    updated installer script available for testing
    211 Posts 18 Posters 319.7k Views 19 Watching
      sdetweil @bhepler
      @bhepler hang on, I’ll be back home in a few minutes.
      Can u do
      pm2 startup
        bhepler Module Developer @sdetweil
        @sdetweil I already went through the installation procedure to get pm2 installed. That required the npm command to install pm2.
        After the initial script run, pm2 start MagicMirror returned a “bash: pm2: command not found” error. Once I got pm2 installed, getting the script monitored by pm2 was easy enough. At a guess, it’s a problem with using sudo to install pm2, but I’m afraid I don’t have the exact error message.
          sdetweil @bhepler
          @bhepler what did u have to do for the pm2 install?
            @sdetweil - I pulled this from the official GitHub page: sudo npm install -g pm2. Once I ran that, I just changed to the ~/MagicMirrors/installers folder and told pm2 to run/maintain it: pm2 start mm.sh
              sdetweil @bhepler
              @bhepler weird… that is that the script does between the two log entries
              	echo pm2 not installed, installing >>$logfile
              	result=$(npm install $up -g pm2)
              	echo pm2 install result $result >>$logfile
              $up is for the mac
              bet it needed sudo…
                @bhepler
                I also added to catch the stderr output to the log too
                	result=$(sudo npm install $up -g pm2 2>&1)
                  sdetweil @bhepler
                  @bhepler could you retest the installer? just rename your current MagicMirror folder out of the way… thanks
                  course u have pm2 already … never mind
                    @sdetweil - No worries. I have a spare Pi and a SD card I can use. I’ll get it cranked out tonight. I’ll get you that info.
                      sdetweil @bhepler
                      @bhepler thanks… i got some new sd cards today, so I will test too.
                        @sdetweil - Brand new Buster installation on a RPi 3B+. Installation script worked as expected.
                        I had trouble with pm2 on my existing mirror too. I ended up upgrading to the latest pm2 in order to get it to remember to start on boot.
                        At this point, I think your script is handling it properly. Thanks for the quick replies!
                          sdetweil @bhepler
                          @bhepler oh, there is a script for just pm2 as well.
                          Thx for feedback.
                          • N Offline
                            NathTheDude
                            Hey sam (@sdetweil ),
                            Thanks for this, made my life a lot easier.
                            So, I just did a new build with Buster on a RPI Zero W. All looked good and I have configured mm2 to start on reboot of the Pi. I am start/stop/restart and check the status of mm2 and is looks to be working, the mm2 logs are also good with no error logs.
                            The problem I am facing is that the magicMirror page via chromium seems to try and load (white screen which changes to a pure black screen) however seems to fail/crash and go back to the Raspbian desktop.
                            This happens when I reboot the pi and also when I manually try to start/restart the mm2 service.
                            Anything you think I am missing?
                              sdetweil @NathTheDude
                              @NathTheDude if u start the chromium browser from the desktop does it work?
                                U may need to increase the swap space. Pi 0 has very little memory.
                                https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
                                • N Offline
                                  NathTheDude
                                  Thanks @sdetweil , after a couple of reboots this is now working as expected. Not sure what the issue was, I will have to keep an eye on it. Thanks for the link on swap space, I will also look in that direction if I have any more of the same issues.
                                    @NathTheDude ok… let me know if there are any other issues…
                                    S N 2 Replies Last reply Reply Quote 0
                                      @sdetweil this installer script is now the script in 2.10…
                                      I will close/lock this topic in a couple days
                                        jorgnyg
                                        Should I install electron with --arch=armv7l ?
                                          jorgnyg @jorgnyg
                                          @jorgnyg Yea guess so. Installation fails on rpi zero. So I deleted the electron folder from node_modules, and ran npm install --arch=armv7l electron@3.0.13
                                            sdetweil @jorgnyg
                                            @jorgnyg doesn’t fail on my pi 0.
                                            Can u send me the install.log
                                            S J 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 8 / 11
