    updated installer script available for testing
    211 Posts 18 Posters 330.9k Views 19 Watching
      sdetweil @Neebotol
      @Neebotol is MM working ok now?
      • N
        Neebotol @sdetweil
        @sdetweil Hello! thank you for the way you’re helping people in this project.
        I just solved the problem tonight after more than 20 hours on it! It was really stupid, I used another SD card and it just worked. (I don’t understand too much because the SD card I was using until now was of good quality)
        Have a good day!
          sdetweil @Neebotol
          @Neebotol great work!! Yeh, having a bad card will.make things very challenging.
          Thanks for the feedback
          • N
            NathTheDude @sdetweil
            Hey @sdetweil,
            Forgot I did not get back to you. After much testing it was not feasible to use an rpi zero. Actually the ram/memory was ok, the main limitation was the cpu.
            I was using htop to monitor this during boot and normal usage, is was constantly at 100%. This caused really slow boot time and could not load the modules fully even if left for several hours.
            As soon as I went back to my rpi3 with the same modules it started very quick in comparison with no boot issues.
              sdetweil @NathTheDude
              @NathTheDude thank you for the feedback. Yes Pi 0 is really limited in what it can do.
                @NathTheDude using the new run-start.sh which launches chrome to connect to the MM serverOnly instance… I see 45% usage in htop for the initial config.
                electron has become unavailable for armv6l and node >8, so we’ve had to go split mode
                  PinkPumpkin
                  Do anyone know if the link bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)” can be found elsewhere?
                  It worked great on Raspberry Pi (1) but now it’s 404:-/
                    sdetweil @PinkPumpkin
                    @PinkPumpkin the scripts were moved to
                    As they were removed from the last release
                    This was also corrected on the 1st post of this topic.
                      PinkPumpkin
                      Thanks alot;-)
                      Sowwy I didn’t see that…
                        @PinkPumpkin no problem!.. its hard to keep stuff up to date here… lots of folks use 3 year old ‘cookbooks’, that no longer work…
                        • StoffbeuteluweS
                          Stoffbeuteluwe Project Sponsor @sdetweil
                          @sdetweil Hi, when I install your MM installer script on my Mac, does it install pm2 automatically.
                            sdetweil @Stoffbeuteluwe
                            @Stoffbeuteluwe it will if u select yes when prompted
                            • StoffbeuteluweS
                              @sdetweil oh thanks :grinning_face:
                                @Stoffbeuteluwe if you didn’t do it during the install, u can do it later with the fixuppm2 script from my site
                                StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                • StoffbeuteluweS
                                  @sdetweil ok sam…thanks for all your work
                                  • StoffbeuteluweS
                                    @sdetweil do you know what I am doing wrong?
                                                           \______/
                                    \e[0m
                                    install log being saved to /Users/patrickhahn/install.log
                                    this appears not to be a Raspberry Pi 2 or 3, do you want to continue installation (y/N)?y
                                    \e[96mCheck current Node installation ...\e[0m
                                    \e[0mNode currently installed. Checking version number.
                                    \e[0mMinimum Node version: \e[1mv10.1.0\e[0m
                                    \e[0mInstalled Node version: \e[1mv12.16.3\e[0m
                                    \e[92mNo Node.js upgrade necessary.\e[0m
                                    \e[96mCheck current NPM installation ...\e[0m
                                    \e[0mNPM currently installed. Checking version number.
                                    \e[0mMinimum npm version: \e[1mV6.0.0\e[0m
                                    \e[0mInstalled npm version: \e[1mV6.14.4\e[0m
                                    \e[92mNo npm upgrade necessary.\e[0m
                                    \e[96mCloning MagicMirror ...\e[90m
                                    Cloning into 'MagicMirror'...
                                    remote: Enumerating objects: 316, done.
                                    remote: Counting objects: 100% (316/316), done.
                                    remote: Compressing objects: 100% (276/276), done.
                                    remote: Total 316 (delta 43), reused 178 (delta 27), pack-reused 0
                                    Receiving objects: 100% (316/316), 437.95 KiB | 1.48 MiB/s, done.
                                    Resolving deltas: 100% (43/43), done.
                                    \e[92mCloning MagicMirror Done!\e[90m
                                    \e[96mInstalling dependencies ...\e[90m
                                    npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                    npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead
                                    npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
                                    npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
                                    npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
                                    npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                                    npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
                                    npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
                                    In file included from ../fsevents.cc:6:
                                    In file included from ../../nan/nan.h:222:
                                    In file included from ../../nan/nan_converters.h:67:
                                    ../../nan/nan_converters_43_inl.h:22:1: warning: 'ToBoolean' is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
                                    X(Boolean)
                                    ../../nan/nan_converters_43_inl.h:18:12: note: expanded from macro 'X'
                                         val->To ## TYPE(isolate->GetCurrentContext())                            \
                                    <scratch space>:207:1: note: expanded from here
                                    ToBoolean
                                    /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:2663:3: note: 'ToBoolean' has been explicitly marked deprecated here
                                     V8_DEPRECATED("ToBoolean can never throw. Use Local version.",
                                    /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8config.h:328:29: note: expanded from macro 'V8_DEPRECATED'
                                     declarator __attribute__((deprecated(message)))
                                    ../../nan/nan_converters_43_inl.h:40:1: warning: 'BooleanValue' is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
                                    X(bool, Boolean)
                                    ../../nan/nan_converters_43_inl.h:37:15: note: expanded from macro 'X'
                                     return val->NAME ## Value(isolate->GetCurrentContext());                     \
                                    <scratch space>:214:1: note: expanded from here
                                    BooleanValue
                                    /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:2701:3: note: 'BooleanValue' has been explicitly marked deprecated here
                                     V8_DEPRECATED("BooleanValue can never throw. Use Isolate version.",
                                    In file included from ../../nan/nan.h:223:
                                    In file included from ../../nan/nan_new.h:189:
                                    ../../nan/nan_implementation_12_inl.h:356:37: error: too few arguments to function call, expected 2, have 1
                                     return v8::StringObject::New(value).As<v8::StringObject>();
                                    /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:5531:3: note: 'New' declared here
                                     static Local<Value> New(Isolate* isolate, Local<String> value);
                                    In file included from ../../nan/nan.h:2722:
                                    ../../nan/nan_object_wrap.h:24:25: error: no member named 'IsNearDeath' in 'Nan::Persistent<v8::Object, v8::NonCopyablePersistentTraits<v8::Object> >'
                                       assert(persistent().IsNearDeath());
                                    /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/assert.h:93:25: note: expanded from macro 'assert'
                                       (__builtin_expect(!(e), 0) ? __assert_rtn(__func__, __FILE__, __LINE__, #e) : (void)0)
                                    ../../nan/nan_object_wrap.h:127:26: error: no member named 'IsNearDeath' in 'Nan::Persistent<v8::Object, v8::NonCopyablePersistentTraits<v8::Object> >'
                                       assert(wrap->handle_.IsNearDeath());
                                    ../fsevents.cc:50:32: error: no template named 'Handle' in namespace 'v8'
                                       static void Initialize(v8::Handle<v8::Object> exports);
                                    ../fsevents.cc:63:6: warning: field 'async_resource' will be initialized after field 'lockStarted' [-Wreorder]
                                      : async_resource("fsevents:FSEvents"), lockStarted(false) {
                                    In file included from ../fsevents.cc:82:
                                    ../src/constants.cc:89:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagNone").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagNone));
                                    /Users/patrickhahn/Library/Caches/node-gyp/12.16.3/include/node/v8.h:3498:3: note: 'Set' has been explicitly marked deprecated here
                                     V8_DEPRECATED("Use maybe version",
                                    ../src/constants.cc:90:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagMustScanSubDirs").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagMustScanSubDirs));
                                    ../src/constants.cc:91:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagUserDropped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagUserDropped));
                                    ../src/constants.cc:92:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagKernelDropped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagKernelDropped));
                                    ../src/constants.cc:93:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagEventIdsWrapped").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagEventIdsWrapped));
                                    ../src/constants.cc:94:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagHistoryDone").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagHistoryDone));
                                    ../src/constants.cc:95:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagRootChanged").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagRootChanged));
                                    ../src/constants.cc:96:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagMount").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagMount));
                                    ../src/constants.cc:97:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagUnmount").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagUnmount));
                                    ../src/constants.cc:98:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemCreated").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemCreated));
                                    ../src/constants.cc:99:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemRemoved").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemRemoved));
                                    ../src/constants.cc:100:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemInodeMetaMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemInodeMetaMod));
                                    ../src/constants.cc:101:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemRenamed").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemRenamed));
                                    ../src/constants.cc:102:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemModified").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemModified));
                                    ../src/constants.cc:103:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemFinderInfoMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemFinderInfoMod));
                                    ../src/constants.cc:104:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemChangeOwner").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemChangeOwner));
                                    ../src/constants.cc:105:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemXattrMod").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemXattrMod));
                                    ../src/constants.cc:106:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsFile").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsFile));
                                    ../src/constants.cc:107:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsDir").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsDir));
                                    ../src/constants.cc:108:11: warning: 'Set' is deprecated: Use maybe version [-Wdeprecated-declarations]
                                     object->Set(Nan::New<v8::String>("kFSEventStreamEventFlagItemIsSymlink").ToLocalChecked(), Nan::New<v8::Integer>(kFSEventStreamEventFlagItemIsSymlink));
                                    ../fsevents.cc:85:16: error: variable has incomplete type 'void'
                                    void FSEvents::Initialize(v8::Handle<v8::Object> exports) {
                                    ../fsevents.cc:85:31: error: no member named 'Handle' in namespace 'v8'
                                    ../fsevents.cc:85:48: error: expected '(' for function-style cast or type construction
                                    ../fsevents.cc:85:50: error: use of undeclared identifier 'exports'
                                    ../fsevents.cc:85:58: error: expected ';' after top level declarator
                                    23 warnings and 9 errors generated.
                                    make: *** [Release/obj.target/fse/fsevents.o] Error 1
                                    gyp ERR! build error
                                    gyp ERR! stack Error: `make` failed with exit code: 2
                                    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                    gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                                    gyp ERR! System Darwin 19.4.0
                                    gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64/fse.node" "--module_name=fse" "--module_path=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64" "--napi_version=5" "--node_abi_napi=napi"
                                    gyp ERR! cwd /Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents
                                    gyp ERR! node -v v12.16.3
                                    gyp ERR! node-gyp -v v5.1.0
                                    gyp ERR! not ok
                                    node-pre-gyp ERR! build error
                                    node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64/fse.node --module_name=fse --module_path=/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/lib/binding/Release/node-v72-darwin-x64 --napi_version=5 --node_abi_napi=napi' (1)
                                    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:310:20)
                                    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)
                                    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
                                    node-pre-gyp ERR! System Darwin 19.4.0
                                    node-pre-gyp ERR! command "/usr/local/bin/node" "/Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents/node_modules/node-pre-gyp/bin/node-pre-gyp" "install" "--fallback-to-build"
                                    node-pre-gyp ERR! cwd /Users/patrickhahn/MagicMirror/vendor/node_modules/fsevents
                                    node-pre-gyp ERR! node -v v12.16.3
                                    node-pre-gyp ERR! node-pre-gyp -v v0.10.0
                                    node-pre-gyp ERR! not ok
                                    npm notice created a lockfile as package-lock.json. You should commit this file.
                                    \e[92mDependencies installation Done!\e[90m
                                    setting up initial config.js
                                    \e[96mCheck plymouth installation ...\e[0m
                                    \e[93mplymouth is not installed.\e[0m
                                    Do you want use pm2 for auto starting of your MagicMirror (y/N)?n
                                    Do you want to disable the screen saver? (y/N)?n
                                    \e[92mWe're ready! Run \e[1m\e[97mDISPLAY=:0 npm start\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m
                                    patrickhahn@Patricks-Mini ~ %
                                      @Stoffbeuteluwe so much fun…
                                      I put in a fix
                                      remove the MagicMirror folder and try again…
                                      I had not tried installer on mac since 2.10… sorry…
                                      • StoffbeuteluweS
                                        @sdetweil MM install was without problems thank you…
                                        but pm2 say error but it works…
                                        Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                                        install and setup pm2
                                        Password:
                                        [PM2][ERROR] Init system not found
                                        /bin/sh: launchctl: command not found
                                        [PM2][ERROR] launchctl load -w /Users/patrickhahn/Library/LaunchAgents/pm2.patrickhahn.plist failed, see error above.
                                        [PM2] Spawning PM2 daemon with pm2_home=/Users/patrickhahn/.pm2
                                        [PM2] PM2 Successfully daemonized
                                        [PM2][WARN] Applications MagicMirror not running, starting...
                                        [PM2] App [MagicMirror] launched (1 instances)
                                        │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                                        │ 0   │ MagicMirror    │ default     │ 2.11.0  │ fork    │ 4867     │ 0s     │ 0    │ online    │ 0%       │ 1.0mb    │ pat… │ enabled  │
                                        [PM2] Saving current process list...
                                        [PM2] Successfully saved in /Users/patrickhahn/.pm2/dump.pm2
                                        Do you want to disable the screen saver? (y/N)?y
                                        2020-05-22 14:37:06.275 defaults[5057:87330]
                                        The domain/default pair of (com.apple.screensaver, idleTime) does not exist
                                        bash: line 537: [: !=: unary operator expected
                                        \e[92mWe're ready! Run \e[1m\e[97mpm2 start MagicMirror\e[0m\e[92m from the ~/MagicMirror directory to start your MagicMirror.\e[0m
                                        patrickhahn@Mac-mini ~ %
                                          @Stoffbeuteluwe ok, on the screensaver can u show the results of this
                                          defaults -currentHost read com.apple.screensaver
                                          thanks… working on the pm2 issue
                                          what os level are u running on the mini?
                                          • StoffbeuteluweS
                                            version10.15.4 (19E287)
                                            • 10
                                            • 11
                                            • 10 / 11
