    updated installer script available for testing
    211 Posts 18 Posters 317.6k Views 19 Watching
      sdetweil @swvalenti
      @swvalenti said in Anyone want to try updated installer...:
      19082
      kill -9 19082
      • swvalentiS Offline
        swvalenti Project Sponsor
        Still won’t work did the kill command
        pi@raspberrypi:~ $ kill -9 19082
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        install log being saved to /home/pi/MagicMirror/installers/install.log
        No LSB modules are available.
        Updating packages ...
        Installing helper tools ...
        Reading package lists... Done
        Building dependency tree
        build-essential is already the newest version (12.3).
        curl is already the newest version (7.52.1-5+deb9u9).
        git is already the newest version (1:2.11.0-3+deb9u4).
        unzip is already the newest version (6.0-21+deb9u2).
        wget is already the newest version (1.18-5+deb9u3).
          coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
          libfile-which-perl libhttp-daemon-perl libhttp-date-perl
          libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
          libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
          librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
        Use 'sudo apt autoremove' to remove them.
        0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
        Minimum Node version: v10.1.0
        Installed Node version: v9.11.2
        Node should be upgraded.
        A Node process is currently running. Can't upgrade.
        Please quit all Node processes and restart the installer.
        pi@raspberrypi:~ $
        bash: kill: (19082) - No such process
        pi@raspberrypi:~ $
                                \______/
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $
          sdetweil @swvalenti
          @swvalenti looks like it gets restarted…
          again… you killed it before u ran installer
          ps -ef | grep node
          swvalentiS 1 Reply Last reply Reply Quote 0
            swvalenti Project Sponsor @sdetweil
            @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
              sdetweil @swvalenti
              @swvalenti yes, somehow… I don’t know how it got added…
              can u do a
              pm2 status
                pi@raspberrypi:~ $ pm2 status
                │ Name        │ id │ mode  │ status │ ↺       │ cpu │ memory │
                │ mm          │ 1  │ N/A   │ fork   │ stopped │ 176 │ 0%     │ 0 B       │
                │ omx_stream1 │ 2  │ N/A   │ fork   │ stopped │ 61  │ 0%     │ 0 B       │
                │ omx_stream2 │ 3  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                │ omx_stream3 │ 4  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                │ server      │ 0  │ 1.6.5 │ fork   │ online  │ 3   │ 0.4%   │ 40.0 MB   │
                 Use `pm2 show <id|name>` to get more details about an app
                pi@raspberrypi:~ $
                  sdetweil @swvalenti
                  @swvalenti i would guess server
                  pm2 stop server
                    @sdetweil Awesome that worked thanks Sam!
                      sdetweil @swvalenti
                      @swvalenti cool… maybe I should dump out the ps -ef list if I find that problem…
                        @sdetweil So I renamed the old magicmirror folder and updated. Now the updates stripped modules and config.js. They are not in the new magicmirror folder at all…what gives?
                          sdetweil @swvalenti
                          @swvalenti this is not an update, it is a NEW install…
                          so you have to copy from the old mm folder to the new…
                          if u wanted to UPDATE then u should run the UPDATE script
                          https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                            @sdetweil Well I am an idiot, so I can just delete the new MagicMirror folder and then run the update in the other?
                              sdetweil @swvalenti
                              @swvalenti yes… UPDATE just gets you the new MagicMirror version. currently 2.9.0
                                Thanks Sam
                                  bhepler Module Developer
                                  Huh. I just tried it on a fresh Buster install on a RPI 3B+ and PM2 failed to install correctly. It seems to be a permissions issue.
                                    sdetweil @bhepler
                                    @bhepler show me the log please
                                    ~/install.log
                                      It’s not terribly illuminating.
                                      install and setup pm2
                                      pm2 not installed, installing
                                      pm2 install result
                                      get the pm2 platform specific startup command
                                      startup command =
                                      pm2 startup command done
                                      configure the pm2 config file for MagicMirror
                                      start MagicMirror via pm2 now
                                      save MagicMirror pm2 config now
                                      disable screensaver via lxsession
                                        sdetweil @bhepler
                                        @bhepler hang on, I’ll be back home in a few minutes.
                                        Can u do
                                        pm2 startup
                                          bhepler Module Developer @sdetweil
                                          @sdetweil I already went through the installation procedure to get pm2 installed. That required the npm command to install pm2.
                                          After the initial script run, pm2 start MagicMirror returned a “bash: pm2: command not found” error. Once I got pm2 installed, getting the script monitored by pm2 was easy enough. At a guess, it’s a problem with using sudo to install pm2, but I’m afraid I don’t have the exact error message.
                                            sdetweil @bhepler
                                            @bhepler what did u have to do for the pm2 install?
                                            • 10
                                            • 11
                                            • 7 / 11
