://forum.magicmirror.builders/topic/2743/mmm-rtspstream-video-streaming-from-live-feeds-security-cameras/379
                                        • N
                                          Number_5
                                          Hello
                                          I’m just overwhelmed with the syntax.
                                          and
                                          I’ll try tomorrow and give feedback, thanks for your support
                                          • N
                                            Number_5 @evroom
                                            @evroom
                                            thats the result with the port 554
                                            pi@raspberrypi:~/MagicMirror/config $ omxplayer --genlog --avdict rtsp_transport:tcp --win 786,424,1138,666 --live --video_queue 4 --fps 30 --no-osd 'rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0'
                                            have a nice day ;)
                                            pi@raspberrypi:~/MagicMirror/config $ head -30 omxplayer.log
                                            21:33:25 T:18446744071806154291   DEBUG: DllBcm: Using omx system library
                                            21:33:25 T:18446744071806155602   DEBUG: DllOMX: Using omx system library
                                            21:33:25 T:18446744071806156277   DEBUG: DllAvFormat: Using libavformat system library
                                            21:33:25 T:18446744071806157458 WARNING: Failed to acquire D-Bus name 'org.mpris.MediaPlayer2.omxplayer'
                                            21:33:25 T:18446744071806157567 WARNING: DBus connection failed, trying alternate
                                            21:33:25 T:18446744071806158687   DEBUG: DBus connection succeeded
                                            21:33:25 T:18446744071806159455   DEBUG: Keyboard: DBus connection succeeded
                                            21:33:25 T:18446744071806159602   DEBUG: OMXThread::Create - Thread with id -1387290944 started
                                            21:33:25 T:18446744071806159705   DEBUG: DllAvUtilBase: Using libavutil system library
                                            21:33:25 T:18446744071806159738   DEBUG: DllAvCodec: Using libavcodec system library
                                            21:33:25 T:18446744071806159756   DEBUG: DllAvFormat: Using libavformat system library
                                            21:33:25 T:18446744071806160118   DEBUG: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                            21:33:25 T:18446744071806160518   ERROR: COMXPlayer::OpenFile - avformat_open_input rtsp://admin:roland!?1971@192.168.2.108:554/cam/realmonitor?channel=2&subtype=0
                                            21:33:25 T:18446744071806179771   DEBUG: OMXThread::Run - Exited thread with  id -1387290944
                                            21:33:25 T:18446744071806180025   DEBUG: OMXThread::StopThread - Thread stopped
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 30
                                            • 31
                                            • 21 / 31
