    Config Options in the News Module
    15 Posts 2 Posters 4.3k Views 2 Watching
    • edwardssjE Offline
      edwardssj
      Could you give me an example please so I can understand where and the format, thanks.
        sdetweil @edwardssj
        @edwardssj never mind,. it doesn’ty work for some sites (as the site refuses to allow embedding)
        the setup was
        			module: "newsfeed",
        			disabled: false,
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: true,
        				broadcastNewsUpdates: true,
        				showFullArticle : true      // < ---  added this, with the comma on line before
          edwardssj @sdetweil
          @sdetweil Could you give me an example please so I can understand where and the format, thanks.
            sdetweil @edwardssj
            @edwardssj I did that in the message above this one
            edwardssjE 1 Reply Last reply Reply Quote 0
              edwardssj @sdetweil
              @sdetweil Sorry Sam, I should have refresehed :)
                sdetweil @edwardssj
                @edwardssj no problem. Hope it works for you.
                The New York Times doesn’t allow it’s feed to be framed away from it’s parent site
                edwardssjE 2 Replies Last reply Reply Quote 0
                  edwardssj @sdetweil
                  @sdetweil It does but of course brings the story up into a full screen, I just have to find a way to bring the text only into the window.
                  Thank you for showing me the anatomy of the module.
                  Stuart
                    edwardssj @sdetweil
                    @sdetweil I have broken something and I cannot see where
                    /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                    var config =
                      address: '0.0.0.0',
                      electronOptions: {},
                      ipWhitelist: [],
                          module: 'MMM-Remote-Control',
                          position: 'bottom_right',
                            apiKey: '',
                            customCommand: {}
                          module: 'alert',
                          config: {}
                          module: 'updatenotification',
                          position: 'top_bar',
                          config: {}
                          module: 'clock',
                          position: 'top_left',
                          config: {}
                          module: 'calendar',
                          header: 'UK Holidays',
                                symbol: 'calendar-check',
                                url: 'webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics'
                            titleReplace: {
                              'De verjaardag van ': '',
                              '\'s birthday': ''
                            excludedEvents: []
                          module: 'currentweather',
                          position: 'top_right',
                            locationID: '2651654',
                            appid: 'c1a5ad438e20f60a0f61165ef64837da',
                            iconTable: {
                              '01d': 'wi-day-sunny',
                              '02d': 'wi-day-cloudy',
                              '03d': 'wi-cloudy',
                              '04d': 'wi-cloudy-windy',
                              '09d': 'wi-showers',
                              '10d': 'wi-rain',
                              '11d': 'wi-thunderstorm',
                              '13d': 'wi-snow',
                              '50d': 'wi-fog',
                              '01n': 'wi-night-clear',
                              '02n': 'wi-night-cloudy',
                              '03n': 'wi-night-cloudy',
                              '04n': 'wi-night-cloudy',
                              '09n': 'wi-night-showers',
                              '10n': 'wi-night-rain',
                              '11n': 'wi-night-thunderstorm',
                              '13n': 'wi-night-snow',
                              '50n': 'wi-night-alt-cloudy-windy'
                          header: ''
                          module: 'weatherforecast',
                          header: 'Weather Forecast',
                            appid: '6ad7c913f464a99eef2b61631b084d42',
                            iconTable: {
                              '03d': 'wi-cloudy',
                              '10d': 'wi-rain',
                              '13d': 'wi-snow',
                              '50d': 'wi-fog',
                          module: 'newsfeed',
                          position: 'top_center',
                            feeds: [
                                title: 'BBC News',
                                url: 'http://feeds.bbci.co.uk/news/rss.xml'
                            showDescription: true,
                            ignoreOldItems: true,
                            scrollLength: true,
                            startTags: [],
                            endTags: [],
                            prohibitedWords: []
                          header: ''
                      paths: {
                        modules: 'modules',
                        vendor: 'vendor'
                      sdetweil @edwardssj
                      @edwardssj u could edit the code not to be full screen. Careful the article could be clipped at the iframe edge
                        sdetweil @edwardssj
                        @edwardssj what is that extra } after prohibited words?
                        Match the braces and brackets
