    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 156.3k Views 25 Watching
      Bangee Module Developer
      @bibi did you try it with the instructions from paviro:
      https://github.com/paviro/MMM-PIR-Sensor
      I don’t think that this warn is your problem. I have so many times these warnings :-D
      You sould send us whats in your pm2 logs mm
      B 2 Replies Last reply
        bibi @Bangee
        @Bangee yes i follow his and yours… quite the same… regarding this npm warning I do nothing then as understood?
        I will send you the log later when I’m home
        Thx bangee! Appreciated!
          bibi @Bangee
          @Bangee so as expected the pm2 log mm just show that the file has syntax error… here is my config file, i put the module at the end…
          thx again :)
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @bibi
            @bibi powerSaving: true
            B 1 Reply Last reply
              bibi @strawberry 3.141
              @strawberry-3.141 right was a typo but still the config file is “not created” :((
              • strawberry 3.141S
                @bibi can you post your whole config file?
                  @strawberry-3.141 here you go and many thx in advance - i struggling with this now (sorry i don’t know why only few parts of the code is with the color background)
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                          port: 8080,
                          language: 'en',
                          timeFormat: 24,
                          units: 'metric',
                                          module: 'alert',
                                          module: 'clock',
                                          position: 'top_left'
                                          module: 'calendar',
                                          header: 'US Holidays',
                                          position: 'top_left',
        symbol: 'calendar-check-o ',
                                          module: 'compliments',
                                          position: 'lower_third'
                                          module: 'currentweather',
                                          header: 'xxx',
                                          position: 'top_right',
                                                  locationID: 'xxx',  //ID from http://www.openweathermap.org
                                                  appid: 'xxx'
                                          module: 'newsfeed',
                                          position: 'bottom_bar',
                                                  feeds: [
        title: "New York Times",
                                                  showSourceTitle: true,
                                                  showPublishDate: true
                                          module: 'MMM-PIR-Sensor',
                                                  sensorPIN: 22,
                                                  powerSaving: true
                  • Y
                    yawns Moderator
                    Everything with at least one tab indent is treated as code and highlighted. ;)
                      bibi @yawns
                      @yawns thx! :))
                      • strawberry 3.141S
                        @bibi you forgot to close the config section in the newsfeed module, add } after showPublishDate: true and you should be fine
                          @strawberry-3.141 yeah! thx a lot. at least i can see this white screen now :p :))) have to figure out how to solve this… Only if it’s realllllly really obvious for you/someone, i post my log file. (sorry to ask so much) otherwise not prob, i will reinstall the PIR module…
                          [TAILING] Tailing last 10 lines for [mm] process (change the value with --lines option)
                          /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                          0|mm       |     at Error (native)
                          0|mm       |     at process.module.(anonymous function) [as dlopen]     (ELECTRON_ASAR.js:168:20)
                          0|mm       |     at Object.Module._extensions..node (module.js:583:18)
                          0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:168:20)
                          0|mm       |     at Module.load (module.js:473:32)
                          0|mm       |     at tryModuleLoad (module.js:432:12)
                          0|mm       |     at Function.Module._load (module.js:424:3)
                          0|mm       |     at Module.require (module.js:483:17)
                          0|mm       |     at require (internal/module.js:20:19)
                          0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                           /home/pi/.pm2/logs/mm-out-0.log last 10 lines:
                           0|mm       | No helper found for module: clock.
                           0|mm       | Initializing new module helper ...
                           0|mm       | No helper found for module: compliments.
                           0|mm       | No helper found for module: currentweather.
                           0|mm       | No helper found for module: weatherforecast.
                           0|mm       | Whoops! There was an uncaught exception...
                           0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                           0|mm       | If you think this really is an issue, please open an issue on GitHub:    https://github.com/MichMich/MagicMirror/issues
                           0|mm       | Launching application.
                            bibi
                            Ok the problem it’s solved! except the screen is turning on and off in a very strange way… have to figure out why.
                            For those you would get the same issue as me, what i did after fixing my config file was:
                            1. sudo apt-get update & upgrade & reboot,
                            2. go in MMM-PIR-Sensor folder in modules folder and run npm install there
                              3.sudo reboot
                              cheers
                              Medo
                              Also had the “white screen” problem. I installed a complete new Raspian (with PIXEL), a new MagicMirror - including node.js in version 7.3.0
                              As soon as i tried to get the MMM-Pir-Sensor working, it failed (with an white screen). Heres, how i solved my problem.
                              At first: Theres no need to downgrade the node (i tried this too, and had no luck)
                              I figured out, that my problem was an MMM-PIR-Sensor installation error i did not recognized at the beginning. When i tried “npm install” i got something like this (an error):
                              "gyp WARN EACCES user “root” does not have permission to access the dev dir “/root/.node-gyp/5.12.0”
                              I figured out, that there are two ways of solving this:
                              1. CHOWN the directory the install procedure tries to install
                              2. use “npm install --unsafe-perm”
                              Im aware that option two is not the “elegant” way, but it solved my problem (and i did not have to change directory permissions).
                              I removed all files and git the files again (like described some lines above from banglee) and then just use “npm install --unsafe-perm”
                              The “–unsafe-perm” option was the key to my problem…
                              Z 1 Reply Last reply
                              • Z
                                zichao92 @Medo
                                Hi @Medo ,
                                I have gotten the white screen problem as well and my raspberry pi configuration is similar to yours ( running on PIXEL with the latest nodejs).
                                However, upon using option 2 from your solution. I have obtained this error :
                                npm ERR! Linux 4.4.38-v7+
                                npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--unsafe-perm"
                                npm ERR! node v7.3.0
                                npm ERR! npm  v3.10.10
                                npm ERR! code ELIFECYCLE
                                npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e        ../../node_modules/electron-prebuilt`
                                npm ERR! Exit status 255
                                npm ERR!
                                npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script '        electron-rebuild -e ../../node_modules/electron-prebuilt'.
                                npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-P        IR-Sensor package,
                                npm ERR! not with npm itself.
                                npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
                                npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
                                npm ERR! Or if that isn't available, you can get their info via:
                                npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
                                npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                                Does anyone have solution to this?
                                M 1 Reply Last reply
                                  Medo @zichao92
                                  @zichao92
                                  First things that come to my mind:
                                  • maybe a “sudo” is missing? Like sudo npm install --unsafe-perm?
                                  • are you executing this from the MMM-PIR-Sensor directory ?
                                  Z C 2 Replies Last reply
                                  • Z
                                    zichao92 @Medo
                                    Hi @Medo, Thanks for the reply.
                                    1.) I tried this method and it gives an output of the following error.
                                    pi@raspi:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm install --unsafe-perm
                                    npm WARN prefer global npm@3.10.10 should be installed with -g
                                    > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                                    > node-gyp rebuild
                                    make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                                      CXX(target) Release/obj.target/epoll/src/epoll.o
                                      SOLINK_MODULE(target) Release/obj.target/epoll.node
                                      COPY Release/epoll.node
                                    make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
                                    > nslog@3.0.0 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/nslog
                                    > node-gyp rebuild
                                    make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/nslog/build'
                                      CXX(target) Release/obj.target/nslog/src/main.o
                                      CXX(target) Release/obj.target/nslog/src/nslog_linux.o
                                      SOLINK_MODULE(target) Release/obj.target/nslog.node
                                      COPY Release/nslog.node
                                    make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/nslog/build'
                                    > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
                                    Unable to find electron-prebuilt's version number, either install it or specify an explicit version
                                    npm ERR!
                                    npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
                                    npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
                                    1. Yea it’s in the file directory ( MagicMirror/modules/MMM-PIR_Sensor )
                                      Medo @zichao92
                                      @zichao92
                                      What i also did, was a complete reinstall of the PIR-Sensor
                                      I followed the steps, “Banglee” described some lines above:
                                      ok so lets go step by step:
                                      cd ~/MagicMirror/modules/
                                      now we will remove the PIR folder:
                                      rm -rf MMM-PIR-Sensor
                                      and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
                                      git clone https://github.com/paviro/MMM-PIR-Sensor.git
                                      cd MMM-PIR-Sensor
                                      run the following cmd here:
                                      npm install and wait, this can take a few minutes.
                                      Now you’ll have to add pi to gpio
                                      sudo useradd -g pi gpio
                                      and reboot your Raspi:
                                      sudo reboot
                                      Sorry, no further ideas so far (maybe you can open a PIR-Sensor troubleshooting thread)?
                                      • Z
                                        zichao92 @Medo
                                        Hi @Medo ,
                                        I managed to get it working in an ugly way. Doesnt matter, it works. Thanks for your help!
                                          jwhittaker
                                          I’m having nothing but trouble with this. I’ve tried all the tips on here but still get a white screen.
                                          @zichao92 What was the ugly way and how did you manage to get it working please?
                                          This is the error I get:
                                          > electron js/electron.js
                                          >Starting MagicMirror: v2.1.0
                                          Loading config ...
                                          Loading module helpers ...
                                          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Could not locate the bindings file. Tried:
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node
                                           → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node
                                          App threw an error during load
                                              at bindings (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/bindings/bindings.js:88:9)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:116)
                                              at Module._compile (module.js:556:32)
                                              at Object.Module._extensions..js (module.js:565:10)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/onoff/onoff.js:4:11)
                                          { Error: Could not locate the bindings file. Tried:
                                            tries:
                                             [ '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node',
                                               '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node' ] }
                                          Launching application.```
                                          • Z
                                            zichao92 @jwhittaker
                                            Hi @jwhittaker ,
                                            Previously i had a working node_modules that Ive installed through npm install ( Cant rmb how i got it but i managed to create a back up copy of it). Subsequently when I tried to use npm install on a new raspberry pi, it didnt work as intended.
                                            What i did was instead of using npm install, I bypassed it by inserting the node_module that i previously salvaged and it worked for some reasons.
                                            • 3 / 5
