    Config Options in the News Module
    15 Posts 2 Posters 3.9k Views 2 Watching
      sdetweil @edwardssj
      @edwardssj never mind,. it doesn’ty work for some sites (as the site refuses to allow embedding)
      the setup was
      			module: "newsfeed",
      			disabled: false,
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true,
      				showFullArticle : true      // < ---  added this, with the comma on line before
      • edwardssjE Offline
        edwardssj @sdetweil
        @sdetweil Could you give me an example please so I can understand where and the format, thanks.
          sdetweil @edwardssj
          @edwardssj I did that in the message above this one
          edwardssjE 1 Reply Last reply Reply Quote 0
            edwardssj @sdetweil
            @sdetweil Sorry Sam, I should have refresehed :)
              sdetweil @edwardssj
              @edwardssj no problem. Hope it works for you.
              The New York Times doesn’t allow it’s feed to be framed away from it’s parent site
              edwardssjE 2 Replies Last reply Reply Quote 0
                edwardssj @sdetweil
                @sdetweil It does but of course brings the story up into a full screen, I just have to find a way to bring the text only into the window.
                Thank you for showing me the anatomy of the module.
                Stuart
                  edwardssj @sdetweil
                  @sdetweil I have broken something and I cannot see where
                  /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                  var config =
                    address: '0.0.0.0',
                    electronOptions: {},
                    ipWhitelist: [],
                        module: 'MMM-Remote-Control',
                        position: 'bottom_right',
                          apiKey: '',
                          customCommand: {}
                        module: 'alert',
                        config: {}
                        module: 'updatenotification',
                        position: 'top_bar',
                        config: {}
                        module: 'clock',
                        position: 'top_left',
                        config: {}
                        module: 'calendar',
                        header: 'UK Holidays',
                              symbol: 'calendar-check',
                              url: 'webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics'
                          titleReplace: {
                            'De verjaardag van ': '',
                            '\'s birthday': ''
                          excludedEvents: []
                        module: 'currentweather',
                        position: 'top_right',
                          locationID: '2651654',
                          appid: 'c1a5ad438e20f60a0f61165ef64837da',
                          iconTable: {
                            '01d': 'wi-day-sunny',
                            '02d': 'wi-day-cloudy',
                            '03d': 'wi-cloudy',
                            '04d': 'wi-cloudy-windy',
                            '09d': 'wi-showers',
                            '10d': 'wi-rain',
                            '11d': 'wi-thunderstorm',
                            '13d': 'wi-snow',
                            '50d': 'wi-fog',
                            '01n': 'wi-night-clear',
                            '02n': 'wi-night-cloudy',
                            '03n': 'wi-night-cloudy',
                            '04n': 'wi-night-cloudy',
                            '09n': 'wi-night-showers',
                            '10n': 'wi-night-rain',
                            '11n': 'wi-night-thunderstorm',
                            '13n': 'wi-night-snow',
                            '50n': 'wi-night-alt-cloudy-windy'
                        header: ''
                        module: 'weatherforecast',
                        header: 'Weather Forecast',
                          appid: '6ad7c913f464a99eef2b61631b084d42',
                          iconTable: {
                            '03d': 'wi-cloudy',
                            '10d': 'wi-rain',
                            '13d': 'wi-snow',
                            '50d': 'wi-fog',
                        module: 'newsfeed',
                        position: 'top_center',
                          feeds: [
                              title: 'BBC News',
                              url: 'http://feeds.bbci.co.uk/news/rss.xml'
                          showDescription: true,
                          ignoreOldItems: true,
                          scrollLength: true,
                          startTags: [],
                          endTags: [],
                          prohibitedWords: []
                        header: ''
                    paths: {
                      modules: 'modules',
                      vendor: 'vendor'
                    sdetweil @edwardssj
                    @edwardssj u could edit the code not to be full screen. Careful the article could be clipped at the iframe edge
                      sdetweil @edwardssj
                      @edwardssj what is that extra } after prohibited words?
                      Match the braces and brackets
                        edwardssj @sdetweil
                        @sdetweil Do I just remove it?
                        Coding is not my strong suit, I tried adding an extra module and got it very wrong
