    updated installer script available for testing
    211 Posts 18 Posters 319.4k Views 19 Watching
      jorgnyg @jorgnyg
      @jorgnyg Yea guess so. Installation fails on rpi zero. So I deleted the electron folder from node_modules, and ran npm install --arch=armv7l electron@3.0.13
        sdetweil @jorgnyg
        @jorgnyg doesn’t fail on my pi 0.
        Can u send me the install.log
        S J 2 Replies Last reply Reply Quote 0
          @sdetweil note that we made electron optional. There is no armv6l at node 10
          So we will run in split mode use chromium
            jorgnyg @sdetweil
            @sdetweil sure thing. Guess this is the most relevant error
            26380 verbose stack Error: electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
            26380 verbose stack Exit status 1
            26380 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
            26380 verbose stack     at EventEmitter.emit (events.js:198:13)
            26380 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
            26380 verbose stack     at ChildProcess.emit (events.js:198:13)
            26380 verbose stack     at maybeClose (internal/child_process.js:982:16)
            26380 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
            26381 verbose pkgid electron-chromedriver@1.8.0
            26382 verbose cwd /home/pi/MagicMirror
            26383 verbose Linux 4.19.75+
            26384 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
            26385 verbose node v10.18.1
            26386 verbose npm  v6.13.4
            26387 error code ELIFECYCLE
            26388 error errno 1
            26389 error electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
            26389 error Exit status 1
            26390 error Failed at the electron-chromedriver@1.8.0 install script.
            26390 error This is probably not a problem with npm. There is likely additional logging output above.
            26391 verbose exit [ 1, true ]
              sdetweil @jorgnyg
              @jorgnyg the run-start.sh script now handles this problem and launches chromium instead of electron to connect to mm in serveronly mode
                jorgnyg @sdetweil
                @sdetweil got it!
                  jthirasilpa
                  Hi - firstly thanks for putting together this installer!
                  I am running Raspbian on RP3b+ as a fresh install using the command
                  curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
                  Installer indicated successful install of MagicMirror.
                  Using SSH DISPLAY=:0 npm start gives the following error:
                  magicmirror@2.10.1 start /home/jojo/MagicMirror
                  ./run-start.sh
                  No protocol specified
                  (electron:17801): Gtk-WARNING **: 18:36:26.218: cannot open display: :0
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno 1
                  npm ERR! magicmirror@2.10.1 start: ./run-start.sh
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.10.1 start script.
                  npm ERR! /home/jojo/.npm/_logs/2020-01-25T18_36_26_308Z-debug.log
                  Debug log contents are as follows:
                  1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
                  2 info using npm@6.13.4
                  3 info using node@v10.18.1
                  4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                  5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
                  6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
                  7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
                  8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/jojo/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                  9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/jojo/MagicMirror
                  10 silly lifecycle magicmirror@2.10.1~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
                  11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1 signal: null
                  12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
                  13 verbose stack Error: magicmirror@2.10.1 start: ./run-start.sh
                  13 verbose stack Exit status 1
                  13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                  13 verbose stack at EventEmitter.emit (events.js:198:13)
                  13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  13 verbose stack at ChildProcess.emit (events.js:198:13)
                  13 verbose stack at maybeClose (internal/child_process.js:982:16)
                  13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                  14 verbose pkgid magicmirror@2.10.1
                  15 verbose cwd /home/jojo/MagicMirror
                  16 verbose Linux 4.19.75-v7+
                  17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
                  18 verbose node v10.18.1
                  19 verbose npm v6.13.4
                  20 error code ELIFECYCLE
                  21 error errno 1
                  22 error magicmirror@2.10.1 start: ./run-start.sh
                  22 error Exit status 1
                  23 error Failed at the magicmirror@2.10.1 start script.
                  23 error This is probably not a problem with npm. There is likely additional logging output above.
                  24 verbose exit [ 1, true ]
                  Any thoughts on how to troubleshoot? Many thanks.
                    sdetweil @jthirasilpa
                    @jthirasilpa seems like you are running in console mode, instead of graphical mode.
                    Mm requires the full desktop.
                      jthirasilpa @sdetweil
                      @sdetweil Thanks. The RP is running a full desktop - if I run npm start directly from the RP, the debug log gives the following output:
                      21 error errno 1
                        @jthirasilpa change line 1 of run-start.sh to be
                        #~/bin/bash -x
                        then do the npm start again…
                        also do
                         which chromium-browser
                        my system returns
                        /usr/bin/chromium-browser
                        can u send me the MagicMirror/installers/upgrade.log via email
                        same userid as here, at gmail
                        thanks
                          @sdetweil sorry, typo on run-start
                          #!/bin/bash -x
                          • N Offline
                            Neebotol
                            Hello there!
                            Thank you for this script, it has worked better than the original one for me. But I still really unlucky and have an issue.
                            Here it is :
                            pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirr  or_scripts/master/raspberry.sh | bash
                            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                          $$  __$$\
                            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$  $\   $$$$$$\   $$$$$$\  \__/  $$ |
                            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __  $$\ $$  __$$\ $$  __$$\  $$$$$$  |
                            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |    \__|$$ /  $$ |$$ |  \__|$$  ____/
                            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |        $$ |  $$ |$$ |      $$ |
                            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |        \$$$$$$  |$$ |      $$$$$$$$\
                            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|         \______/ \__|      \________|
                                                    \______/
                            install log being saved to /home/pi/install.log
                            Updating packages ...
                            Installing helper tools ...
                            Lecture des listes de paquets... Fait
                            Construction de l'arbre des dépendances
                            Lecture des informations d'état... Fait
                            build-essential est déjà la version la plus récente (12.6).
                            curl est déjà la version la plus récente (7.64.0-4).
                            unzip est déjà la version la plus récente (6.0-23+deb10u1).
                            wget est déjà la version la plus récente (1.20.1-1.1).
                            wget passé en « installé manuellement ».
                            Paquets suggérés :
                              git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitwe
                            Les paquets suivants seront mis à jour :
                              git
                            1 mis à jour, 0 nouvellement installés, 0 à enlever et 166 non mis à jour.
                            Il est nécessaire de prendre 4 203 ko dans les archives.
                            Après cette opération, 33,8 ko d'espace disque supplémentaires seront utilisés.
                            Réception de :1 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf gi
                            4 203 ko réceptionnés en 2s (2 281 ko/s)
                            apt-listchanges : Lecture des fichiers de modifications (« changelog »)...
                            (Lecture de la base de données... 93835 fichiers et répertoires déjà installés.)
                            Préparation du dépaquetage de .../git_1%3a2.20.1-2+deb10u1_armhf.deb ...
                            Dépaquetage de git (1:2.20.1-2+deb10u1) sur (1:2.20.1-2) ...
                            Paramétrage de git (1:2.20.1-2+deb10u1) ...
                            Node.js is not installed.
                            Installing Node.js ...
                            Warning: apt-key output should not be parsed (stdout is not a terminal)
                            Les NOUVEAUX paquets suivants seront installés :
                              nodejs
                            0 mis à jour, 1 nouvellement installés, 0 à enlever et 166 non mis à jour.
                            Il est nécessaire de prendre 14,6 Mo dans les archives.
                            Après cette opération, 77,3 Mo d'espace disque supplémentaires seront utilisés.
                            Réception de :1 https://deb.nodesource.com/node_10.x buster/main armhf nodejs armhf 10.18.1-1nodesource1 [14,6 MB]
                            14,6 Mo réceptionnés en 11s (1 365 ko/s)
                            Sélection du paquet nodejs précédemment désélectionné.
                            (Lecture de la base de données... 93842 fichiers et répertoires déjà installés.)
                            Préparation du dépaquetage de .../nodejs_10.18.1-1nodesource1_armhf.deb ...
                            Dépaquetage de nodejs (10.18.1-1nodesource1) ...
                            Paramétrage de nodejs (10.18.1-1nodesource1) ...
                            Traitement des actions différées (« triggers ») pour man-db (2.8.5-2) ...
                            node version is
                            Node.js installation Done! version=v10.18.1
                            internal/modules/cjs/loader.js:638
                                throw err;
                            Error: Cannot find module 'rimraf'
                                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                at Module.require (internal/modules/cjs/loader.js:692:17)
                                at require (internal/modules/cjs/helpers.js:25:18)
                                at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-vacuum/vacuum.js:6:14)
                            Minimum npm version: V6.0.0
                            Installed npm version: V
                            npm should be upgraded.
                            Installing npm ...
                            E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
                                throw err;
                                throw err;
                            npm installation Done! version=V
                            Cloning MagicMirror ...
                            Clonage dans 'MagicMirror'...
                            remote: Enumerating objects: 331, done.
                            remote: Counting objects: 100% (331/331), done.
                            remote: Compressing objects: 100% (295/295), done.
                            remote: Total 331 (delta 42), reused 193 (delta 23), pack-reused 0
                            Réception d'objets: 100% (331/331), 676.44 KiB | 1.57 MiB/s, fait.
                            Résolution des deltas: 100% (42/42), fait.
                            Cloning MagicMirror Done!
                            Installing dependencies ...
                                throw err;
                            Unable to install dependencies!
                            Any idea please? Honnestly I have spent so much time on this project, all my past weekend and some hours in the week. I tried many things, with several tutorials, raspian stretch, buster… I’m a little desperate, but I’m not giving up!
                            S Mykle1M 2 Replies Last reply Reply Quote 0
                              sdetweil @Neebotol
                              @Neebotol looks like npm is not able to run after the node upgrade…
                              do this
                              rm -rf MagicMirror
                              npm clean cache
                              then start the installer script again
                                Mykle1 Project Sponsor Module Developer @Neebotol
                                @Neebotol said in updated installer script available for testing:
                                We’ve all been there.
                                :thumbsup:
                                  @sdetweil Thanks for your help in getting my installation sorted out Sam.
                                  • N Offline
                                    Neebotol @Mykle1
                                    @Mykle1 said in updated installer script available for testing:
                                    :thumbsup:
                                    Yep! :handshake:
                                      sdetweil @Neebotol
                                      @Neebotol is MM working ok now?
                                      • N Offline
                                        Neebotol @sdetweil
                                        @sdetweil Hello! thank you for the way you’re helping people in this project.
                                        I just solved the problem tonight after more than 20 hours on it! It was really stupid, I used another SD card and it just worked. (I don’t understand too much because the SD card I was using until now was of good quality)
                                        Have a good day!
                                          sdetweil @Neebotol
                                          @Neebotol great work!! Yeh, having a bad card will.make things very challenging.
                                          Thanks for the feedback
                                          • N Offline
                                            NathTheDude @sdetweil
                                            Hey @sdetweil,
                                            Forgot I did not get back to you. After much testing it was not feasible to use an rpi zero. Actually the ram/memory was ok, the main limitation was the cpu.
                                            I was using htop to monitor this during boot and normal usage, is was constantly at 100%. This caused really slow boot time and could not load the modules fully even if left for several hours.
                                            As soon as I went back to my rpi3 with the same modules it started very quick in comparison with no boot issues.
                                            • 10
                                            • 11
                                            • 9 / 11
