    updated installer script available for testing
    211 Posts 18 Posters 337.7k Views 19 Watching
      sdetweil @bdream
      @bdream i don’t think it will run in the CYGWIN or MINW environments
      you will have to do the manual install
      see the instructions here https://github.com/MichMich/MagicMirror#manual-installation
      this also requires sudo, to install nodejs
      if you succeed, let me know what you did (step by step) and I will consider updating the installer
        bdream
        @sdetweil looks like a new workingplace :dizzy_face:
        I will hang it on for the next time and mark your comment for further usage.
        1st try to follow the manual installation instruction failed and need more investigatin and understanding on my side
        bdream@win7 MINGW64 ~ (master)
        $ curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
        bash: sudo: command not found
        cheers, bdream
          sdetweil @bdream
          @bdream CYGWIN and MINW don’t allow sudo operations, as they don’t control the machine directly
            bdream
            @sdetweil yeah, that is I don’t know what and how to do. And it sounds like a big lack of knowledge on my side…
            cheers, bdream
              sdetweil @bdream
              @bdream try, this, may not work
              curl -sL https://deb.nodesource.com/setup_10.x | bash -
                bdream
                @sdetweil it don’t work
                $ curl -sL https://deb.nodesource.com/setup_10.x | bash -
                ## Installing the NodeSource Node.js 10.x repo...
                ## Populating apt-get cache...
                + apt-get update
                bash: apt-get: command not found
                Error executing command, exiting
                cheers, bdream
                  sdetweil @bdream
                  @bdream yeh, figured
                  if u have windows 10, you could install the ubuntu support, MM will install and run (in serveronly mode) there.
                    bdream
                    then I will start thinking update to Windows10, latest in case I get trouble with MM 2.6.0
                    cheers, bdream
                      sdetweil @bdream
                      @bdream 2.9 is current version.
                        bdream
                        that is, why I wnated to update to 2.9
                        cheers, bdream
                          sdetweil @BD0G
                          @BD0G said in Anyone want to try updated installer...:
                          XXABI_1.3.9’ not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: versionGLIBCXX_3.4.21’
                          I have found a fix, allowing jessie to continue to work… added fix to latest installer…
                          thanks for your help
                          Reply Quote 2
                          • swvalentiS
                            swvalenti Project Sponsor
                            Tried using the updated install script but get this error. I did killall node
                            and it said that node: no process found
                            install log being saved to /home/pi/MagicMirror/installers/install.log
                            No LSB modules are available.
                            Updating packages ...
                            Installing helper tools ...
                            Reading package lists... Done
                            Building dependency tree
                            build-essential is already the newest version (12.3).
                            curl is already the newest version (7.52.1-5+deb9u9).
                            git is already the newest version (1:2.11.0-3+deb9u4).
                            unzip is already the newest version (6.0-21+deb9u2).
                            wget is already the newest version (1.18-5+deb9u3).
                              coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
                              libfile-which-perl libhttp-daemon-perl libhttp-date-perl
                              libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
                              libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
                              librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
                            Use 'sudo apt autoremove' to remove them.
                            0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
                            Minimum Node version: v10.1.0
                            Installed Node version: v9.11.2
                            Node should be upgraded.
                            A Node process is currently running. Can't upgrade.
                            Please quit all Node processes and restart the installer.
                            pi@raspberrypi:~ $
                            pi@raspberrypi:~ $ killall node
                            pi@raspberrypi:~ $
                              sdetweil @swvalenti
                              @swvalenti the code is doing a
                              pgrep "node"
                              to test, do
                              ps -ef | grep node
                              so, they are usually running as /usr/bin/node, killall won’t kill those
                              swvalentiS 1 Reply Last reply
                              • swvalentiS
                                swvalenti Project Sponsor @sdetweil
                                @sdetweil said in Anyone want to try updated installer...:
                                ps -ef | grep node
                                pi@raspberrypi:~ $ ps -ef | grep node
                                pi        5623  5392  0 13:11 pts/0    00:00:00 grep --color=auto node
                                pi       19082   648  0 Nov12 ?        00:51:53 node /home/pi/node-sonos-http-api/server.js
                                I dont even have this module anymore I thought it was deleted…what do I need to do in order to make the update work?
                                  sdetweil @swvalenti
                                  @swvalenti said in Anyone want to try updated installer...:
                                  19082
                                  kill -9 19082
                                  • swvalentiS
                                    Still won’t work did the kill command
                                    pi@raspberrypi:~ $ kill -9 19082
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                                    $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                                    $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                                    $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                    $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                                    $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                                    $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                                    \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                            \______/
                                    pi@raspberrypi:~ $
                                    bash: kill: (19082) - No such process
                                    pi@raspberrypi:~ $
                                                            \______/
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $
                                      sdetweil @swvalenti
                                      @swvalenti looks like it gets restarted…
                                      again… you killed it before u ran installer
                                      ps -ef | grep node
                                      • swvalentiS
                                        @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
                                          sdetweil @swvalenti
                                          @swvalenti yes, somehow… I don’t know how it got added…
                                          can u do a
                                          pm2 status
                                          • swvalentiS
                                            pi@raspberrypi:~ $ pm2 status
                                            │ Name        │ id │ mode  │ status │ ↺       │ cpu │ memory │
                                            │ mm          │ 1  │ N/A   │ fork   │ stopped │ 176 │ 0%     │ 0 B       │
                                            │ omx_stream1 │ 2  │ N/A   │ fork   │ stopped │ 61  │ 0%     │ 0 B       │
                                            │ omx_stream2 │ 3  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                                            │ omx_stream3 │ 4  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                                            │ server      │ 0  │ 1.6.5 │ fork   │ online  │ 3   │ 0.4%   │ 40.0 MB   │
                                             Use `pm2 show <id|name>` to get more details about an app
                                            pi@raspberrypi:~ $
                                            • 10
                                            • 11
                                            • 7 / 11
