    updated installer script available for testing
    211 Posts 18 Posters 337.7k Views 19 Watching
      sdetweil @bdream
      @bdream 2.9 is current version.
        bdream
        that is, why I wnated to update to 2.9
        cheers, bdream
          sdetweil @BD0G
          @BD0G said in Anyone want to try updated installer...:
          XXABI_1.3.9’ not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: versionGLIBCXX_3.4.21’
          I have found a fix, allowing jessie to continue to work… added fix to latest installer…
          thanks for your help
          Reply Quote 2
          • swvalentiS
            swvalenti Project Sponsor
            Tried using the updated install script but get this error. I did killall node
            and it said that node: no process found
            install log being saved to /home/pi/MagicMirror/installers/install.log
            No LSB modules are available.
            Updating packages ...
            Installing helper tools ...
            Reading package lists... Done
            Building dependency tree
            build-essential is already the newest version (12.3).
            curl is already the newest version (7.52.1-5+deb9u9).
            git is already the newest version (1:2.11.0-3+deb9u4).
            unzip is already the newest version (6.0-21+deb9u2).
            wget is already the newest version (1.18-5+deb9u3).
              coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
              libfile-which-perl libhttp-daemon-perl libhttp-date-perl
              libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
              libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
              librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
            Use 'sudo apt autoremove' to remove them.
            0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
            Minimum Node version: v10.1.0
            Installed Node version: v9.11.2
            Node should be upgraded.
            A Node process is currently running. Can't upgrade.
            Please quit all Node processes and restart the installer.
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $ killall node
            pi@raspberrypi:~ $
              sdetweil @swvalenti
              @swvalenti the code is doing a
              pgrep "node"
              to test, do
              ps -ef | grep node
              so, they are usually running as /usr/bin/node, killall won’t kill those
              swvalentiS 1 Reply Last reply
              • swvalentiS
                swvalenti Project Sponsor @sdetweil
                @sdetweil said in Anyone want to try updated installer...:
                ps -ef | grep node
                pi@raspberrypi:~ $ ps -ef | grep node
                pi        5623  5392  0 13:11 pts/0    00:00:00 grep --color=auto node
                pi       19082   648  0 Nov12 ?        00:51:53 node /home/pi/node-sonos-http-api/server.js
                I dont even have this module anymore I thought it was deleted…what do I need to do in order to make the update work?
                  sdetweil @swvalenti
                  @swvalenti said in Anyone want to try updated installer...:
                  19082
                  kill -9 19082
                  • swvalentiS
                    Still won’t work did the kill command
                    pi@raspberrypi:~ $ kill -9 19082
                    pi@raspberrypi:~ $
                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
                    $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                    $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                    $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                    $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                    $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                    $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                    \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                            \______/
                    pi@raspberrypi:~ $
                    bash: kill: (19082) - No such process
                    pi@raspberrypi:~ $
                                            \______/
                    pi@raspberrypi:~ $
                    pi@raspberrypi:~ $
                      sdetweil @swvalenti
                      @swvalenti looks like it gets restarted…
                      again… you killed it before u ran installer
                      ps -ef | grep node
                      • swvalentiS
                        @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
                          sdetweil @swvalenti
                          @swvalenti yes, somehow… I don’t know how it got added…
                          can u do a
                          pm2 status
                          • swvalentiS
                            pi@raspberrypi:~ $ pm2 status
                            │ Name        │ id │ mode  │ status │ ↺       │ cpu │ memory │
                            │ mm          │ 1  │ N/A   │ fork   │ stopped │ 176 │ 0%     │ 0 B       │
                            │ omx_stream1 │ 2  │ N/A   │ fork   │ stopped │ 61  │ 0%     │ 0 B       │
                            │ omx_stream2 │ 3  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                            │ omx_stream3 │ 4  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
                            │ server      │ 0  │ 1.6.5 │ fork   │ online  │ 3   │ 0.4%   │ 40.0 MB   │
                             Use `pm2 show <id|name>` to get more details about an app
                            pi@raspberrypi:~ $
                              sdetweil @swvalenti
                              @swvalenti i would guess server
                              pm2 stop server
                              • swvalentiS
                                @sdetweil Awesome that worked thanks Sam!
                                  sdetweil @swvalenti
                                  @swvalenti cool… maybe I should dump out the ps -ef list if I find that problem…
                                  • swvalentiS
                                    @sdetweil So I renamed the old magicmirror folder and updated. Now the updates stripped modules and config.js. They are not in the new magicmirror folder at all…what gives?
                                      sdetweil @swvalenti
                                      @swvalenti this is not an update, it is a NEW install…
                                      so you have to copy from the old mm folder to the new…
                                      if u wanted to UPDATE then u should run the UPDATE script
                                      https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                                      • swvalentiS
                                        @sdetweil Well I am an idiot, so I can just delete the new MagicMirror folder and then run the update in the other?
                                          sdetweil @swvalenti
                                          @swvalenti yes… UPDATE just gets you the new MagicMirror version. currently 2.9.0
                                          • swvalentiS
                                            Thanks Sam
                                            • 10
                                            • 11
                                            • 7 / 11
