    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 109.4k Views 25 Watching
      A Former User
      Hi, I wrote audio script with play plughw. If don’t work try manually to find your configuration
      • K
        Kevinho195
        Hi @Sean
        I just updated from 3.0 to the latest version. I did git pull and npm install and did create the token.json again and store it as decribed in your manual. Version 3.0 did work great, but now I get this error: What am I doing wrong?
        0|MagicMirror  | [21:35:32.002] [LOG]
        0|MagicMirror  | Starting MagicMirror: v2.10.0
        0|MagicMirror  | [21:35:32.032] [LOG]
        0|MagicMirror  | Loading config ...
        0|MagicMirror  | [21:35:32.071] [LOG]
        0|MagicMirror  | Loading module helpers ...
        0|MagicMirror  | [21:35:32.078] [LOG]
        0|MagicMirror  | No helper found for module: MMM-pages.
        0|MagicMirror  | [21:35:36.901] [ERROR]
        0|MagicMirror  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'play-sound'
        0|MagicMirror  | [21:35:36.903] [LOG]    Loading module helpers ...
        0|MagicMirror  | [21:35:36.906] [LOG]    No helper found for module: MMM-pages.
        0|MagicMirror  | [21:35:36.913] [ERROR]  App threw an error during load
        0|MagicMirror  | [21:35:36.919] [ERROR]  Error: Cannot find module 'play-sound'
        0|MagicMirror  |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
        0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
        0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
        0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:658:17)
        0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:20:18)
        0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:12:19)
        0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:201:3)
        0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:711:30)
        0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
        0|MagicMirror  | [21:35:36.939] [LOG]
        0|MagicMirror  | Whoops! There was an uncaught exception...
        0|MagicMirror  | [21:35:36.941] [ERROR]
        0|MagicMirror  | { Error: Cannot find module 'play-sound'
        0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) code: 'MODULE_NOT_FOUND' }
        0|MagicMirror  | [21:35:36.975] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|MagicMirror  | [21:35:36.977] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|MagicMirror  | Fontconfig error: "/home/pi/.config/fontconfig/fonts.conf", line 10: junk after document element
        0|MagicMirror  | [21:35:37.852] [LOG]
        0|MagicMirror  | Launching application.
          A Former User
          Try this :
          cd ~/MagicMirror/modules/MMM-AssistantMk2
          ./update
          I think package. Json and package-lock. Json are outdated. I wrote a script for this ;)
          K 1 Reply Last reply
          • K
            Kevinho195 @Guest
            @Bugsounet thanks for your help :)
              A Former User
              We have updated AMk2 to v3.1.0-2
              Changes:
              • Standby icon Touch to activate assistant
              • AMk2 is now prepared to receive addons
              Note: I prepare sample and template addons.
              Coming soon ;)
              Just a little patience and I will come back to you for the addons
              EDIT
              Addons repository is now online
              • N
                nakedrabbit
                New version installed fine for me, though I did not git pull, just wiped the old one off. Installer worked great, and I no longer have to rebuild electron afterwards, as I did previously. Everything worked great.
                HOWEVER
                I still can’t get much action out of the plugin. Here’s my latest error dump:
                [AMK2] MMM-AssistantMk2 Version: 3.1.0-3
                0|mm | [AMK2] AssistantMk2 is initialized.
                0|mm | [HOTWORD] begins.
                0|mm | [HOTWORD] Detector starts listening.
                0|mm | [HOTWORD] Detected: SMARTMIRROR
                0|mm | [HOTWORD] After Recording: 4000
                0|mm | [HOTWORD] stops.
                0|mm | [HOTWORD] After Recording finised. size: 16050
                0|mm | [HOTWORD:B2W] WAV_FILE_CREATED: /home/pi/MagicMirror/modules/MMM-Hotword/temp/afterRecording.wav 16050
                0|mm | [HOTWORD] Final Result: { detected: true,
                0|mm | hotword: ‘SMARTMIRROR’,
                0|mm | file: ‘temp/afterRecording.wav’ }
                Seems to indicate Hotword is the problem…?
                Here are the last 15 errors:
                0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js:235:3)
                0|mm | at Module._compile (internal/modules/cjs/loader.js:711:30)
                0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                0|mm | { Error: Cannot find module ‘google-assistant’
                0|mm | at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                0|mm | at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                0|mm | at Module.require (internal/modules/cjs/loader.js:658:17)
                0|mm | at require (internal/modules/cjs/helpers.js:20:18)
                0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js:1:180)
                0|mm | at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
                Triggered the module with MMM-Buttons, but when I do that, AssistantMk2 just waits and doesn’t listen, finally timing out.
                  A Former User
                  hi, google-assistant module is not installed.
                  try this:
                  npm install
                  and execute electron rebuild :)
                  • N
                    nakedrabbit
                    Yes, that seems obvious, but I did, in fact, follow the installation instructions, so I’m not sure why I have this error message either… left over from an aborted earlier attempt?
                    In addition I took out Hotword and used your fine snowboy addon. Exactly the same effect, so I must have something wrong with my general setup… still testing…
                    Thanks for your patience!
                      A Former User
                      @nakedrabbit : oupss, i have not seen your post :(
                      maybe your problem is now solved…
                        A Former User
                        MMM-AssisantMk2 v3.1.1-1
                        3.1.1-1 (05/03/2020)
                        • BUG: correct audio cutting response for mpg321 (test)
                        • ADD: add cvlc audio out support (vlc using)
                        3.1.1-0 (02/03/2020)
                        • ADD: add new function for addons-recipe (socketExec, onSocketExec)
                        • BUG: continous conversation bug - infinite loop on no user response
                        • BUG: double chimed on TRANSCRIPTION_FAILS retry
                        • ADD: ability to set no chime on activate assistant
                        • ADD: touching the keyword “try to say” activates the assistant for the suggested search (Fullscreen and Classic2 ui)
                        • ADD: ASSISTANT_WEB server for activate with keyword
                        • MOTIFY : search KEYWORD/ TRYTOSAY translation script to improve performance
                        • BUG: correct screen parser log
                        Assistant2Display v1.0.0
                        addons of AMk2 to display result links and photos of assistant search
                        credits:
                        • @Sean
                        • @bugsounet
                        Addons repository updated
                        see addon repository for more information ;)
                        Good assistant to you !
                        @bugsounet, @Sean
                        SergeS 1 Reply Last reply
                        • SergeS
                          Serge @Guest
                          @Bugsounet said in MMM-AssistantMk2 (v3):
                          Excellent updates!
                          @Bugsounet could you please explain in a few words the functionality of these two features:
                          I have looked briefly on module’s wiki and did not found what do they mean.
                            A Former User
                            @Serge said in MMM-AssistantMk2 (v3):
                            internal server to activate assistant with http://127.0.0.1:8080/activatebytext/?query='your request'
                            it’s used in Fullscreen ui for touch help response screen word to active assistant with it
                            KEYWORD/ TRYTOSAY
                            script to search and store
                            try to say... translation
                            keyword is help word if found
                            it’s used in Classic 2 ui
                              A Former User
                              MMM-AssisantMk2 v3.1.1-2
                              3.1.1-2 (06/03/2020)
                              • ADD/MODIFY: ui: "Fullscreen"
                                • position: "fullscreen_above" is now ui like Google Home
                              • MODIFY: user interface priority order Assistant2Display -> AMk2
                              • ADD: move native sound to class
                              SergeS A 2 Replies Last reply
                              • SergeS
                                Serge @Guest
                                @Bugsounet got it. thanx for quick reply. will test shortly
                                • A
                                  athavanraja @Guest
                                  @Bugsounet Hi I am on version 3.0.2 and trying to update to latest version.
                                  Running npm run update at ~/MagicMirror/modules/MMM-AssistantMk2 gives the following error message
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm run update
                                  npm ERR! missing script: update
                                  npm ERR! /home/pi/.npm/_logs/2020-03-15T18_41_39_806Z-debug.log
                                  Any help is highly appreciated.
                                  Thanks.
                                    A Former User
                                    hi, write update script since v3.1.X ;)
                                    so, retry with this:
                                    git pull
                                    npm run update
                                    it should work ;)
                                    notes :
                                    • install all new needed dependencies
                                    • skip GCC check
                                    • Electron rebuild step is not needed
                                    • Audio check is not needed too
                                    If you have some problems for updating, or if don’t work, i will help you ;)
                                    A 1 Reply Last reply
                                    • A
                                      athavanraja @Guest
                                      @Bugsounet Thank you very much. Updated to 3.1.1-2 All working fine.
                                      • A
                                        amsuvarna27
                                        Can anyone share me image file of Magic mirror back up with Voice recognition and face recognition
                                          A Former User
                                          MMM-AssistantMk2 v3.2.1
                                          NEW UPDATES
                                          3.2.1 (16/04/2020)
                                          • FIX: Send A2D response only on no hooked response
                                          • FIX: repository change owner
                                          • ADD: preprared recipe with-radio_fr.js recipe for A2D Radio (FR Only)
                                          • ADD: npm run rebuild -> REFRESH installation on MagicMirror version change
                                          3.2.0 (09/04/2020)
                                          • ADD: Chinese_simplified translate (thx to @wlmqpsc)
                                          • ADD: ability to play personnal sound on recipes soundExec command (see wiki)
                                          • FIX: no fade in animation on first use in Fullscreen ui
                                          • DEL: full addon code and cleanning
                                          • ADD: add control if A2D used
                                          3.1.2 (17/03/2020)
                                          • FIX: No sound response issue when custom action is used.
                                          • FIX: correct youtube search link.
                                          • ADD: Add A2D stop command (beta)
                                            A Former User
                                            we are now in v3.2.2 because i detect a problem in installation (package conflict and solved)
                                            • 3 / 7
