    updated installer script available for testing
    211 Posts 18 Posters 331.0k Views 19 Watching
      sdetweil @swvalenti
      @swvalenti cool… maybe I should dump out the ps -ef list if I find that problem…
      swvalentiS 1 Reply Last reply Reply Quote 0
      • swvalentiS
        swvalenti Project Sponsor @sdetweil
        @sdetweil So I renamed the old magicmirror folder and updated. Now the updates stripped modules and config.js. They are not in the new magicmirror folder at all…what gives?
          sdetweil @swvalenti
          @swvalenti this is not an update, it is a NEW install…
          so you have to copy from the old mm folder to the new…
          if u wanted to UPDATE then u should run the UPDATE script
          https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
          • swvalentiS
            @sdetweil Well I am an idiot, so I can just delete the new MagicMirror folder and then run the update in the other?
              sdetweil @swvalenti
              @swvalenti yes… UPDATE just gets you the new MagicMirror version. currently 2.9.0
              • swvalentiS
                Thanks Sam
                  bhepler Module Developer
                  Huh. I just tried it on a fresh Buster install on a RPI 3B+ and PM2 failed to install correctly. It seems to be a permissions issue.
                    sdetweil @bhepler
                    @bhepler show me the log please
                    ~/install.log
                      It’s not terribly illuminating.
                      install and setup pm2
                      pm2 not installed, installing
                      pm2 install result
                      get the pm2 platform specific startup command
                      startup command =
                      pm2 startup command done
                      configure the pm2 config file for MagicMirror
                      start MagicMirror via pm2 now
                      save MagicMirror pm2 config now
                      disable screensaver via lxsession
                        sdetweil @bhepler
                        @bhepler hang on, I’ll be back home in a few minutes.
                        Can u do
                        pm2 startup
                          bhepler Module Developer @sdetweil
                          @sdetweil I already went through the installation procedure to get pm2 installed. That required the npm command to install pm2.
                          After the initial script run, pm2 start MagicMirror returned a “bash: pm2: command not found” error. Once I got pm2 installed, getting the script monitored by pm2 was easy enough. At a guess, it’s a problem with using sudo to install pm2, but I’m afraid I don’t have the exact error message.
                            sdetweil @bhepler
                            @bhepler what did u have to do for the pm2 install?
                              @sdetweil - I pulled this from the official GitHub page: sudo npm install -g pm2. Once I ran that, I just changed to the ~/MagicMirrors/installers folder and told pm2 to run/maintain it: pm2 start mm.sh
                                sdetweil @bhepler
                                @bhepler weird… that is that the script does between the two log entries
                                	echo pm2 not installed, installing >>$logfile
                                	result=$(npm install $up -g pm2)
                                	echo pm2 install result $result >>$logfile
                                $up is for the mac
                                bet it needed sudo…
                                  @bhepler
                                  I also added to catch the stderr output to the log too
                                  	result=$(sudo npm install $up -g pm2 2>&1)
                                    sdetweil @bhepler
                                    @bhepler could you retest the installer? just rename your current MagicMirror folder out of the way… thanks
                                    course u have pm2 already … never mind
                                      @sdetweil - No worries. I have a spare Pi and a SD card I can use. I’ll get it cranked out tonight. I’ll get you that info.
                                        sdetweil @bhepler
                                        @bhepler thanks… i got some new sd cards today, so I will test too.
                                          @sdetweil - Brand new Buster installation on a RPi 3B+. Installation script worked as expected.
                                          I had trouble with pm2 on my existing mirror too. I ended up upgrading to the latest pm2 in order to get it to remember to start on boot.
                                          At this point, I think your script is handling it properly. Thanks for the quick replies!
                                            sdetweil @bhepler
                                            @bhepler oh, there is a script for just pm2 as well.
                                            Thx for feedback.
                                            • 10
                                            • 11
                                            • 8 / 11
