    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      A Former User
      @Serge said in MMM-AssistantMk2 (v3):
      ASSISTANT_WEB server
      internal server to activate assistant with http://127.0.0.1:8080/activatebytext/?query='your request'
      it’s used in Fullscreen ui for touch help response screen word to active assistant with it
      KEYWORD/ TRYTOSAY
      script to search and store
      try to say... translation
      keyword is help word if found
      it’s used in Classic 2 ui
        A Former User
        MMM-AssisantMk2 v3.1.1-2
        3.1.1-2 (06/03/2020)
        • ADD/MODIFY: ui: "Fullscreen"
          • position: "fullscreen_above" is now ui like Google Home
        • MODIFY: user interface priority order Assistant2Display -> AMk2
        • ADD: move native sound to class
        SergeS A 2 Replies Last reply Reply Quote 0
        • SergeS
          Serge @Guest
          @Bugsounet got it. thanx for quick reply. will test shortly
          • A
            athavanraja @Guest
            @Bugsounet Hi I am on version 3.0.2 and trying to update to latest version.
            Running npm run update at ~/MagicMirror/modules/MMM-AssistantMk2 gives the following error message
            pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm run update
            npm ERR! missing script: update
            npm ERR! /home/pi/.npm/_logs/2020-03-15T18_41_39_806Z-debug.log
            Any help is highly appreciated.
            Thanks.
              A Former User
              hi, write update script since v3.1.X ;)
              so, retry with this:
              cd ~/MagicMirror/modules/MMM-AssistantMk2
              git pull
              npm run update
              it should work ;)
              notes :
              • install all new needed dependencies
              • skip GCC check
              • Electron rebuild step is not needed
              • Audio check is not needed too
              If you have some problems for updating, or if don’t work, i will help you ;)
              • A
                athavanraja @Guest
                @Bugsounet Thank you very much. Updated to 3.1.1-2 All working fine.
                • A
                  amsuvarna27
                  Can anyone share me image file of Magic mirror back up with Voice recognition and face recognition
                    A Former User
                    MMM-AssistantMk2 v3.2.1
                    NEW UPDATES
                    3.2.1 (16/04/2020)
                    • FIX: Send A2D response only on no hooked response
                    • FIX: repository change owner
                    • ADD: preprared recipe with-radio_fr.js recipe for A2D Radio (FR Only)
                    • ADD: npm run rebuild -> REFRESH installation on MagicMirror version change
                    3.2.0 (09/04/2020)
                    • ADD: Chinese_simplified translate (thx to @wlmqpsc)
                    • ADD: ability to play personnal sound on recipes soundExec command (see wiki)
                    • FIX: no fade in animation on first use in Fullscreen ui
                    • DEL: full addon code and cleanning
                    • ADD: add control if A2D used
                    3.1.2 (17/03/2020)
                    • FIX: No sound response issue when custom action is used.
                    • FIX: correct youtube search link.
                    • ADD: Add A2D stop command (beta)
                      A Former User
                      we are now in v3.2.2 because i detect a problem in installation (package conflict and solved)
                        costascontis
                        using the latest module + MMM-Hotword and everything works exept controling MMM-Spotify by voice.I use the prepared recipe for it ,MMM-Spotify is showing whatever is playing allright but no voice command is working. My config:
                                               module: "MMM-AssistantMk2",
                                                        ui: "Classic",
                                                        assistantConfig: {
                        						  projectId: "kitchen-tv-d4c48", // Required to use gaction.
        modelId: "kitchen-tv", // (OPTIONAL for gaction)
        instanceId: "kitchen-tv", // (OPTIONAL for gaction)
        latitude: 37.975342,
        longitude: 23.736151,
        micConfig: {
        recorder: "arecord",
                        			                    device: "plughw:1"
        recipes: [ "with-MMM-Hotword.js", "Reboot-Restart-Shutdown.js", "with-MMM-Spotify.js" ],
        profiles: {
                        					   "default": {
        profileFile: "default.json",
        lang: "en-US"
        useA2D: false,
                                                module: "MMM-Hotword",
                                                position: "bottom_left",
                                                useDisplay: false,
                                                chimeOnFinish: null,
                                                recipes: ["with-AMk2v3_Jarvis.js"],
                                                mic: {
                        			recordProgram: "arecord",
                                                device: "plughw:1",
                        			module: "MMM-Spotify",
                        				 style: "mini", // "default" or "mini" available
                                                         control: "hidden", //"default", "hidden" available
                                                         updateInterval: 1000,
                                                         onStart: null, // disable onStart feature with `null`
                                                         allowDevices: [], //If you want to limit devices to display info, use this.
                                                         // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                        ? A 2 Replies Last reply Reply Quote 0
                          A Former User @costascontis
                          @costascontis : MMM-Spotify and recipes have an issue @eouia will solve it soon.
                          I can’t inspect it, because I have no premium account
                            costascontis @Guest
                            @Bugsounet said in MMM-AssistantMk2 (v3):
                            oh!!! need to have premium account on spotify to work?i dont…
                              @costascontis
                              You should be a premium member of Spotify
                                costascontis @Guest
                                @Sean said in MMM-AssistantMk2 (v3):
                                @costascontis
                                so as a free member on Spotify i can use MMM-Spotify to see what is playing but i can not control it by voice?
                                  @costascontis said in MMM-AssistantMk2 (v3):
                                  Hmmm. I didn’t test. but there is a possibility not to use any feature (Because some API’s are tied together, so I’m not sure)
                                    costascontis @Guest
                                    @Sean i did so as a free member i can only see what’s playing,album photo an info about song,artist and device playing.I only cant control anything.
                                      Notes: it’s not related to MMM-Spotify but it’s Spotify Api want that
                                      • A
                                        amsuvarna27 @costascontis
                                          A Former User
                                          MMM-AssistantMk2 v3.2.3
                                          NEW UPDATES
                                          3.2.3 (30/04/2020)
                                          • ADD: New ui -> Simple
                                          • OPT: Optional Build with Snowboy embed
                                          • ADD: A2DStopCommand for personalize your stop command (Assistant2Display Server)
                                          • FIX: some logs
                                          3.2.2 (17/04/2020)
                                          • FIX: Package.json (google-assistant)
                                          E 1 Reply Last reply Reply Quote 1
                                          • E
                                            electros Project Sponsor @Guest
                                            @Bugsounet Hi, I installed this module and A2D module and it’s working fine just few small problems:
                                            1 When I want to use this module with A2D and the answer is coming on the screen all the modules is go hiding and its coming back on the screen after 1 minute. If I use without A2D everything works fine and the modules just go blurred behind of the answer window and come back fast.
                                            2 it’s try to use that radio recipe but I can’t manage to start any radio station. I don’t know how it’s work. Every time when the assistant understands station name he look on the Internet to find information about that radio station but never want to start listening. I must install something else ?
                                            Apart of this everything it’s fine and the module it’s brilliant. Thank you for this.
                                            • 4 / 7
