    updated installer script available for testing
    211 Posts 18 Posters 317.6k Views 19 Watching
      bdream
      @sdetweil umpf, yes I started the script but it doesn’t work. So it was a plan not a run :rolling_on_the_floor_laughing:
      bdream@win7 MINGW64 ~/MagicMirror (master)
      $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                              \______/
      install log being saved to /c/Users/HikischB/install.log
      this appears not to be a Raspberry Pi 2 or 3, do you want to continue installation (y/N)?y
      Updating packages ...
      bash: line 93: sudo: command not found
      Update failed, carrying on installation ...
      Installing helper tools ...
      bash: line 99: sudo: command not found
      Seems there is an failure with sudo on my windows machine.
      Do I need to run as admin for update GIT Bash as admin?
      cheers, bdream
        sdetweil @bdream
        @bdream i don’t think it will run in the CYGWIN or MINW environments
        you will have to do the manual install
        see the instructions here https://github.com/MichMich/MagicMirror#manual-installation
        this also requires sudo, to install nodejs
        if you succeed, let me know what you did (step by step) and I will consider updating the installer
          bdream
          @sdetweil looks like a new workingplace :dizzy_face:
          I will hang it on for the next time and mark your comment for further usage.
          1st try to follow the manual installation instruction failed and need more investigatin and understanding on my side
          bdream@win7 MINGW64 ~ (master)
          $ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
          bash: sudo: command not found
          cheers, bdream
            sdetweil @bdream
            @bdream CYGWIN and MINW don’t allow sudo operations, as they don’t control the machine directly
              bdream
              @sdetweil yeah, that is I don’t know what and how to do. And it sounds like a big lack of knowledge on my side…
              cheers, bdream
                sdetweil @bdream
                @bdream try, this, may not work
                curl -sL https://deb.nodesource.com/setup_10.x | bash -
                  bdream
                  @sdetweil it don’t work
                  $ curl -sL https://deb.nodesource.com/setup_10.x | bash -
                  ## Installing the NodeSource Node.js 10.x repo...
                  ## Populating apt-get cache...
                  + apt-get update
                  bash: apt-get: command not found
                  Error executing command, exiting
                  cheers, bdream
                    sdetweil @bdream
                    @bdream yeh, figured
                    if u have windows 10, you could install the ubuntu support, MM will install and run (in serveronly mode) there.
                      bdream
                      then I will start thinking update to Windows10, latest in case I get trouble with MM 2.6.0
                      cheers, bdream
                        sdetweil @bdream
                        @bdream 2.9 is current version.
                          bdream
                          that is, why I wnated to update to 2.9
                          cheers, bdream
                            sdetweil @BD0G
                            @BD0G said in Anyone want to try updated installer...:
                            XXABI_1.3.9’ not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: versionGLIBCXX_3.4.21’
                            I have found a fix, allowing jessie to continue to work… added fix to latest installer…
                            thanks for your help
                            • swvalentiS Offline
                              swvalenti Project Sponsor
                              Tried using the updated install script but get this error. I did killall node
                              and it said that node: no process found
                              install log being saved to /home/pi/MagicMirror/installers/install.log
                              No LSB modules are available.
                              Reading package lists... Done
                              Building dependency tree
                              build-essential is already the newest version (12.3).
                              curl is already the newest version (7.52.1-5+deb9u9).
                              git is already the newest version (1:2.11.0-3+deb9u4).
                              unzip is already the newest version (6.0-21+deb9u2).
                              wget is already the newest version (1.18-5+deb9u3).
                                coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
                                libfile-which-perl libhttp-daemon-perl libhttp-date-perl
                                libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
                                libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
                                librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
                              Use 'sudo apt autoremove' to remove them.
                              0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
                              Minimum Node version: v10.1.0
                              Installed Node version: v9.11.2
                              Node should be upgraded.
                              A Node process is currently running. Can't upgrade.
                              Please quit all Node processes and restart the installer.
                              pi@raspberrypi:~ $
                              pi@raspberrypi:~ $ killall node
                              pi@raspberrypi:~ $
                                sdetweil @swvalenti
                                @swvalenti the code is doing a
                                pgrep "node"
                                to test, do
                                ps -ef | grep node
                                so, they are usually running as /usr/bin/node, killall won’t kill those
                                swvalentiS 1 Reply Last reply Reply Quote 0
                                  swvalenti Project Sponsor @sdetweil
                                  @sdetweil said in Anyone want to try updated installer...:
                                  ps -ef | grep node
                                  pi@raspberrypi:~ $ ps -ef | grep node
                                  pi        5623  5392  0 13:11 pts/0    00:00:00 grep --color=auto node
                                  pi       19082   648  0 Nov12 ?        00:51:53 node /home/pi/node-sonos-http-api/server.js
                                  I dont even have this module anymore I thought it was deleted…what do I need to do in order to make the update work?
                                    sdetweil @swvalenti
                                    @swvalenti said in Anyone want to try updated installer...:
                                    19082
                                    kill -9 19082
                                      Still won’t work did the kill command
                                      pi@raspberrypi:~ $ kill -9 19082
                                      pi@raspberrypi:~ $
                                      pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                                              \______/
                                      pi@raspberrypi:~ $
                                      bash: kill: (19082) - No such process
                                      pi@raspberrypi:~ $
                                                              \______/
                                      pi@raspberrypi:~ $
                                      pi@raspberrypi:~ $
                                        sdetweil @swvalenti
                                        @swvalenti looks like it gets restarted…
                                        again… you killed it before u ran installer
                                        ps -ef | grep node
                                          @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
                                            sdetweil @swvalenti
                                            @swvalenti yes, somehow… I don’t know how it got added…
                                            can u do a
                                            pm2 status
                                            • 10
                                            • 11
                                            • 7 / 11
