    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 102.5k Views 25 Watching
      [[global:former-user]] @costascontis
      @costascontis said in MMM-AssistantMk2 (v3):
      so as a free member on Spotify i can use MMM-Spotify to see what is playing but i can not control it by voice?
      Hmmm. I didn’t test. but there is a possibility not to use any feature (Because some API’s are tied together, so I’m not sure)
        costascontis @Guest
        @Sean i did so as a free member i can only see what’s playing,album photo an info about song,artist and device playing.I only cant control anything.
          Notes: it’s not related to MMM-Spotify but it’s Spotify Api want that
            amsuvarna27 @costascontis
              MMM-AssistantMk2 v3.2.3
              NEW UPDATES
              3.2.3 (30/04/2020)
              • ADD: New ui -> Simple
              • OPT: Optional Build with Snowboy embed
              • ADD: A2DStopCommand for personalize your stop command (Assistant2Display Server)
              • FIX: some logs
              3.2.2 (17/04/2020)
              • FIX: Package.json (google-assistant)
              E 1 Reply Last reply Reply Quote 1
              • E Offline
                electros Project Sponsor @Guest
                @Bugsounet Hi, I installed this module and A2D module and it’s working fine just few small problems:
                1 When I want to use this module with A2D and the answer is coming on the screen all the modules is go hiding and its coming back on the screen after 1 minute. If I use without A2D everything works fine and the modules just go blurred behind of the answer window and come back fast.
                2 it’s try to use that radio recipe but I can’t manage to start any radio station. I don’t know how it’s work. Every time when the assistant understands station name he look on the Internet to find information about that radio station but never want to start listening. I must install something else ?
                Apart of this everything it’s fine and the module it’s brilliant. Thank you for this.
                  hi @electros
                  1. i think you forget MagicMirror configuration part
                    Read here
                  2. i have prepare a guide for create it
                    Read here
                  but it’s not finish … there is some surprise again … if i have a lot of time ;)
                  • E Offline
                    @Bugsounet
                    Hello again. I tried what you recommended but without much success. First I made the settings for A2D as you recommended and now when I ask something after the assistant answers me an internet window opens with reference to the answer this being a new and very good thing. But when the assistant starts saying the answer, it hides the modules on the screen apart of calendarext. I was talking about this in the post above. I put a short video on youtube.
                    https://youtu.be/DOIkuA60tKo
                    As for the radio, I tried after that tutorial but without success.
                    I tried to use that file “with-radio_fr.js” but when I say “cheriefm” the assistant shows me the website of the radio station “cheriefm” saying “here is what I found on the web” without starting the radio station.
                    Thank you.
                      @electros said in MMM-AssistantMk2 (v3):
                      it’s a know bug of calendarext
                      ah … “cheriefm” is the name of the block (like a landmark)
                      the think to say is “mets chérie fm” in the sample.
                      you can try to change it for your language with pattern value
                      exemple: if you change pattern value to radio test
                      if you say : radio test it will reconize the cheriefm command and execute it (send to A2D mp3 link of the radio and img)
                      E 2 Replies Last reply Reply Quote 0
                      • E Offline
                        @Bugsounet said in MMM-AssistantMk2 (v3):
                        okay but couldn’t remain all the modules on the screen behind the assistant window?
                        Well I need to practice more with this. for a start I think I should look for another microphone, the assistant doesn’t really understand what I’m saying.
                        Do you think a respeaker board with 2 microphones would be better than a USB microphone?
                        SergeS 1 Reply Last reply Reply Quote 0
                        • SergeS Offline
                          Serge @electros
                          One possible solution for mic
                          Working on getting a good hardware solution for MMM-AssistantMK2
                          • E Offline
                            electros Project Sponsor @Serge
                            @Serge Thank you for the link i was looking for a solution like that.
                              jimmydew
                              Hey everyone, I have a problem with the MMM-assistantMk2:
                              The Icon is showing on the mirror, when i click on it in VNC it activates,and works. but it doesnt activate by my voice on the mirror.
                              any ideas? these are my configs:
                              var config = {
                              	port: 8080,
                              	language: "en",
                              	timeFormat: 24,
                              	units: "metric",
                              			     // false, default for all  NON-armv6l devices
                              			module: "clock",
                              			position: "top_left"
                              			header: "US Holidays",
                              						symbol: "calendar-check",
                              						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                              			module: "compliments",
                              			position: "lower_third"
                              			module: "currentweather",
                              				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                              			module: "weatherforecast",
                              			header: "Weather Forecast",
                              				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                              			module: "newsfeed",
                              			position: "bottom_bar",
                              				feeds: [
                              						title: "New York Times",
                              				showSourceTitle: true,
                              				showPublishDate: true,
                              				broadcastNewsFeeds: true,
                              				broadcastNewsUpdates: true
                                module: "MMM-AssistantMk2",
                                  debug: false,
                                  ui: "Classic", // Classic2, Classic or Simple
                                  // if you want Google Nest ui style
                                  // set Fullscreen ui AND fullscreen_above position
                                  assistantConfig: {
                                    projectId: "", // Required to use gaction.
                                    modelId: "", // (OPTIONAL for gaction)
                                    instanceId: "", // (OPTIONAL for gaction)
                                    latitude: 52.0955919,
                                    longitude: 4.4711253,
                                  responseConfig: {
                                    useHTML5: true, // sound render by HTML5
                                    useScreenOutput: true,
                                    useAudioOutput: true,
                                    useChime: true,
                                    timer: 5000,
                                    myMagicWord: true,
                                    //Your prefer sound play program.
                                    //By example, if you are running this on OSX, `afplay` could be available.
                                    //by default mpg321 play program is enabled
                                    //if audio output cutting try with mpg123 or cvlc program
                                    playProgram: "mpg321",
                                    chime: {
                                      beep: "beep.mp3",
                                      error: "error.mp3",
                                      continue: "continue.mp3",
                                      open: "Google_beep_open.mp3",
                                      close: "Google_beep_close.mp3",
                                    // false - animated icons, 'standby' - static icons only for standby state, true - all static icons
                                    useStaticIcons: false
                                  micConfig: { // put there configuration generated by auto-installer
                                    recorder: "arecord",
                                    device: "plughw:1",
                                  customActionConfig: {
                                    autoMakeAction: false,
                                    autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                                    actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                                  recipes: [ "with-MMM-TelegramBot.js" ],
                                  profiles: {
                                    "default": {
                                      profileFile: "default.json",
                                      lang: "en-US"
                                  useA2D: false,
                                  A2DStopCommand: "stop",
                                  useSnowboy: true,
                                  snowboy: {
                                    audioGain: 2.0,
                                    Frontend: true,
                                    Model: "jarvis",
                                    Sensitivity: null
                              (it’s running on raspberry pi 4b)
                                useSnowboy: true,
                                if you use this feature, you need to update AMk2
                                npm run update
                                try this in AMk2 directory
                                and enable snowboy library (and electron rebuild for snowboy)
                                  sdetweil @jimmydew
                                  @jimmydew in the future please use the markdown for code
                                  select the text and hit the </> icon above the editor
                                    jimmydew @Guest
                                    @Bugsounet
                                    i got quite a few errors on the rebuild:
                                    ✖ Rebuild Failed
                                    An unhandled error occurred inside electron-rebuild
                                    make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                                      CXX(target) Release/obj.target/snowboy/lib/snowboy.o
                                    In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
                                                     from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
                                                     from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                                                     from ../../../nan/nan.h:56,
                                                     from ../lib/snowboy.cc:1:
                                    /home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
                                       declarator __attribute__((deprecated(message)))
                                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                                       V8_DEPRECATE_SOON("Use *WithData version.",
                                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                                    In file included from ../lib/snowboy.cc:1:
                                    ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                    ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                    ../lib/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
                                    ../lib/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
                                       } catch (std::runtime_error e) {
                                    In file included from ../../../nan/nan.h:56,
                                    ../lib/snowboy.cc: At global scope:
                                    /home/pi/.electron-gyp/6.1.7/include/node/node.h:572:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                           (node::addon_register_func) (regfunc),                          \
                                    /home/pi/.electron-gyp/6.1.7/include/node/node.h:606:3: note: in expansion of macro ‘NODE_MODULE_X’
                                       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                    ../lib/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
                                     NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
                                    In file included from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                                    /home/pi/.electron-gyp/6.1.7/include/node/node_object_wrap.h:84:78:   required from here
                                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                                    reinterpret_cast<Callback>(callback), type);
                                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                                    ../../../nan/nan_object_wrap.h:65:61:   required from here
                                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                      SOLINK_MODULE(target) Release/obj.target/snowboy.node
                                    /usr/bin/ld: cannot find -lcblas
                                    collect2: error: ld returned 1 exit status
                                    make: *** [snowboy.target.mk:143: Release/obj.target/snowboy.node] Error 1
                                    make: Leaving directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                                    gyp ERR! build error
                                    gyp ERR! stack Error: `make` failed with exit code: 2
                                    gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:194:23)
                                    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                    gyp ERR! System Linux 5.4.35-v7l+
                                    gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm" "--remote_path=./snowboy/v1.4.7/Release/" "--package_name=snowboy-v1.4.7-electron-v6.1-linux-arm.tar.gz" "--host=https://github.com/bugsounet/snowboy"
                                    gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
                                    gyp ERR! node -v v10.20.1
                                    gyp ERR! node-gyp -v v6.1.0
                                    gyp ERR! not ok
                                    Failed with exit code: 1
                                    Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                                    gyp ERR! not ok
                                        at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:267:84)
                                        at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:205:16)
                                        at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:156:26)
                                        at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                                        at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                                        at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                                        at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                                        at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:242:65)
                                        at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:143:22)
                                    > @bugsounet/snowboy@1.4.7 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
                                    > tsc -p tsconfig.json
                                    + @bugsounet/snowboy@1.4.7
                                    added 20 packages from 25 contributors and audited 315 packages in 38.481s
                                    3 packages are looking for funding
                                      run `npm fund` for details
                                    found 6 low severity vulnerabilities
                                      run `npm audit fix` to fix them, or `npm audit` for details
                                    @bugsounet/snowboy library installed
                                      @jimmydew said in MMM-AssistantMk2 (v3):
                                      Linux 5.4.35-v7l+
                                      ah …
                                      and what version of gcc do you use ?
                                      try gcc --version in console
                                        jimmydew @Guest
                                        @Bugsounet
                                        pi@raspberrypi:~/MagicMirror $ gcc --version
                                        gcc (Raspbian 7.3.0-19) 7.3.0
                                        Copyright (C) 2017 Free Software Foundation, Inc.
                                        This is free software; see the source for copying conditions.  There is NO
                                        warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                                        • E Offline
                                          @Bugsounet Hi, again. I managed to make my radio station list and everything works fine, just I don’t know how to stop the radio. Can you please explain me how to add a stop radio command?
                                          Thank you
                                             @jimmydew can you do this command for more informations, please ?
                                            cat /etc/*release
                                            @electros :
                                            Good job !
                                            For stop radio (and other A2D module), i create a feature in AMk2 (A2D Server part)
                                            You can define your prefered stop command
                                            by default it’s stop but … it’s depend of your language !
                                            for exemple in french language, when i say stop, google transcript stoppe
                                            you have an exemple in AMk2 structure sample
                                            E J 2 Replies Last reply Reply Quote 0
                                            • 4 / 7
