    updated installer script available for testing
    211 Posts 18 Posters 330.9k Views 19 Watching
      sdetweil @bdream
      @bdream
      I planned to run updatescript from @sdetweil but failed.
      what does ‘planned’ mean?
      if you DID run my upgrade-script,
      can u show me the ~/MagicMirror/installers/upgrade.log
      thanks
        bdream
        @sdetweil umpf, yes I started the script but it doesn’t work. So it was a plan not a run :rolling_on_the_floor_laughing:
        bdream@win7 MINGW64 ~/MagicMirror (master)
        $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        install log being saved to /c/Users/HikischB/install.log
        this appears not to be a Raspberry Pi 2 or 3, do you want to continue installation (y/N)?y
        Updating packages ...
        bash: line 93: sudo: command not found
        Update failed, carrying on installation ...
        Installing helper tools ...
        bash: line 99: sudo: command not found
        Seems there is an failure with sudo on my windows machine.
        Do I need to run as admin for update GIT Bash as admin?
        cheers, bdream
          sdetweil @bdream
          @bdream i don’t think it will run in the CYGWIN or MINW environments
          you will have to do the manual install
          see the instructions here https://github.com/MichMich/MagicMirror#manual-installation
          this also requires sudo, to install nodejs
          if you succeed, let me know what you did (step by step) and I will consider updating the installer
            bdream
            @sdetweil looks like a new workingplace :dizzy_face:
            I will hang it on for the next time and mark your comment for further usage.
            1st try to follow the manual installation instruction failed and need more investigatin and understanding on my side
            bdream@win7 MINGW64 ~ (master)
            $ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
            bash: sudo: command not found
            cheers, bdream
              sdetweil @bdream
              @bdream CYGWIN and MINW don’t allow sudo operations, as they don’t control the machine directly
                bdream
                @sdetweil yeah, that is I don’t know what and how to do. And it sounds like a big lack of knowledge on my side…
                cheers, bdream
                  sdetweil @bdream
                  @bdream try, this, may not work
                  curl -sL https://deb.nodesource.com/setup_10.x | bash -
                    bdream
                    @sdetweil it don’t work
                    $ curl -sL https://deb.nodesource.com/setup_10.x | bash -
                    ## Installing the NodeSource Node.js 10.x repo...
                    ## Populating apt-get cache...
                    + apt-get update
                    bash: apt-get: command not found
                    Error executing command, exiting
                    cheers, bdream
                      sdetweil @bdream
                      @bdream yeh, figured
                      if u have windows 10, you could install the ubuntu support, MM will install and run (in serveronly mode) there.
                        bdream
                        then I will start thinking update to Windows10, latest in case I get trouble with MM 2.6.0
                        cheers, bdream
                          sdetweil @bdream
                          @bdream 2.9 is current version.
                            bdream
                            that is, why I wnated to update to 2.9
                            cheers, bdream
                              sdetweil @BD0G
                              @BD0G said in Anyone want to try updated installer...:
                              XXABI_1.3.9’ not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: versionGLIBCXX_3.4.21’
                              I have found a fix, allowing jessie to continue to work… added fix to latest installer…
                              thanks for your help
                              • swvalentiS
                                swvalenti Project Sponsor
                                Tried using the updated install script but get this error. I did killall node
                                and it said that node: no process found
                                install log being saved to /home/pi/MagicMirror/installers/install.log
                                No LSB modules are available.
                                Reading package lists... Done
                                Building dependency tree
                                build-essential is already the newest version (12.3).
                                curl is already the newest version (7.52.1-5+deb9u9).
                                git is already the newest version (1:2.11.0-3+deb9u4).
                                unzip is already the newest version (6.0-21+deb9u2).
                                wget is already the newest version (1.18-5+deb9u3).
                                  coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
                                  libfile-which-perl libhttp-daemon-perl libhttp-date-perl
                                  libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
                                  libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
                                  librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
                                Use 'sudo apt autoremove' to remove them.
                                0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
                                Minimum Node version: v10.1.0
                                Installed Node version: v9.11.2
                                Node should be upgraded.
                                A Node process is currently running. Can't upgrade.
                                Please quit all Node processes and restart the installer.
                                pi@raspberrypi:~ $
                                pi@raspberrypi:~ $ killall node
                                pi@raspberrypi:~ $
                                  sdetweil @swvalenti
                                  @swvalenti the code is doing a
                                  pgrep "node"
                                  to test, do
                                  ps -ef | grep node
                                  so, they are usually running as /usr/bin/node, killall won’t kill those
                                  swvalentiS 1 Reply Last reply Reply Quote 0
                                  • swvalentiS
                                    swvalenti Project Sponsor @sdetweil
                                    @sdetweil said in Anyone want to try updated installer...:
                                    ps -ef | grep node
                                    pi@raspberrypi:~ $ ps -ef | grep node
                                    pi        5623  5392  0 13:11 pts/0    00:00:00 grep --color=auto node
                                    pi       19082   648  0 Nov12 ?        00:51:53 node /home/pi/node-sonos-http-api/server.js
                                    I dont even have this module anymore I thought it was deleted…what do I need to do in order to make the update work?
                                      sdetweil @swvalenti
                                      @swvalenti said in Anyone want to try updated installer...:
                                      19082
                                      kill -9 19082
                                      • swvalentiS
                                        Still won’t work did the kill command
                                        pi@raspberrypi:~ $ kill -9 19082
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
        \______/
                                        pi@raspberrypi:~ $
                                        bash: kill: (19082) - No such process
                                        pi@raspberrypi:~ $
        \______/
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $
                                          sdetweil @swvalenti
                                          @swvalenti looks like it gets restarted…
                                          again… you killed it before u ran installer
                                          ps -ef | grep node
                                          • swvalentiS
                                            @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
                                            • 10
                                            • 11
                                            • 7 / 11
