    updated installer script available for testing
    211 Posts 18 Posters 319.7k Views 19 Watching
      jthirasilpa
      Hi - firstly thanks for putting together this installer!
      I am running Raspbian on RP3b+ as a fresh install using the command
      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh | bash
      Installer indicated successful install of MagicMirror.
      Using SSH DISPLAY=:0 npm start gives the following error:
      magicmirror@2.10.1 start /home/jojo/MagicMirror
      ./run-start.sh
      No protocol specified
      (electron:17801): Gtk-WARNING **: 18:36:26.218: cannot open display: :0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.10.1 start: ./run-start.sh
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.10.1 start script.
      npm ERR! /home/jojo/.npm/_logs/2020-01-25T18_36_26_308Z-debug.log
      Debug log contents are as follows:
      1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@6.13.4
      3 info using node@v10.18.1
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.10.1~prestart: magicmirror@2.10.1
      6 info lifecycle magicmirror@2.10.1~start: magicmirror@2.10.1
      7 verbose lifecycle magicmirror@2.10.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.10.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/jojo/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      9 verbose lifecycle magicmirror@2.10.1~start: CWD: /home/jojo/MagicMirror
      10 silly lifecycle magicmirror@2.10.1~start: Args: [ ‘-c’, ‘./run-start.sh’ ]
      11 silly lifecycle magicmirror@2.10.1~start: Returned: code: 1 signal: null
      12 info lifecycle magicmirror@2.10.1~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.10.1 start: ./run-start.sh
      13 verbose stack Exit status 1
      13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack at EventEmitter.emit (events.js:198:13)
      13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack at ChildProcess.emit (events.js:198:13)
      13 verbose stack at maybeClose (internal/child_process.js:982:16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.10.1
      15 verbose cwd /home/jojo/MagicMirror
      16 verbose Linux 4.19.75-v7+
      17 verbose argv “/usr/bin/node” “/usr/bin/npm” “start”
      18 verbose node v10.18.1
      19 verbose npm v6.13.4
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.10.1 start: ./run-start.sh
      22 error Exit status 1
      23 error Failed at the magicmirror@2.10.1 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      Any thoughts on how to troubleshoot? Many thanks.
        sdetweil @jthirasilpa
        @jthirasilpa seems like you are running in console mode, instead of graphical mode.
        Mm requires the full desktop.
          jthirasilpa @sdetweil
          @sdetweil Thanks. The RP is running a full desktop - if I run npm start directly from the RP, the debug log gives the following output:
          21 error errno 1
            @jthirasilpa change line 1 of run-start.sh to be
            #~/bin/bash -x
            then do the npm start again…
            also do
             which chromium-browser
            my system returns
            /usr/bin/chromium-browser
            can u send me the MagicMirror/installers/upgrade.log via email
            same userid as here, at gmail
            thanks
              @sdetweil sorry, typo on run-start
              #!/bin/bash -x
              • N Offline
                Neebotol
                Hello there!
                Thank you for this script, it has worked better than the original one for me. But I still really unlucky and have an issue.
                Here it is :
                pi@raspberrypi:~ $ curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirr  or_scripts/master/raspberry.sh | bash
                $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                          $$  __$$\
                $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$  $\   $$$$$$\   $$$$$$\  \__/  $$ |
                $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __  $$\ $$  __$$\ $$  __$$\  $$$$$$  |
                $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |    \__|$$ /  $$ |$$ |  \__|$$  ____/
                $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |        $$ |  $$ |$$ |      $$ |
                $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |        \$$$$$$  |$$ |      $$$$$$$$\
                \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|         \______/ \__|      \________|
                                        \______/
                install log being saved to /home/pi/install.log
                Updating packages ...
                Installing helper tools ...
                Lecture des listes de paquets... Fait
                Construction de l'arbre des dépendances
                Lecture des informations d'état... Fait
                build-essential est déjà la version la plus récente (12.6).
                curl est déjà la version la plus récente (7.64.0-4).
                unzip est déjà la version la plus récente (6.0-23+deb10u1).
                wget est déjà la version la plus récente (1.20.1-1.1).
                wget passé en « installé manuellement ».
                Paquets suggérés :
                  git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitwe
                Les paquets suivants seront mis à jour :
                  git
                1 mis à jour, 0 nouvellement installés, 0 à enlever et 166 non mis à jour.
                Il est nécessaire de prendre 4 203 ko dans les archives.
                Après cette opération, 33,8 ko d'espace disque supplémentaires seront utilisés.
                Réception de :1 http://mirrors.ircam.fr/pub/raspbian/raspbian buster/main armhf gi
                4 203 ko réceptionnés en 2s (2 281 ko/s)
                apt-listchanges : Lecture des fichiers de modifications (« changelog »)...
                (Lecture de la base de données... 93835 fichiers et répertoires déjà installés.)
                Préparation du dépaquetage de .../git_1%3a2.20.1-2+deb10u1_armhf.deb ...
                Dépaquetage de git (1:2.20.1-2+deb10u1) sur (1:2.20.1-2) ...
                Paramétrage de git (1:2.20.1-2+deb10u1) ...
                Node.js is not installed.
                Installing Node.js ...
                Warning: apt-key output should not be parsed (stdout is not a terminal)
                Les NOUVEAUX paquets suivants seront installés :
                  nodejs
                0 mis à jour, 1 nouvellement installés, 0 à enlever et 166 non mis à jour.
                Il est nécessaire de prendre 14,6 Mo dans les archives.
                Après cette opération, 77,3 Mo d'espace disque supplémentaires seront utilisés.
                Réception de :1 https://deb.nodesource.com/node_10.x buster/main armhf nodejs armhf 10.18.1-1nodesource1 [14,6 MB]
                14,6 Mo réceptionnés en 11s (1 365 ko/s)
                Sélection du paquet nodejs précédemment désélectionné.
                (Lecture de la base de données... 93842 fichiers et répertoires déjà installés.)
                Préparation du dépaquetage de .../nodejs_10.18.1-1nodesource1_armhf.deb ...
                Dépaquetage de nodejs (10.18.1-1nodesource1) ...
                Paramétrage de nodejs (10.18.1-1nodesource1) ...
                Traitement des actions différées (« triggers ») pour man-db (2.8.5-2) ...
                node version is
                Node.js installation Done! version=v10.18.1
                internal/modules/cjs/loader.js:638
                    throw err;
                Error: Cannot find module 'rimraf'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                    at Module.require (internal/modules/cjs/loader.js:692:17)
                    at require (internal/modules/cjs/helpers.js:25:18)
                    at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/fs-vacuum/vacuum.js:6:14)
                Minimum npm version: V6.0.0
                Installed npm version: V
                npm should be upgraded.
                Installing npm ...
                E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
                    throw err;
                    throw err;
                npm installation Done! version=V
                Cloning MagicMirror ...
                Clonage dans 'MagicMirror'...
                remote: Enumerating objects: 331, done.
                remote: Counting objects: 100% (331/331), done.
                remote: Compressing objects: 100% (295/295), done.
                remote: Total 331 (delta 42), reused 193 (delta 23), pack-reused 0
                Réception d'objets: 100% (331/331), 676.44 KiB | 1.57 MiB/s, fait.
                Résolution des deltas: 100% (42/42), fait.
                Cloning MagicMirror Done!
                Installing dependencies ...
                    throw err;
                Unable to install dependencies!
                Any idea please? Honnestly I have spent so much time on this project, all my past weekend and some hours in the week. I tried many things, with several tutorials, raspian stretch, buster… I’m a little desperate, but I’m not giving up!
                S Mykle1M 2 Replies Last reply Reply Quote 0
                  sdetweil @Neebotol
                  @Neebotol looks like npm is not able to run after the node upgrade…
                  do this
                  rm -rf MagicMirror
                  npm clean cache
                  then start the installer script again
                    Mykle1 Project Sponsor Module Developer @Neebotol
                    @Neebotol said in updated installer script available for testing:
                    We’ve all been there.
                    :thumbsup:
                      @sdetweil Thanks for your help in getting my installation sorted out Sam.
                      • N Offline
                        Neebotol @Mykle1
                        @Mykle1 said in updated installer script available for testing:
                        :thumbsup:
                        Yep! :handshake:
                          sdetweil @Neebotol
                          @Neebotol is MM working ok now?
                          • N Offline
                            Neebotol @sdetweil
                            @sdetweil Hello! thank you for the way you’re helping people in this project.
                            I just solved the problem tonight after more than 20 hours on it! It was really stupid, I used another SD card and it just worked. (I don’t understand too much because the SD card I was using until now was of good quality)
                            Have a good day!
                              sdetweil @Neebotol
                              @Neebotol great work!! Yeh, having a bad card will.make things very challenging.
                              Thanks for the feedback
                              • N Offline
                                NathTheDude @sdetweil
                                Hey @sdetweil,
                                Forgot I did not get back to you. After much testing it was not feasible to use an rpi zero. Actually the ram/memory was ok, the main limitation was the cpu.
                                I was using htop to monitor this during boot and normal usage, is was constantly at 100%. This caused really slow boot time and could not load the modules fully even if left for several hours.
                                As soon as I went back to my rpi3 with the same modules it started very quick in comparison with no boot issues.
                                  sdetweil @NathTheDude
                                  @NathTheDude thank you for the feedback. Yes Pi 0 is really limited in what it can do.
                                    @NathTheDude using the new run-start.sh which launches chrome to connect to the MM serverOnly instance… I see 45% usage in htop for the initial config.
                                    electron has become unavailable for armv6l and node >8, so we’ve had to go split mode
                                      PinkPumpkin
                                      Do anyone know if the link bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)” can be found elsewhere?
                                      It worked great on Raspberry Pi (1) but now it’s 404:-/
                                        sdetweil @PinkPumpkin
                                        @PinkPumpkin the scripts were moved to
                                        As they were removed from the last release
                                        This was also corrected on the 1st post of this topic.
                                          PinkPumpkin
                                          Thanks alot;-)
                                          Sowwy I didn’t see that…
                                            @PinkPumpkin no problem!.. its hard to keep stuff up to date here… lots of folks use 3 year old ‘cookbooks’, that no longer work…
                                            • 10
                                            • 11
                                            • 9 / 11
