    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
    • A
      athavanraja @Guest
      @Bugsounet Hi I am on version 3.0.2 and trying to update to latest version.
      Running npm run update at ~/MagicMirror/modules/MMM-AssistantMk2 gives the following error message
      pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm run update
      npm ERR! missing script: update
      npm ERR! /home/pi/.npm/_logs/2020-03-15T18_41_39_806Z-debug.log
      Any help is highly appreciated.
      Thanks.
        A Former User
        hi, write update script since v3.1.X ;)
        so, retry with this:
        cd ~/MagicMirror/modules/MMM-AssistantMk2
        git pull
        npm run update
        it should work ;)
        notes :
        • install all new needed dependencies
        • skip GCC check
        • Electron rebuild step is not needed
        • Audio check is not needed too
        If you have some problems for updating, or if don’t work, i will help you ;)
        • A
          athavanraja @Guest
          @Bugsounet Thank you very much. Updated to 3.1.1-2 All working fine.
          • A
            amsuvarna27
            Can anyone share me image file of Magic mirror back up with Voice recognition and face recognition
              A Former User
              MMM-AssistantMk2 v3.2.1
              NEW UPDATES
              3.2.1 (16/04/2020)
              • FIX: Send A2D response only on no hooked response
              • FIX: repository change owner
              • ADD: preprared recipe with-radio_fr.js recipe for A2D Radio (FR Only)
              • ADD: npm run rebuild -> REFRESH installation on MagicMirror version change
              3.2.0 (09/04/2020)
              • ADD: Chinese_simplified translate (thx to @wlmqpsc)
              • ADD: ability to play personnal sound on recipes soundExec command (see wiki)
              • FIX: no fade in animation on first use in Fullscreen ui
              • DEL: full addon code and cleanning
              • ADD: add control if A2D used
              3.1.2 (17/03/2020)
              • FIX: No sound response issue when custom action is used.
              • FIX: correct youtube search link.
              • ADD: Add A2D stop command (beta)
                A Former User
                we are now in v3.2.2 because i detect a problem in installation (package conflict and solved)
                  costascontis
                  using the latest module + MMM-Hotword and everything works exept controling MMM-Spotify by voice.I use the prepared recipe for it ,MMM-Spotify is showing whatever is playing allright but no voice command is working. My config:
                                         module: "MMM-AssistantMk2",
                                                  ui: "Classic",
                                                  assistantConfig: {
                  						  projectId: "kitchen-tv-d4c48", // Required to use gaction.
        modelId: "kitchen-tv", // (OPTIONAL for gaction)
        instanceId: "kitchen-tv", // (OPTIONAL for gaction)
        latitude: 37.975342,
        longitude: 23.736151,
                                                              micConfig: {
                                                              recorder: "arecord",
                  			                    device: "plughw:1"
                                                            recipes: [ "with-MMM-Hotword.js", "Reboot-Restart-Shutdown.js", "with-MMM-Spotify.js" ],
                                                            profiles: {
                  					   "default": {
        profileFile: "default.json",
        lang: "en-US"
                                                              useA2D: false,
                                          module: "MMM-Hotword",
                                          position: "bottom_left",
                                          useDisplay: false,
                                          chimeOnFinish: null,
                                          recipes: ["with-AMk2v3_Jarvis.js"],
                                          mic: {
                  			recordProgram: "arecord",
                                          device: "plughw:1",
                  			module: "MMM-Spotify",
                  				 style: "mini", // "default" or "mini" available
                                                   control: "hidden", //"default", "hidden" available
                                                   updateInterval: 1000,
                                                   onStart: null, // disable onStart feature with `null`
                                                   allowDevices: [], //If you want to limit devices to display info, use this.
                                                   // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                  ? A 2 Replies Last reply Reply Quote 0
                    A Former User @costascontis
                    @costascontis : MMM-Spotify and recipes have an issue @eouia will solve it soon.
                    I can’t inspect it, because I have no premium account
                      costascontis @Guest
                      @Bugsounet said in MMM-AssistantMk2 (v3):
                      oh!!! need to have premium account on spotify to work?i dont…
                        @costascontis
                        You should be a premium member of Spotify
                          costascontis @Guest
                          @Sean said in MMM-AssistantMk2 (v3):
                          @costascontis
                          so as a free member on Spotify i can use MMM-Spotify to see what is playing but i can not control it by voice?
                            @costascontis said in MMM-AssistantMk2 (v3):
                            Hmmm. I didn’t test. but there is a possibility not to use any feature (Because some API’s are tied together, so I’m not sure)
                              costascontis @Guest
                              @Sean i did so as a free member i can only see what’s playing,album photo an info about song,artist and device playing.I only cant control anything.
                                Notes: it’s not related to MMM-Spotify but it’s Spotify Api want that
                                • A
                                  amsuvarna27 @costascontis
                                    A Former User
                                    MMM-AssistantMk2 v3.2.3
                                    NEW UPDATES
                                    3.2.3 (30/04/2020)
                                    • ADD: New ui -> Simple
                                    • OPT: Optional Build with Snowboy embed
                                    • ADD: A2DStopCommand for personalize your stop command (Assistant2Display Server)
                                    • FIX: some logs
                                    3.2.2 (17/04/2020)
                                    • FIX: Package.json (google-assistant)
                                    E 1 Reply Last reply Reply Quote 1
                                    • E
                                      electros Project Sponsor @Guest
                                      @Bugsounet Hi, I installed this module and A2D module and it’s working fine just few small problems:
                                      1 When I want to use this module with A2D and the answer is coming on the screen all the modules is go hiding and its coming back on the screen after 1 minute. If I use without A2D everything works fine and the modules just go blurred behind of the answer window and come back fast.
                                      2 it’s try to use that radio recipe but I can’t manage to start any radio station. I don’t know how it’s work. Every time when the assistant understands station name he look on the Internet to find information about that radio station but never want to start listening. I must install something else ?
                                      Apart of this everything it’s fine and the module it’s brilliant. Thank you for this.
                                        A Former User
                                        hi @electros
                                        1. i think you forget MagicMirror configuration part
                                          Read here
                                        2. i have prepare a guide for create it
                                          Read here
                                        but it’s not finish … there is some surprise again … if i have a lot of time ;)
                                        • E
                                          @Bugsounet
                                          Hello again. I tried what you recommended but without much success. First I made the settings for A2D as you recommended and now when I ask something after the assistant answers me an internet window opens with reference to the answer this being a new and very good thing. But when the assistant starts saying the answer, it hides the modules on the screen apart of calendarext. I was talking about this in the post above. I put a short video on youtube.
                                          https://youtu.be/DOIkuA60tKo
                                          As for the radio, I tried after that tutorial but without success.
                                          I tried to use that file “with-radio_fr.js” but when I say “cheriefm” the assistant shows me the website of the radio station “cheriefm” saying “here is what I found on the web” without starting the radio station.
                                          Thank you.
                                            A Former User
                                            @electros said in MMM-AssistantMk2 (v3):
                                            it’s a know bug of calendarext
                                            ah … “cheriefm” is the name of the block (like a landmark)
                                            the think to say is “mets chérie fm” in the sample.
                                            you can try to change it for your language with pattern value
                                            exemple: if you change pattern value to radio test
                                            if you say : radio test it will reconize the cheriefm command and execute it (send to A2D mp3 link of the radio and img)
                                            E 2 Replies Last reply Reply Quote 0
                                            • 4 / 7
