    updated installer script available for testing
    211 Posts 18 Posters 337.3k Views 19 Watching
      sdetweil @bhepler
      @bhepler could you retest the installer? just rename your current MagicMirror folder out of the way… thanks
      course u have pm2 already … never mind
      bheplerB 1 Reply Last reply
      • bheplerB
        bhepler Module Developer @sdetweil
        @sdetweil - No worries. I have a spare Pi and a SD card I can use. I’ll get it cranked out tonight. I’ll get you that info.
          sdetweil @bhepler
          @bhepler thanks… i got some new sd cards today, so I will test too.
          • bheplerB
            @sdetweil - Brand new Buster installation on a RPi 3B+. Installation script worked as expected.
            I had trouble with pm2 on my existing mirror too. I ended up upgrading to the latest pm2 in order to get it to remember to start on boot.
            At this point, I think your script is handling it properly. Thanks for the quick replies!
              sdetweil @bhepler
              @bhepler oh, there is a script for just pm2 as well.
              Thx for feedback.
              • N
                NathTheDude
                Hey sam (@sdetweil ),
                Thanks for this, made my life a lot easier.
                So, I just did a new build with Buster on a RPI Zero W. All looked good and I have configured mm2 to start on reboot of the Pi. I am start/stop/restart and check the status of mm2 and is looks to be working, the mm2 logs are also good with no error logs.
                The problem I am facing is that the magicMirror page via chromium seems to try and load (white screen which changes to a pure black screen) however seems to fail/crash and go back to the Raspbian desktop.
                This happens when I reboot the pi and also when I manually try to start/restart the mm2 service.
                Anything you think I am missing?
                  sdetweil @NathTheDude
                  @NathTheDude if u start the chromium browser from the desktop does it work?
                    U may need to increase the swap space. Pi 0 has very little memory.
                    https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
                    • N
                      NathTheDude
                      Thanks @sdetweil , after a couple of reboots this is now working as expected. Not sure what the issue was, I will have to keep an eye on it. Thanks for the link on swap space, I will also look in that direction if I have any more of the same issues.
                        @NathTheDude ok… let me know if there are any other issues…
                        S N 2 Replies Last reply
                          @sdetweil this installer script is now the script in 2.10…
                          I will close/lock this topic in a couple days
                            jorgnyg
                            Should I install electron with --arch=armv7l ?
                            J 1 Reply Last reply
                              jorgnyg @jorgnyg
                              @jorgnyg Yea guess so. Installation fails on rpi zero. So I deleted the electron folder from node_modules, and ran npm install --arch=armv7l electron@3.0.13
                                sdetweil @jorgnyg
                                @jorgnyg doesn’t fail on my pi 0.
                                Can u send me the install.log
                                S J 2 Replies Last reply
                                  @sdetweil note that we made electron optional. There is no armv6l at node 10
                                  So we will run in split mode use chromium
                                    jorgnyg @sdetweil
                                    @sdetweil sure thing. Guess this is the most relevant error
                                    26380 verbose stack Error: electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                                    26380 verbose stack Exit status 1
                                    26380 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                    26380 verbose stack     at EventEmitter.emit (events.js:198:13)
                                    26380 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                    26380 verbose stack     at ChildProcess.emit (events.js:198:13)
                                    26380 verbose stack     at maybeClose (internal/child_process.js:982:16)
                                    26380 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                    26381 verbose pkgid electron-chromedriver@1.8.0
                                    26382 verbose cwd /home/pi/MagicMirror
                                    26383 verbose Linux 4.19.75+
                                    26384 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                    26385 verbose node v10.18.1
                                    26386 verbose npm  v6.13.4
                                    26387 error code ELIFECYCLE
                                    26388 error errno 1
                                    26389 error electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                                    26389 error Exit status 1
                                    26390 error Failed at the electron-chromedriver@1.8.0 install script.
                                    26390 error This is probably not a problem with npm. There is likely additional logging output above.
                                    26391 verbose exit [ 1, true ]
                                      sdetweil @jorgnyg
                                      @jorgnyg the run-start.sh script now handles this problem and launches chromium instead of electron to connect to mm in serveronly mode
                                        jorgnyg @sdetweil
                                        @sdetweil got it!
                                          jthirasilpa
                                          Hi - firstly thanks for putting together this installer!
                                          I am running Raspbian on RP3b+ as a fresh install using the command
                                          curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
                                          Installer indicated successful install of MagicMirror.
                                          Using SSH DISPLAY=:0 npm start gives the following error:
                                          magicmirror@2.10.1 start /home/jojo/MagicMirror
                                          ./run-start.sh
                                          No protocol specified
                                          (electron:17801): Gtk-WARNING **: 18:36:26.218: cannot open display: :0
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the magicmirror@2.10.1 start script.
                                          npm ERR! /home/jojo/.npm/_logs/2020-01-25T18_36_26_308Z-debug.log
                                          Debug log contents are as follows:
                                          1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                                          2 info using npm@6.13.4
                                          3 info using node@v10.18.1
                                          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                                          5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                                          6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                                          7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                                          8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/jojo/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                          9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/jojo/MagicMirror
                                          10 silly lifecycle magicmirror@2.10.1~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
                                          11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1 signal: null
                                          12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                                          13 verbose stack Error: magicmirror@2.10.1 start: ./run-start.sh
                                          13 verbose stack Exit status 1
                                          13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                          13 verbose stack at EventEmitter.emit (events.js:198:13)
                                          13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                          13 verbose stack at ChildProcess.emit (events.js:198:13)
                                          13 verbose stack at maybeClose (internal/child_process.js:982:16)
                                          13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                          14 verbose pkgid magicmirror@2.10.1
                                          15 verbose cwd /home/jojo/MagicMirror
                                          16 verbose Linux 4.19.75-v7+
                                          17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
                                          18 verbose node v10.18.1
                                          19 verbose npm v6.13.4
                                          20 error code ELIFECYCLE
                                          21 error errno 1
                                          22 error magicmirror@2.10.1 start: ./run-start.sh
                                          22 error Exit status 1
                                          23 error Failed at the magicmirror@2.10.1 start script.
                                          23 error This is probably not a problem with npm. There is likely additional logging output above.
                                          24 verbose exit [ 1, true ]
                                          Any thoughts on how to troubleshoot? Many thanks.
                                            sdetweil @jthirasilpa
                                            @jthirasilpa seems like you are running in console mode, instead of graphical mode.
                                            Mm requires the full desktop.
                                            • 10
                                            • 11
                                            • 8 / 11
