    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 109.4k Views 25 Watching
    • K
      Kevinho195 @Guest
      @Bugsounet thanks for your help :)
        A Former User
        We have updated AMk2 to v3.1.0-2
        Changes:
        • Standby icon Touch to activate assistant
        • AMk2 is now prepared to receive addons
        Note: I prepare sample and template addons.
        Coming soon ;)
        Just a little patience and I will come back to you for the addons
        EDIT
        Addons repository is now online
        • N
          nakedrabbit
          New version installed fine for me, though I did not git pull, just wiped the old one off. Installer worked great, and I no longer have to rebuild electron afterwards, as I did previously. Everything worked great.
          HOWEVER
          I still can’t get much action out of the plugin. Here’s my latest error dump:
          [AMK2] MMM-AssistantMk2 Version: 3.1.0-3
          0|mm | [AMK2] AssistantMk2 is initialized.
          0|mm | [HOTWORD] begins.
          0|mm | [HOTWORD] Detector starts listening.
          0|mm | [HOTWORD] Detected: SMARTMIRROR
          0|mm | [HOTWORD] After Recording: 4000
          0|mm | [HOTWORD] stops.
          0|mm | [HOTWORD] After Recording finised. size: 16050
          0|mm | [HOTWORD:B2W] WAV_FILE_CREATED: /home/pi/MagicMirror/modules/MMM-Hotword/temp/afterRecording.wav 16050
          0|mm | [HOTWORD] Final Result: { detected: true,
          0|mm | hotword: ‘SMARTMIRROR’,
          0|mm | file: ‘temp/afterRecording.wav’ }
          Seems to indicate Hotword is the problem…?
          Here are the last 15 errors:
          0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js:235:3)
          0|mm | at Module._compile (internal/modules/cjs/loader.js:711:30)
          0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
          0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
          0|mm | { Error: Cannot find module ‘google-assistant’
          0|mm | at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
          0|mm | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          0|mm | at Function.Module._load (internal/modules/cjs/loader.js:528:25)
          0|mm | at Module.require (internal/modules/cjs/loader.js:658:17)
          0|mm | at require (internal/modules/cjs/helpers.js:20:18)
          0|mm | at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js:1:180)
          0|mm | at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
          Triggered the module with MMM-Buttons, but when I do that, AssistantMk2 just waits and doesn’t listen, finally timing out.
            A Former User
            hi, google-assistant module is not installed.
            try this:
            cd ~/MagicMirror/modules/MMM-AssistantMk2
            npm install
            and execute electron rebuild :)
            • N
              nakedrabbit
              Yes, that seems obvious, but I did, in fact, follow the installation instructions, so I’m not sure why I have this error message either… left over from an aborted earlier attempt?
              In addition I took out Hotword and used your fine snowboy addon. Exactly the same effect, so I must have something wrong with my general setup… still testing…
              Thanks for your patience!
                A Former User
                @nakedrabbit : oupss, i have not seen your post :(
                maybe your problem is now solved…
                  A Former User
                  MMM-AssisantMk2 v3.1.1-1
                  3.1.1-1 (05/03/2020)
                  • BUG: correct audio cutting response for mpg321 (test)
                  • ADD: add cvlc audio out support (vlc using)
                  3.1.1-0 (02/03/2020)
                  • ADD: add new function for addons-recipe (socketExec, onSocketExec)
                  • BUG: continous conversation bug - infinite loop on no user response
                  • BUG: double chimed on TRANSCRIPTION_FAILS retry
                  • ADD: ability to set no chime on activate assistant
                  • ADD: touching the keyword “try to say” activates the assistant for the suggested search (Fullscreen and Classic2 ui)
                  • ADD: ASSISTANT_WEB server for activate with keyword
                  • MOTIFY : search KEYWORD/ TRYTOSAY translation script to improve performance
                  • BUG: correct screen parser log
                  Assistant2Display v1.0.0
                  addons of AMk2 to display result links and photos of assistant search
                  credits:
                  • @Sean
                  • @bugsounet
                  Addons repository updated
                  see addon repository for more information ;)
                  Good assistant to you !
                  @bugsounet, @Sean
                  SergeS 1 Reply Last reply
                  • SergeS
                    Serge @Guest
                    @Bugsounet said in MMM-AssistantMk2 (v3):
                    Excellent updates!
                    @Bugsounet could you please explain in a few words the functionality of these two features:
                    I have looked briefly on module’s wiki and did not found what do they mean.
                      A Former User
                      @Serge said in MMM-AssistantMk2 (v3):
                      internal server to activate assistant with http://127.0.0.1:8080/activatebytext/?query='your request'
                      it’s used in Fullscreen ui for touch help response screen word to active assistant with it
                      KEYWORD/ TRYTOSAY
                      script to search and store
                      try to say... translation
                      keyword is help word if found
                      it’s used in Classic 2 ui
                        A Former User
                        MMM-AssisantMk2 v3.1.1-2
                        3.1.1-2 (06/03/2020)
                        • ADD/MODIFY: ui: "Fullscreen"
                          • position: "fullscreen_above" is now ui like Google Home
                        • MODIFY: user interface priority order Assistant2Display -> AMk2
                        • ADD: move native sound to class
                        SergeS A 2 Replies Last reply
                        • SergeS
                          Serge @Guest
                          @Bugsounet got it. thanx for quick reply. will test shortly
                          • A
                            athavanraja @Guest
                            @Bugsounet Hi I am on version 3.0.2 and trying to update to latest version.
                            Running npm run update at ~/MagicMirror/modules/MMM-AssistantMk2 gives the following error message
                            pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm run update
                            npm ERR! missing script: update
                            npm ERR! /home/pi/.npm/_logs/2020-03-15T18_41_39_806Z-debug.log
                            Any help is highly appreciated.
                            Thanks.
                              A Former User
                              hi, write update script since v3.1.X ;)
                              so, retry with this:
                              git pull
                              npm run update
                              it should work ;)
                              notes :
                              • install all new needed dependencies
                              • skip GCC check
                              • Electron rebuild step is not needed
                              • Audio check is not needed too
                              If you have some problems for updating, or if don’t work, i will help you ;)
                              A 1 Reply Last reply
                              • A
                                athavanraja @Guest
                                @Bugsounet Thank you very much. Updated to 3.1.1-2 All working fine.
                                • A
                                  amsuvarna27
                                  Can anyone share me image file of Magic mirror back up with Voice recognition and face recognition
                                    A Former User
                                    MMM-AssistantMk2 v3.2.1
                                    NEW UPDATES
                                    3.2.1 (16/04/2020)
                                    • FIX: Send A2D response only on no hooked response
                                    • FIX: repository change owner
                                    • ADD: preprared recipe with-radio_fr.js recipe for A2D Radio (FR Only)
                                    • ADD: npm run rebuild -> REFRESH installation on MagicMirror version change
                                    3.2.0 (09/04/2020)
                                    • ADD: Chinese_simplified translate (thx to @wlmqpsc)
                                    • ADD: ability to play personnal sound on recipes soundExec command (see wiki)
                                    • FIX: no fade in animation on first use in Fullscreen ui
                                    • DEL: full addon code and cleanning
                                    • ADD: add control if A2D used
                                    3.1.2 (17/03/2020)
                                    • FIX: No sound response issue when custom action is used.
                                    • FIX: correct youtube search link.
                                    • ADD: Add A2D stop command (beta)
                                      A Former User
                                      we are now in v3.2.2 because i detect a problem in installation (package conflict and solved)
                                        costascontis
                                        using the latest module + MMM-Hotword and everything works exept controling MMM-Spotify by voice.I use the prepared recipe for it ,MMM-Spotify is showing whatever is playing allright but no voice command is working. My config:
                                                               module: "MMM-AssistantMk2",
        ui: "Classic",
        assistantConfig: {
                                        						  projectId: "kitchen-tv-d4c48", // Required to use gaction.
        modelId: "kitchen-tv", // (OPTIONAL for gaction)
        instanceId: "kitchen-tv", // (OPTIONAL for gaction)
        latitude: 37.975342,
        longitude: 23.736151,
        micConfig: {
        recorder: "arecord",
                                        			                    device: "plughw:1"
        recipes: [ "with-MMM-Hotword.js", "Reboot-Restart-Shutdown.js", "with-MMM-Spotify.js" ],
        profiles: {
                                        					   "default": {
        profileFile: "default.json",
        lang: "en-US"
        useA2D: false,
        module: "MMM-Hotword",
        position: "bottom_left",
        useDisplay: false,
        chimeOnFinish: null,
        recipes: ["with-AMk2v3_Jarvis.js"],
        mic: {
                                        			recordProgram: "arecord",
        device: "plughw:1",
                                        			module: "MMM-Spotify",
                                        				 style: "mini", // "default" or "mini" available
        control: "hidden", //"default", "hidden" available
        updateInterval: 1000,
        onStart: null, // disable onStart feature with `null`
        allowDevices: [], //If you want to limit devices to display info, use this.
        // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                                        ? A 2 Replies Last reply
                                          A Former User @costascontis
                                          @costascontis : MMM-Spotify and recipes have an issue @eouia will solve it soon.
                                          I can’t inspect it, because I have no premium account
                                          C 1 Reply Last reply
                                            costascontis @Guest
                                            oh!!! need to have premium account on spotify to work?i dont…
                                            ? 1 Reply Last reply
                                            • 3 / 7
