    Can not add more than ONE calendar??
    5 Posts 3 Posters 1.7k Views 3 Watching
    • I Offline
      ironman_DK
      I have tries almost everything, looked at youtube and others here in the forum, but I can not find the answer, how do I put some callendars in my MM ? how do I add one or two calendars more ?:
      			header: "Kalender",
      						symbol: "calendar-check",
      						url: "https://calendar.google.com/calendar/ical/XXXXXXXXXXXX/private-XXXXXXXXXXXXXXXXX/basic.ics"					}
        sdetweil @ironman_DK
        @ironman_DK it would be
             config : {
                  calendars:[
                           Cal 1 info
                           Cal 2 info
        • MeidlmarkusM Offline
          Meidlmarkus
          @ironman_DK , I had the same challenge. I would like to add to add another possible solution to @sdetweil 's :
          By just creating additional instances of the calendar module, you can even give each its own header, which I find adds to clarity. You may want to look at my configuration which I posted here (unfortunately still a prototype, still waiting for the glass to arrive ;-) )
          https://forum.magicmirror.builders/topic/12104/glass-on-the-way-but-still-eager-to-share-my-first-try
          So here’s how I configured it:
          			header: "Familie",
          				maximumEntries: "5",
          						symbol: "calendar-check-o ",
          						url: "https://calendar.google.com/calendar/ical/XXXXXXXXXXXXXXXX/basic.ics"
                                  header: "Markus",
                                                          url: "https://calendar.google.com/calendar/ical/markusXXXXXXXXXXXXX.ics"
          Hope it helps
          • I Offline
            ironman_DK @sdetweil
            @sdetweil It is not possible to do that, It will fail when I do this are you sure this is the right code ?
              @ironman_DK here is my calendar setup, with dual calendars…
              			disabled:false,
              				//maximumEntries: 100,
              				tableClass:"foo",
              				fetchInterval: 10*60*1000,
              						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
              						url: "https://calendar.google.com/calendar/ical/...basic.ics"
