    updated installer script available for testing
    211 Posts 18 Posters 337.5k Views 19 Watching
    • swvalentiS
      swvalenti Project Sponsor @sdetweil
      pi@raspberrypi:~ $ pm2 status
      │ Name        │ id │ mode  │ status │ ↺       │ cpu │ memory │
      │ mm          │ 1  │ N/A   │ fork   │ stopped │ 176 │ 0%     │ 0 B       │
      │ omx_stream1 │ 2  │ N/A   │ fork   │ stopped │ 61  │ 0%     │ 0 B       │
      │ omx_stream2 │ 3  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
      │ omx_stream3 │ 4  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
      │ server      │ 0  │ 1.6.5 │ fork   │ online  │ 3   │ 0.4%   │ 40.0 MB   │
       Use `pm2 show <id|name>` to get more details about an app
      pi@raspberrypi:~ $
        sdetweil @swvalenti
        @swvalenti i would guess server
        pm2 stop server
        swvalentiS 1 Reply Last reply
        • swvalentiS
          @sdetweil Awesome that worked thanks Sam!
            sdetweil @swvalenti
            @swvalenti cool… maybe I should dump out the ps -ef list if I find that problem…
            • swvalentiS
              @sdetweil So I renamed the old magicmirror folder and updated. Now the updates stripped modules and config.js. They are not in the new magicmirror folder at all…what gives?
                sdetweil @swvalenti
                @swvalenti this is not an update, it is a NEW install…
                so you have to copy from the old mm folder to the new…
                if u wanted to UPDATE then u should run the UPDATE script
                https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                • swvalentiS
                  @sdetweil Well I am an idiot, so I can just delete the new MagicMirror folder and then run the update in the other?
                    sdetweil @swvalenti
                    @swvalenti yes… UPDATE just gets you the new MagicMirror version. currently 2.9.0
                    • swvalentiS
                      Thanks Sam
                      • bheplerB
                        bhepler Module Developer
                        Huh. I just tried it on a fresh Buster install on a RPI 3B+ and PM2 failed to install correctly. It seems to be a permissions issue.
                          sdetweil @bhepler
                          @bhepler show me the log please
                          ~/install.log
                          • bheplerB
                            It’s not terribly illuminating.
                            install and setup pm2
                            pm2 not installed, installing
                            pm2 install result
                            get the pm2 platform specific startup command
                            startup command =
                            pm2 startup command done
                            configure the pm2 config file for MagicMirror
                            start MagicMirror via pm2 now
                            save MagicMirror pm2 config now
                            disable screensaver via lxsession
                              sdetweil @bhepler
                              @bhepler hang on, I’ll be back home in a few minutes.
                              Can u do
                              pm2 startup
                              bheplerB 1 Reply Last reply
                              • bheplerB
                                bhepler Module Developer @sdetweil
                                @sdetweil I already went through the installation procedure to get pm2 installed. That required the npm command to install pm2.
                                After the initial script run, pm2 start MagicMirror returned a “bash: pm2: command not found” error. Once I got pm2 installed, getting the script monitored by pm2 was easy enough. At a guess, it’s a problem with using sudo to install pm2, but I’m afraid I don’t have the exact error message.
                                  sdetweil @bhepler
                                  @bhepler what did u have to do for the pm2 install?
                                  • bheplerB
                                    @sdetweil - I pulled this from the official GitHub page: sudo npm install -g pm2. Once I ran that, I just changed to the ~/MagicMirrors/installers folder and told pm2 to run/maintain it: pm2 start mm.sh
                                    S 2 Replies Last reply
                                      sdetweil @bhepler
                                      @bhepler weird… that is that the script does between the two log entries
                                      	echo pm2 not installed, installing >>$logfile
                                      	result=$(npm install $up -g pm2)
                                      	echo pm2 install result $result >>$logfile
                                      $up is for the mac
                                      bet it needed sudo…
                                        @bhepler
                                        I also added to catch the stderr output to the log too
                                        	result=$(sudo npm install $up -g pm2 2>&1)
                                          sdetweil @bhepler
                                          @bhepler could you retest the installer? just rename your current MagicMirror folder out of the way… thanks
                                          course u have pm2 already … never mind
                                          • bheplerB
                                            @sdetweil - No worries. I have a spare Pi and a SD card I can use. I’ll get it cranked out tonight. I’ll get you that info.
                                            • 10
                                            • 11
                                            • 8 / 11
