    updated installer script available for testing
    211 Posts 18 Posters 330.9k Views 19 Watching
      bhepler Module Developer @sdetweil
      @sdetweil - I pulled this from the official GitHub page: sudo npm install -g pm2. Once I ran that, I just changed to the ~/MagicMirrors/installers folder and told pm2 to run/maintain it: pm2 start mm.sh
        sdetweil @bhepler
        @bhepler weird… that is that the script does between the two log entries
        	echo pm2 not installed, installing >>$logfile
        	result=$(npm install $up -g pm2)
        	echo pm2 install result $result >>$logfile
        $up is for the mac
        bet it needed sudo…
          @bhepler
          I also added to catch the stderr output to the log too
          	result=$(sudo npm install $up -g pm2 2>&1)
            sdetweil @bhepler
            @bhepler could you retest the installer? just rename your current MagicMirror folder out of the way… thanks
            course u have pm2 already … never mind
              @sdetweil - No worries. I have a spare Pi and a SD card I can use. I’ll get it cranked out tonight. I’ll get you that info.
                sdetweil @bhepler
                @bhepler thanks… i got some new sd cards today, so I will test too.
                  @sdetweil - Brand new Buster installation on a RPi 3B+. Installation script worked as expected.
                  I had trouble with pm2 on my existing mirror too. I ended up upgrading to the latest pm2 in order to get it to remember to start on boot.
                  At this point, I think your script is handling it properly. Thanks for the quick replies!
                    sdetweil @bhepler
                    @bhepler oh, there is a script for just pm2 as well.
                    Thx for feedback.
                    • N
                      NathTheDude
                      Hey sam (@sdetweil ),
                      Thanks for this, made my life a lot easier.
                      So, I just did a new build with Buster on a RPI Zero W. All looked good and I have configured mm2 to start on reboot of the Pi. I am start/stop/restart and check the status of mm2 and is looks to be working, the mm2 logs are also good with no error logs.
                      The problem I am facing is that the magicMirror page via chromium seems to try and load (white screen which changes to a pure black screen) however seems to fail/crash and go back to the Raspbian desktop.
                      This happens when I reboot the pi and also when I manually try to start/restart the mm2 service.
                      Anything you think I am missing?
                        sdetweil @NathTheDude
                        @NathTheDude if u start the chromium browser from the desktop does it work?
                          U may need to increase the swap space. Pi 0 has very little memory.
                          https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
                          • N
                            NathTheDude
                            Thanks @sdetweil , after a couple of reboots this is now working as expected. Not sure what the issue was, I will have to keep an eye on it. Thanks for the link on swap space, I will also look in that direction if I have any more of the same issues.
                              @NathTheDude ok… let me know if there are any other issues…
                              S N 2 Replies Last reply Reply Quote 0
                                @sdetweil this installer script is now the script in 2.10…
                                I will close/lock this topic in a couple days
                                  jorgnyg
                                  Should I install electron with --arch=armv7l ?
                                    jorgnyg @jorgnyg
                                    @jorgnyg Yea guess so. Installation fails on rpi zero. So I deleted the electron folder from node_modules, and ran npm install --arch=armv7l electron@3.0.13
                                      sdetweil @jorgnyg
                                      @jorgnyg doesn’t fail on my pi 0.
                                      Can u send me the install.log
                                      S J 2 Replies Last reply Reply Quote 0
                                        @sdetweil note that we made electron optional. There is no armv6l at node 10
                                        So we will run in split mode use chromium
                                          jorgnyg @sdetweil
                                          @sdetweil sure thing. Guess this is the most relevant error
                                          26380 verbose stack Error: electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                                          26380 verbose stack Exit status 1
                                          26380 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                                          26380 verbose stack     at EventEmitter.emit (events.js:198:13)
                                          26380 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                          26380 verbose stack     at ChildProcess.emit (events.js:198:13)
                                          26380 verbose stack     at maybeClose (internal/child_process.js:982:16)
                                          26380 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                                          26381 verbose pkgid electron-chromedriver@1.8.0
                                          26382 verbose cwd /home/pi/MagicMirror
                                          26383 verbose Linux 4.19.75+
                                          26384 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                          26385 verbose node v10.18.1
                                          26386 verbose npm  v6.13.4
                                          26387 error code ELIFECYCLE
                                          26388 error errno 1
                                          26389 error electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
                                          26389 error Exit status 1
                                          26390 error Failed at the electron-chromedriver@1.8.0 install script.
                                          26390 error This is probably not a problem with npm. There is likely additional logging output above.
                                          26391 verbose exit [ 1, true ]
                                            sdetweil @jorgnyg
                                            @jorgnyg the run-start.sh script now handles this problem and launches chromium instead of electron to connect to mm in serveronly mode
                                            • 10
                                            • 11
                                            • 8 / 11
