    Config Options in the News Module
    15 Posts 2 Posters 5.5k Views 2 Watching
      sdetweil @edwardssj
      @edwardssj I did that in the message above this one
      edwardssjE 1 Reply Last reply Reply Quote 0
      • edwardssjE
        edwardssj @sdetweil
        @sdetweil Sorry Sam, I should have refresehed :)
          sdetweil @edwardssj
          @edwardssj no problem. Hope it works for you.
          The New York Times doesn’t allow it’s feed to be framed away from it’s parent site
          edwardssjE 2 Replies Last reply Reply Quote 0
          • edwardssjE
            edwardssj @sdetweil
            @sdetweil It does but of course brings the story up into a full screen, I just have to find a way to bring the text only into the window.
            Thank you for showing me the anatomy of the module.
            Stuart
            • edwardssjE
              edwardssj @sdetweil
              @sdetweil I have broken something and I cannot see where
              /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
              var config =
                address: '0.0.0.0',
                electronOptions: {},
                ipWhitelist: [],
                    module: 'MMM-Remote-Control',
                    position: 'bottom_right',
                      apiKey: '',
                      customCommand: {}
                    module: 'alert',
                    config: {}
                    module: 'updatenotification',
                    position: 'top_bar',
                    config: {}
                    module: 'clock',
                    position: 'top_left',
                    config: {}
                    module: 'calendar',
                    header: 'UK Holidays',
                          symbol: 'calendar-check',
                          url: 'webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics'
                      titleReplace: {
                        'De verjaardag van ': '',
                        '\'s birthday': ''
                      excludedEvents: []
                    module: 'currentweather',
                    position: 'top_right',
                      locationID: '2651654',
                      appid: 'c1a5ad438e20f60a0f61165ef64837da',
                      iconTable: {
                        '01d': 'wi-day-sunny',
                        '02d': 'wi-day-cloudy',
                        '03d': 'wi-cloudy',
                        '04d': 'wi-cloudy-windy',
                        '09d': 'wi-showers',
                        '10d': 'wi-rain',
                        '11d': 'wi-thunderstorm',
                        '13d': 'wi-snow',
                        '50d': 'wi-fog',
                        '01n': 'wi-night-clear',
                        '02n': 'wi-night-cloudy',
                        '03n': 'wi-night-cloudy',
                        '04n': 'wi-night-cloudy',
                        '09n': 'wi-night-showers',
                        '10n': 'wi-night-rain',
                        '11n': 'wi-night-thunderstorm',
                        '13n': 'wi-night-snow',
                        '50n': 'wi-night-alt-cloudy-windy'
                    header: ''
                    module: 'weatherforecast',
                    header: 'Weather Forecast',
                      appid: '6ad7c913f464a99eef2b61631b084d42',
                      iconTable: {
                        '03d': 'wi-cloudy',
                        '10d': 'wi-rain',
                        '13d': 'wi-snow',
                        '50d': 'wi-fog',
                    module: 'newsfeed',
                    position: 'top_center',
                      feeds: [
                          title: 'BBC News',
                          url: 'http://feeds.bbci.co.uk/news/rss.xml'
                      showDescription: true,
                      ignoreOldItems: true,
                      scrollLength: true,
                      startTags: [],
                      endTags: [],
                      prohibitedWords: []
                    header: ''
                paths: {
                  modules: 'modules',
                  vendor: 'vendor'
                sdetweil @edwardssj
                @edwardssj u could edit the code not to be full screen. Careful the article could be clipped at the iframe edge
                  sdetweil @edwardssj
                  @edwardssj what is that extra } after prohibited words?
                  Match the braces and brackets
                  • edwardssjE
                    edwardssj @sdetweil
                    @sdetweil Do I just remove it?
                    Coding is not my strong suit, I tried adding an extra module and got it very wrong
                      sdetweil @edwardssj
                      @edwardssj run npm run config:check from the MagicMirror folder.
                      Fix errors starting from the top.
                      Errors are usually reported on the line after the problem.
                      (Usually)
                      • edwardssjE
                        edwardssj @sdetweil
                        @sdetweil Fixed it by copying the lower portion of the sample file into the live file, will look at the differences later to see where I went wrong, thank you for your help.
                        Stuart
