    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      A Former User @costascontis
      @costascontis
      You should be a premium member of Spotify
        costascontis @Guest
        @Sean said in MMM-AssistantMk2 (v3):
        @costascontis
        so as a free member on Spotify i can use MMM-Spotify to see what is playing but i can not control it by voice?
          @costascontis said in MMM-AssistantMk2 (v3):
          Hmmm. I didn’t test. but there is a possibility not to use any feature (Because some API’s are tied together, so I’m not sure)
            costascontis @Guest
            @Sean i did so as a free member i can only see what’s playing,album photo an info about song,artist and device playing.I only cant control anything.
              Notes: it’s not related to MMM-Spotify but it’s Spotify Api want that
              • A
                amsuvarna27 @costascontis
                  A Former User
                  MMM-AssistantMk2 v3.2.3
                  NEW UPDATES
                  3.2.3 (30/04/2020)
                  • ADD: New ui -> Simple
                  • OPT: Optional Build with Snowboy embed
                  • ADD: A2DStopCommand for personalize your stop command (Assistant2Display Server)
                  • FIX: some logs
                  3.2.2 (17/04/2020)
                  • FIX: Package.json (google-assistant)
                  E 1 Reply Last reply Reply Quote 1
                  • E
                    electros Project Sponsor @Guest
                    @Bugsounet Hi, I installed this module and A2D module and it’s working fine just few small problems:
                    1 When I want to use this module with A2D and the answer is coming on the screen all the modules is go hiding and its coming back on the screen after 1 minute. If I use without A2D everything works fine and the modules just go blurred behind of the answer window and come back fast.
                    2 it’s try to use that radio recipe but I can’t manage to start any radio station. I don’t know how it’s work. Every time when the assistant understands station name he look on the Internet to find information about that radio station but never want to start listening. I must install something else ?
                    Apart of this everything it’s fine and the module it’s brilliant. Thank you for this.
                      A Former User
                      hi @electros
                      1. i think you forget MagicMirror configuration part
                        Read here
                      2. i have prepare a guide for create it
                        Read here
                      but it’s not finish … there is some surprise again … if i have a lot of time ;)
                      • E
                        @Bugsounet
                        Hello again. I tried what you recommended but without much success. First I made the settings for A2D as you recommended and now when I ask something after the assistant answers me an internet window opens with reference to the answer this being a new and very good thing. But when the assistant starts saying the answer, it hides the modules on the screen apart of calendarext. I was talking about this in the post above. I put a short video on youtube.
                        https://youtu.be/DOIkuA60tKo
                        As for the radio, I tried after that tutorial but without success.
                        I tried to use that file “with-radio_fr.js” but when I say “cheriefm” the assistant shows me the website of the radio station “cheriefm” saying “here is what I found on the web” without starting the radio station.
                        Thank you.
                          A Former User
                          @electros said in MMM-AssistantMk2 (v3):
                          it’s a know bug of calendarext
                          ah … “cheriefm” is the name of the block (like a landmark)
                          the think to say is “mets chérie fm” in the sample.
                          you can try to change it for your language with pattern value
                          exemple: if you change pattern value to radio test
                          if you say : radio test it will reconize the cheriefm command and execute it (send to A2D mp3 link of the radio and img)
                          E 2 Replies Last reply Reply Quote 0
                          • E
                            @Bugsounet said in MMM-AssistantMk2 (v3):
                            okay but couldn’t remain all the modules on the screen behind the assistant window?
                            Well I need to practice more with this. for a start I think I should look for another microphone, the assistant doesn’t really understand what I’m saying.
                            Do you think a respeaker board with 2 microphones would be better than a USB microphone?
                            SergeS 1 Reply Last reply Reply Quote 0
                            • SergeS
                              Serge @electros
                              One possible solution for mic
                              Working on getting a good hardware solution for MMM-AssistantMK2
                              • E
                                electros Project Sponsor @Serge
                                @Serge Thank you for the link i was looking for a solution like that.
                                  jimmydew
                                  Hey everyone, I have a problem with the MMM-assistantMk2:
                                  The Icon is showing on the mirror, when i click on it in VNC it activates,and works. but it doesnt activate by my voice on the mirror.
                                  any ideas? these are my configs:
                                  var config = {
                                  	port: 8080,
                                  	language: "en",
                                  	timeFormat: 24,
                                  	units: "metric",
                                  			     // false, default for all  NON-armv6l devices
                                  			module: "clock",
                                  			position: "top_left"
                                  			header: "US Holidays",
                                  						symbol: "calendar-check",
                                  						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                  			module: "compliments",
                                  			position: "lower_third"
                                  			module: "currentweather",
                                  				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                  			module: "weatherforecast",
                                  			header: "Weather Forecast",
                                  				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                  			module: "newsfeed",
                                  			position: "bottom_bar",
                                  				feeds: [
                                  						title: "New York Times",
                                  				showSourceTitle: true,
                                  				showPublishDate: true,
                                  				broadcastNewsFeeds: true,
                                  				broadcastNewsUpdates: true
                                    module: "MMM-AssistantMk2",
                                      debug: false,
                                      ui: "Classic", // Classic2, Classic or Simple
                                      // if you want Google Nest ui style
                                      // set Fullscreen ui AND fullscreen_above position
                                      assistantConfig: {
                                        projectId: "", // Required to use gaction.
                                        modelId: "", // (OPTIONAL for gaction)
                                        instanceId: "", // (OPTIONAL for gaction)
                                        latitude: 52.0955919,
                                        longitude: 4.4711253,
                                      responseConfig: {
                                        useHTML5: true, // sound render by HTML5
                                        useScreenOutput: true,
                                        useAudioOutput: true,
                                        useChime: true,
                                        timer: 5000,
                                        myMagicWord: true,
                                        //Your prefer sound play program.
                                        //By example, if you are running this on OSX, `afplay` could be available.
                                        //by default mpg321 play program is enabled
                                        //if audio output cutting try with mpg123 or cvlc program
                                        playProgram: "mpg321",
                                        chime: {
                                          beep: "beep.mp3",
                                          error: "error.mp3",
                                          continue: "continue.mp3",
                                          open: "Google_beep_open.mp3",
                                          close: "Google_beep_close.mp3",
                                        // false - animated icons, 'standby' - static icons only for standby state, true - all static icons
                                        useStaticIcons: false
                                      micConfig: { // put there configuration generated by auto-installer
                                        recorder: "arecord",
                                        device: "plughw:1",
                                      customActionConfig: {
                                        autoMakeAction: false,
                                        autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                                        actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                                      recipes: [ "with-MMM-TelegramBot.js" ],
                                      profiles: {
                                        "default": {
                                          profileFile: "default.json",
                                          lang: "en-US"
                                      useA2D: false,
                                      A2DStopCommand: "stop",
                                      useSnowboy: true,
                                      snowboy: {
                                        audioGain: 2.0,
                                        Frontend: true,
                                        Model: "jarvis",
                                        Sensitivity: null
                                  (it’s running on raspberry pi 4b)
                                    A Former User
                                    useSnowboy: true,
                                    if you use this feature, you need to update AMk2
                                    npm run update
                                    try this in AMk2 directory
                                    and enable snowboy library (and electron rebuild for snowboy)
                                      sdetweil @jimmydew
                                      @jimmydew in the future please use the markdown for code
                                      select the text and hit the </> icon above the editor
                                        jimmydew @Guest
                                        @Bugsounet
                                        i got quite a few errors on the rebuild:
                                        ✖ Rebuild Failed
                                        An unhandled error occurred inside electron-rebuild
                                        make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                                          CXX(target) Release/obj.target/snowboy/lib/snowboy.o
                                        In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
                                                         from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
                                                         from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                                                         from ../../../nan/nan.h:56,
                                                         from ../lib/snowboy.cc:1:
                                        /home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
                                           declarator __attribute__((deprecated(message)))
                                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                                           V8_DEPRECATE_SOON("Use *WithData version.",
                                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                                        In file included from ../lib/snowboy.cc:1:
                                        ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                        ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                        ../lib/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
                                        ../lib/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
                                           } catch (std::runtime_error e) {
                                        In file included from ../../../nan/nan.h:56,
                                        ../lib/snowboy.cc: At global scope:
                                        /home/pi/.electron-gyp/6.1.7/include/node/node.h:572:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                               (node::addon_register_func) (regfunc),                          \
                                        /home/pi/.electron-gyp/6.1.7/include/node/node.h:606:3: note: in expansion of macro ‘NODE_MODULE_X’
                                           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                        ../lib/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
                                         NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
                                        In file included from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                                        /home/pi/.electron-gyp/6.1.7/include/node/node_object_wrap.h:84:78:   required from here
                                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                                        reinterpret_cast<Callback>(callback), type);
                                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                                        ../../../nan/nan_object_wrap.h:65:61:   required from here
                                        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                          SOLINK_MODULE(target) Release/obj.target/snowboy.node
                                        /usr/bin/ld: cannot find -lcblas
                                        collect2: error: ld returned 1 exit status
                                        make: *** [snowboy.target.mk:143: Release/obj.target/snowboy.node] Error 1
                                        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                                        gyp ERR! build error
                                        gyp ERR! stack Error: `make` failed with exit code: 2
                                        gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:194:23)
                                        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                                        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                                        gyp ERR! System Linux 5.4.35-v7l+
                                        gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm" "--remote_path=./snowboy/v1.4.7/Release/" "--package_name=snowboy-v1.4.7-electron-v6.1-linux-arm.tar.gz" "--host=https://github.com/bugsounet/snowboy"
                                        gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
                                        gyp ERR! node -v v10.20.1
                                        gyp ERR! node-gyp -v v6.1.0
                                        gyp ERR! not ok
                                        Failed with exit code: 1
                                        Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                                        gyp ERR! not ok
                                            at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:267:84)
                                            at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:205:16)
                                            at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:156:26)
                                            at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                                            at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                                            at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                                            at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                                            at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:242:65)
                                            at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:143:22)
                                        > @bugsounet/snowboy@1.4.7 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
                                        > tsc -p tsconfig.json
                                        + @bugsounet/snowboy@1.4.7
                                        added 20 packages from 25 contributors and audited 315 packages in 38.481s
                                        3 packages are looking for funding
                                          run `npm fund` for details
                                        found 6 low severity vulnerabilities
                                          run `npm audit fix` to fix them, or `npm audit` for details
                                        @bugsounet/snowboy library installed
                                          A Former User
                                          @jimmydew said in MMM-AssistantMk2 (v3):
                                          Linux 5.4.35-v7l+
                                          ah …
                                          and what version of gcc do you use ?
                                          try gcc --version in console
                                            jimmydew @Guest
                                            @Bugsounet
                                            pi@raspberrypi:~/MagicMirror $ gcc --version
                                            gcc (Raspbian 7.3.0-19) 7.3.0
                                            Copyright (C) 2017 Free Software Foundation, Inc.
                                            This is free software; see the source for copying conditions.  There is NO
                                            warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                                            • 4 / 7
