    updated installer script available for testing
    211 Posts 18 Posters 319.4k Views 19 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      Still won’t work did the kill command
      pi@raspberrypi:~ $ kill -9 19082
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
      $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
      $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
      $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
      $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
      $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
      $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
      \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                              \______/
      install log being saved to /home/pi/MagicMirror/installers/install.log
      No LSB modules are available.
      Updating packages ...
      Installing helper tools ...
      Reading package lists... Done
      Building dependency tree
      build-essential is already the newest version (12.3).
      curl is already the newest version (7.52.1-5+deb9u9).
      git is already the newest version (1:2.11.0-3+deb9u4).
      unzip is already the newest version (6.0-21+deb9u2).
      wget is already the newest version (1.18-5+deb9u3).
        coinor-libipopt1v5 libcommon-sense-perl libdbi1 libencode-locale-perl
        libfile-which-perl libhttp-daemon-perl libhttp-date-perl
        libhttp-message-perl libio-html-perl libipc-sharelite-perl libjson-perl
        libjson-xs-perl liblwp-mediatypes-perl libmumps-seq-4.10.0 libraw15 librrd8
        librrds-perl libtimedate-perl libtypes-serialiser-perl liburi-perl realpath
      Use 'sudo apt autoremove' to remove them.
      0 upgraded, 0 newly installed, 0 to remove and 25 not upgraded.
      Minimum Node version: v10.1.0
      Installed Node version: v9.11.2
      Node should be upgraded.
      A Node process is currently running. Can't upgrade.
      Please quit all Node processes and restart the installer.
      pi@raspberrypi:~ $
      bash: kill: (19082) - No such process
      pi@raspberrypi:~ $
                              \______/
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $
        sdetweil @swvalenti
        @swvalenti looks like it gets restarted…
        again… you killed it before u ran installer
        ps -ef | grep node
        swvalentiS 1 Reply Last reply Reply Quote 0
          swvalenti Project Sponsor @sdetweil
          @sdetweil that is correct, can I somehow delete this node process as I don’t even use that module anymore?
            sdetweil @swvalenti
            @swvalenti yes, somehow… I don’t know how it got added…
            can u do a
            pm2 status
              pi@raspberrypi:~ $ pm2 status
              │ Name        │ id │ mode  │ status │ ↺       │ cpu │ memory │
              │ mm          │ 1  │ N/A   │ fork   │ stopped │ 176 │ 0%     │ 0 B       │
              │ omx_stream1 │ 2  │ N/A   │ fork   │ stopped │ 61  │ 0%     │ 0 B       │
              │ omx_stream2 │ 3  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
              │ omx_stream3 │ 4  │ N/A   │ fork   │ stopped │ 0   │ 0%     │ 0 B       │
              │ server      │ 0  │ 1.6.5 │ fork   │ online  │ 3   │ 0.4%   │ 40.0 MB   │
               Use `pm2 show <id|name>` to get more details about an app
              pi@raspberrypi:~ $
                sdetweil @swvalenti
                @swvalenti i would guess server
                pm2 stop server
                  @sdetweil Awesome that worked thanks Sam!
                    sdetweil @swvalenti
                    @swvalenti cool… maybe I should dump out the ps -ef list if I find that problem…
                      @sdetweil So I renamed the old magicmirror folder and updated. Now the updates stripped modules and config.js. They are not in the new magicmirror folder at all…what gives?
                        sdetweil @swvalenti
                        @swvalenti this is not an update, it is a NEW install…
                        so you have to copy from the old mm folder to the new…
                        if u wanted to UPDATE then u should run the UPDATE script
                        https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                          @sdetweil Well I am an idiot, so I can just delete the new MagicMirror folder and then run the update in the other?
                            sdetweil @swvalenti
                            @swvalenti yes… UPDATE just gets you the new MagicMirror version. currently 2.9.0
                              Thanks Sam
                                bhepler Module Developer
                                Huh. I just tried it on a fresh Buster install on a RPI 3B+ and PM2 failed to install correctly. It seems to be a permissions issue.
                                  sdetweil @bhepler
                                  @bhepler show me the log please
                                  ~/install.log
                                    It’s not terribly illuminating.
                                    install and setup pm2
                                    pm2 not installed, installing
                                    pm2 install result
                                    get the pm2 platform specific startup command
                                    startup command =
                                    pm2 startup command done
                                    configure the pm2 config file for MagicMirror
                                    start MagicMirror via pm2 now
                                    save MagicMirror pm2 config now
                                    disable screensaver via lxsession
                                      sdetweil @bhepler
                                      @bhepler hang on, I’ll be back home in a few minutes.
                                      Can u do
                                      pm2 startup
                                        bhepler Module Developer @sdetweil
                                        @sdetweil I already went through the installation procedure to get pm2 installed. That required the npm command to install pm2.
                                        After the initial script run, pm2 start MagicMirror returned a “bash: pm2: command not found” error. Once I got pm2 installed, getting the script monitored by pm2 was easy enough. At a guess, it’s a problem with using sudo to install pm2, but I’m afraid I don’t have the exact error message.
                                          sdetweil @bhepler
                                          @bhepler what did u have to do for the pm2 install?
                                            @sdetweil - I pulled this from the official GitHub page: sudo npm install -g pm2. Once I ran that, I just changed to the ~/MagicMirrors/installers folder and told pm2 to run/maintain it: pm2 start mm.sh
                                            • 10
                                            • 11
                                            • 7 / 11
