    updated installer script available for testing
    211 Posts 18 Posters 287.2k Views 19 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      Thanks Sam
      • bheplerB Offline
        bhepler Module Developer
        Huh. I just tried it on a fresh Buster install on a RPI 3B+ and PM2 failed to install correctly. It seems to be a permissions issue.
          sdetweil @bhepler
          @bhepler show me the log please
          ~/install.log
          • bheplerB Offline
            It’s not terribly illuminating.
            install and setup pm2
            pm2 not installed, installing
            pm2 install result
            get the pm2 platform specific startup command
            startup command =
            pm2 startup command done
            configure the pm2 config file for MagicMirror
            start MagicMirror via pm2 now
            save MagicMirror pm2 config now
            disable screensaver via lxsession
              sdetweil @bhepler
              @bhepler hang on, I’ll be back home in a few minutes.
              Can u do
              pm2 startup
              • bheplerB Offline
                bhepler Module Developer @sdetweil
                @sdetweil I already went through the installation procedure to get pm2 installed. That required the npm command to install pm2.
                After the initial script run, pm2 start MagicMirror returned a “bash: pm2: command not found” error. Once I got pm2 installed, getting the script monitored by pm2 was easy enough. At a guess, it’s a problem with using sudo to install pm2, but I’m afraid I don’t have the exact error message.
                  sdetweil @bhepler
                  @bhepler what did u have to do for the pm2 install?
                  • bheplerB Offline
                    @sdetweil - I pulled this from the official GitHub page: sudo npm install -g pm2. Once I ran that, I just changed to the ~/MagicMirrors/installers folder and told pm2 to run/maintain it: pm2 start mm.sh
                      sdetweil @bhepler
                      @bhepler weird… that is that the script does between the two log entries
                      	echo pm2 not installed, installing >>$logfile
                      	result=$(npm install $up -g pm2)
                      	echo pm2 install result $result >>$logfile
                      $up is for the mac
                      bet it needed sudo…
                        @bhepler
                        I also added to catch the stderr output to the log too
                        	result=$(sudo npm install $up -g pm2 2>&1)
                          sdetweil @bhepler
                          @bhepler could you retest the installer? just rename your current MagicMirror folder out of the way… thanks
                          course u have pm2 already … never mind
                          • bheplerB Offline
                            @sdetweil - No worries. I have a spare Pi and a SD card I can use. I’ll get it cranked out tonight. I’ll get you that info.
                              sdetweil @bhepler
                              @bhepler thanks… i got some new sd cards today, so I will test too.
                              • bheplerB Offline
                                @sdetweil - Brand new Buster installation on a RPi 3B+. Installation script worked as expected.
                                I had trouble with pm2 on my existing mirror too. I ended up upgrading to the latest pm2 in order to get it to remember to start on boot.
                                At this point, I think your script is handling it properly. Thanks for the quick replies!
                                  sdetweil @bhepler
                                  @bhepler oh, there is a script for just pm2 as well.
                                  Thx for feedback.
                                  • N Offline
                                    NathTheDude
                                    Hey sam (@sdetweil ),
                                    Thanks for this, made my life a lot easier.
                                    So, I just did a new build with Buster on a RPI Zero W. All looked good and I have configured mm2 to start on reboot of the Pi. I am start/stop/restart and check the status of mm2 and is looks to be working, the mm2 logs are also good with no error logs.
                                    The problem I am facing is that the magicMirror page via chromium seems to try and load (white screen which changes to a pure black screen) however seems to fail/crash and go back to the Raspbian desktop.
                                    This happens when I reboot the pi and also when I manually try to start/restart the mm2 service.
                                    Anything you think I am missing?
                                      sdetweil @NathTheDude
                                      @NathTheDude if u start the chromium browser from the desktop does it work?
                                        U may need to increase the swap space. Pi 0 has very little memory.
                                        https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
                                        • N Offline
                                          NathTheDude
                                          Thanks @sdetweil , after a couple of reboots this is now working as expected. Not sure what the issue was, I will have to keep an eye on it. Thanks for the link on swap space, I will also look in that direction if I have any more of the same issues.
                                            @NathTheDude ok… let me know if there are any other issues…
                                            S N 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 8 / 11
