    updated installer script available for testing
    211 Posts 18 Posters 337.2k Views 19 Watching
      sdetweil @NathTheDude
      @NathTheDude if u start the chromium browser from the desktop does it work?
        U may need to increase the swap space. Pi 0 has very little memory.
        https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
        • N
          NathTheDude
          Thanks @sdetweil , after a couple of reboots this is now working as expected. Not sure what the issue was, I will have to keep an eye on it. Thanks for the link on swap space, I will also look in that direction if I have any more of the same issues.
            @NathTheDude ok… let me know if there are any other issues…
            S N 2 Replies Last reply
              @sdetweil this installer script is now the script in 2.10…
              I will close/lock this topic in a couple days
                jorgnyg
                Should I install electron with --arch=armv7l ?
                J 1 Reply Last reply
                  jorgnyg @jorgnyg
                  @jorgnyg Yea guess so. Installation fails on rpi zero. So I deleted the electron folder from node_modules, and ran npm install --arch=armv7l electron@3.0.13
                    sdetweil @jorgnyg
                    @jorgnyg doesn’t fail on my pi 0.
                    Can u send me the install.log
                    S J 2 Replies Last reply
                      @sdetweil note that we made electron optional. There is no armv6l at node 10
                      So we will run in split mode use chromium
                        jorgnyg @sdetweil
                        @sdetweil sure thing. Guess this is the most relevant error
                        26380 verbose stack Error: electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                        26380 verbose stack Exit status 1
                        26380 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                        26380 verbose stack     at EventEmitter.emit (events.js:198:13)
                        26380 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                        26380 verbose stack     at ChildProcess.emit (events.js:198:13)
                        26380 verbose stack     at maybeClose (internal/child_process.js:982:16)
                        26380 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                        26381 verbose pkgid electron-chromedriver@1.8.0
                        26382 verbose cwd /home/pi/MagicMirror
                        26383 verbose Linux 4.19.75+
                        26384 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                        26385 verbose node v10.18.1
                        26386 verbose npm  v6.13.4
                        26387 error code ELIFECYCLE
                        26388 error errno 1
                        26389 error electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                        26389 error Exit status 1
                        26390 error Failed at the electron-chromedriver@1.8.0 install script.
                        26390 error This is probably not a problem with npm. There is likely additional logging output above.
                        26391 verbose exit [ 1, true ]
                          sdetweil @jorgnyg
                          @jorgnyg the run-start.sh script now handles this problem and launches chromium instead of electron to connect to mm in serveronly mode
                            jorgnyg @sdetweil
                            @sdetweil got it!
                              jthirasilpa
                              Hi - firstly thanks for putting together this installer!
                              I am running Raspbian on RP3b+ as a fresh install using the command
                              curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
                              Installer indicated successful install of MagicMirror.
                              Using SSH DISPLAY=:0 npm start gives the following error:
                              magicmirror@2.10.1 start /home/jojo/MagicMirror
                              ./run-start.sh
                              No protocol specified
                              (electron:17801): Gtk-WARNING **: 18:36:26.218: cannot open display: :0
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno 1
                              npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                              npm ERR! Exit status 1
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.10.1 start script.
                              npm ERR! /home/jojo/.npm/_logs/2020-01-25T18_36_26_308Z-debug.log
                              Debug log contents are as follows:
                              1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                              2 info using npm@6.13.4
                              3 info using node@v10.18.1
                              4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                              5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                              6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                              7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                              8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/jojo/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                              9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/jojo/MagicMirror
                              10 silly lifecycle magicmirror@2.10.1~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
                              11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1 signal: null
                              12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                              13 verbose stack Error: magicmirror@2.10.1 start: ./run-start.sh
                              13 verbose stack Exit status 1
                              13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                              13 verbose stack at EventEmitter.emit (events.js:198:13)
                              13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                              13 verbose stack at ChildProcess.emit (events.js:198:13)
                              13 verbose stack at maybeClose (internal/child_process.js:982:16)
                              13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                              14 verbose pkgid magicmirror@2.10.1
                              15 verbose cwd /home/jojo/MagicMirror
                              16 verbose Linux 4.19.75-v7+
                              17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
                              18 verbose node v10.18.1
                              19 verbose npm v6.13.4
                              20 error code ELIFECYCLE
                              21 error errno 1
                              22 error magicmirror@2.10.1 start: ./run-start.sh
                              22 error Exit status 1
                              23 error Failed at the magicmirror@2.10.1 start script.
                              23 error This is probably not a problem with npm. There is likely additional logging output above.
                              24 verbose exit [ 1, true ]
                              Any thoughts on how to troubleshoot? Many thanks.
                                sdetweil @jthirasilpa
                                @jthirasilpa seems like you are running in console mode, instead of graphical mode.
                                Mm requires the full desktop.
                                  jthirasilpa @sdetweil
                                  @sdetweil Thanks. The RP is running a full desktop - if I run npm start directly from the RP, the debug log gives the following output:
                                  21 error errno 1
                                    @jthirasilpa change line 1 of run-start.sh to be
                                    #~/bin/bash -x
                                    then do the npm start again…
                                    also do
                                     which chromium-browser
                                    my system returns
                                    /usr/bin/chromium-browser
                                    can u send me the MagicMirror/installers/upgrade.log via email
                                    same userid as here, at gmail
                                    thanks
                                      @sdetweil sorry, typo on run-start
                                      #!/bin/bash -x
                                      • N
                                        Neebotol
                                        Hello there!
                                        Thank you for this script, it has worked better than the original one for me. But I still really unlucky and have an issue.
                                        Here it is :
                                        pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirr  or_scripts/master/raspberry.sh | bash
                                        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                          $$  __$$\
                                        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$  $\   $$$$$$\   $$$$$$\  \__/  $$ |
                                        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __  $$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |    \__|$$ /  $$ |$$ |  \__|$$  ____/
                                        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |        $$ |  $$ |$$ |      $$ |
                                        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |        \$$$$$$  |$$ |      $$$$$$$$\
                                        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|         \______/ \__|      \________|
        \______/
                                        install log being saved to /home/pi/install.log
                                        Updating packages ...
                                        Installing helper tools ...
                                        Lecture des listes de paquets... Fait
                                        Construction de l'arbre des dépendances
                                        Lecture des informations d'état... Fait
                                        build-essential est déjà la version la plus récente (12.6).
                                        curl est déjà la version la plus récente (7.64.0-4).
                                        unzip est déjà la version la plus récente (6.0-23+deb10u1).
                                        wget est déjà la version la plus récente (1.20.1-1.1).
                                        wget passé en « installé manuellement ».
                                        Paquets suggérés :
                                          git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitwe
                                        Les paquets suivants seront mis à jour :
                                          git
                                        1 mis à jour, 0 nouvellement installés, 0 à enlever et 166 non mis à jour.
                                        Il est nécessaire de prendre 4 203 ko dans les archives.
                                        Après cette opération, 33,8 ko d'espace disque supplémentaires seront utilisés.
                                        Réception de :1 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf gi
                                        4 203 ko réceptionnés en 2s (2 281 ko/s)
                                        apt-listchanges : Lecture des fichiers de modifications (« changelog »)...
                                        (Lecture de la base de données... 93835 fichiers et répertoires déjà installés.)
                                        Préparation du dépaquetage de .../git_1%3a2.20.1-2+deb10u1_armhf.deb ...
                                        Dépaquetage de git (1:2.20.1-2+deb10u1) sur (1:2.20.1-2) ...
                                        Paramétrage de git (1:2.20.1-2+deb10u1) ...
                                        Node.js is not installed.
                                        Installing Node.js ...
                                        Warning: apt-key output should not be parsed (stdout is not a terminal)
                                        Les NOUVEAUX paquets suivants seront installés :
                                          nodejs
                                        0 mis à jour, 1 nouvellement installés, 0 à enlever et 166 non mis à jour.
                                        Il est nécessaire de prendre 14,6 Mo dans les archives.
                                        Après cette opération, 77,3 Mo d'espace disque supplémentaires seront utilisés.
                                        Réception de :1 https://deb.nodesource.com/node_10.x buster/main armhf nodejs armhf 10.18.1-1nodesource1 [14,6 MB]
                                        14,6 Mo réceptionnés en 11s (1 365 ko/s)
                                        Sélection du paquet nodejs précédemment désélectionné.
                                        (Lecture de la base de données... 93842 fichiers et répertoires déjà installés.)
                                        Préparation du dépaquetage de .../nodejs_10.18.1-1nodesource1_armhf.deb ...
                                        Dépaquetage de nodejs (10.18.1-1nodesource1) ...
                                        Paramétrage de nodejs (10.18.1-1nodesource1) ...
                                        Traitement des actions différées (« triggers ») pour man-db (2.8.5-2) ...
                                        node version is
                                        Node.js installation Done! version=v10.18.1
                                        internal/modules/cjs/loader.js:638
                                            throw err;
                                        Error: Cannot find module 'rimraf'
                                            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                            at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                            at Module.require (internal/modules/cjs/loader.js:692:17)
                                            at require (internal/modules/cjs/helpers.js:25:18)
                                            at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-vacuum/vacuum.js:6:14)
                                        Minimum npm version: V6.0.0
                                        Installed npm version: V
                                        npm should be upgraded.
                                        Installing npm ...
                                        E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
                                            throw err;
                                            throw err;
                                        npm installation Done! version=V
                                        Cloning MagicMirror ...
                                        Clonage dans 'MagicMirror'...
                                        remote: Enumerating objects: 331, done.
                                        remote: Counting objects: 100% (331/331), done.
                                        remote: Compressing objects: 100% (295/295), done.
                                        remote: Total 331 (delta 42), reused 193 (delta 23), pack-reused 0
                                        Réception d'objets: 100% (331/331), 676.44 KiB | 1.57 MiB/s, fait.
                                        Résolution des deltas: 100% (42/42), fait.
                                        Cloning MagicMirror Done!
                                        Installing dependencies ...
                                            throw err;
                                        Unable to install dependencies!
                                        Any idea please? Honnestly I have spent so much time on this project, all my past weekend and some hours in the week. I tried many things, with several tutorials, raspian stretch, buster… I’m a little desperate, but I’m not giving up!
                                        S Mykle1M 2 Replies Last reply
                                          sdetweil @Neebotol
                                          @Neebotol looks like npm is not able to run after the node upgrade…
                                          do this
                                          rm -rf MagicMirror
                                          npm clean cache
                                          then start the installer script again
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Neebotol
                                            @Neebotol said in updated installer script available for testing:
                                            We’ve all been there.
                                            :thumbsup:
                                            N 1 Reply Last reply
                                            • 10
                                            • 11
                                            • 9 / 11
