    updated installer script available for testing
    211 Posts 18 Posters 337.5k Views 19 Watching
      sdetweil @bdream
      @bdream try, this, may not work
      curl -sL https://deb.nodesource.com/setup_10.x | bash -
        bdream
        @sdetweil it don’t work
        $ curl -sL https://deb.nodesource.com/setup_10.x | bash -
        ## Installing the NodeSource Node.js 10.x repo...
        ## Populating apt-get cache...
        + apt-get update
        bash: apt-get: command not found
        Error executing command, exiting
        cheers, bdream
          sdetweil @bdream
          @bdream yeh, figured
          if u have windows 10, you could install the ubuntu support, MM will install and run (in serveronly mode) there.
            bdream
            then I will start thinking update to Windows10, latest in case I get trouble with MM 2.6.0
            cheers, bdream
              sdetweil @bdream
              @bdream 2.9 is current version.
                bdream
                that is, why I wnated to update to 2.9
                cheers, bdream
                  sdetweil @BD0G
                  @BD0G said in Anyone want to try updated installer...:
                  XXABI_1.3.9’ not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: versionGLIBCXX_3.4.21’
                  I have found a fix, allowing jessie to continue to work… added fix to latest installer…
                  thanks for your help
                  Reply Quote 2
                  • swvalentiS
                    swvalenti Project Sponsor
                    Tried using the updated install script but get this error. I did killall node
                    and it said that node: no process found
                    install log being saved to /home/pi/MagicMirror/installers/install.log
                    No LSB modules are available.
                    Updating packages ...
                    Installing helper tools ...
                    Reading package lists... Done
                    Building dependency tree
                    build-essential is already the newest version (12.3).
                    curl is already the newest version (7.52.1-5+deb9u9).
                    git is already the newest version (1:2.11.0-3+deb9u4).
                    unzip is already the newest version (6.0-21+deb9u2).
                    wget is already the newest version (1.18-5+deb9u3).
                      coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
                      libfile-which-perl libhttp-daemon-perl libhttp-date-perl
                      libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
                      libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
                      librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
                    Use 'sudo apt autoremove' to remove them.
                    0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
                    Minimum Node version: v10.1.0
                    Installed Node version: v9.11.2
                    Node should be upgraded.
                    A Node process is currently running. Can't upgrade.
                    Please quit all Node processes and restart the installer.
                    pi@raspberrypi:~ $
                    pi@raspberrypi:~ $ killall node
                    pi@raspberrypi:~ $
                      sdetweil @swvalenti
                      @swvalenti the code is doing a
                      pgrep "node"
                      to test, do
                      ps -ef | grep node
                      so, they are usually running as /usr/bin/node, killall won’t kill those
                      swvalentiS 1 Reply Last reply
                      • swvalentiS
                        swvalenti Project Sponsor @sdetweil
                        @sdetweil said in Anyone want to try updated installer...:
                        ps -ef | grep node
                        pi@raspberrypi:~ $ ps -ef | grep node
                        pi        5623  5392  0 13:11 pts/0    00:00:00 grep --color=auto node
                        pi       19082   648  0 Nov12 ?        00:51:53 node /home/pi/node-sonos-http-api/server.js
                        I dont even have this module anymore I thought it was deleted…what do I need to do in order to make the update work?
                          sdetweil @swvalenti
                          @swvalenti said in Anyone want to try updated installer...:
                          19082
                          kill -9 19082
                          • swvalentiS
                            Still won’t work did the kill command
                            pi@raspberrypi:~ $ kill -9 19082
                            pi@raspberrypi:~ $
                            pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                    \______/
                            pi@raspberrypi:~ $
                            bash: kill: (19082) - No such process
                            pi@raspberrypi:~ $
                                                    \______/
                            pi@raspberrypi:~ $
                            pi@raspberrypi:~ $
                              sdetweil @swvalenti
                              @swvalenti looks like it gets restarted…
                              again… you killed it before u ran installer
                              ps -ef | grep node
                              • swvalentiS
                                @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
                                  sdetweil @swvalenti
                                  @swvalenti yes, somehow… I don’t know how it got added…
                                  can u do a
                                  pm2 status
                                  • swvalentiS
                                    pi@raspberrypi:~ $ pm2 status
                                    │ Name        │ id │ mode  │ status │ ↺       │ cpu │ memory │
                                    │ mm          │ 1  │ N/A   │ fork   │ stopped │ 176 │ 0%     │ 0 B       │
                                    │ omx_stream1 │ 2  │ N/A   │ fork   │ stopped │ 61  │ 0%     │ 0 B       │
                                    │ omx_stream2 │ 3  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                                    │ omx_stream3 │ 4  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                                    │ server      │ 0  │ 1.6.5 │ fork   │ online  │ 3   │ 0.4%   │ 40.0 MB   │
                                     Use `pm2 show <id|name>` to get more details about an app
                                    pi@raspberrypi:~ $
                                      sdetweil @swvalenti
                                      @swvalenti i would guess server
                                      pm2 stop server
                                      • swvalentiS
                                        @sdetweil Awesome that worked thanks Sam!
                                          sdetweil @swvalenti
                                          @swvalenti cool… maybe I should dump out the ps -ef list if I find that problem…
                                          • swvalentiS
                                            @sdetweil So I renamed the old magicmirror folder and updated. Now the updates stripped modules and config.js. They are not in the new magicmirror folder at all…what gives?
                                            • 10
                                            • 11
                                            • 7 / 11
