    MMM-Netatmo updated
    56 Posts 15 Posters 42.5k Views 16 Watching
      sdetweil @Miller
      @Miller can u describe what your changes enable
        Miller @sdetweil
        I tried to upload a picture but it didn’t work
        Pictures are also included in my github repository.
        In the Original CFenner repo, if a weathermodule wasn’t in reach, the MMM-Module kept loading. This is fixed. All weathermodules are always displayed, even when not in reach, but then with “–” values and possible message.
        The haywirecoder fork included AIRQuality, and the Rain and Wind-module were integrated in Outdoor. However, depending on the order in which the weathermodules where displayed, the rain and wind values were not always displayed.
        So I changed that first all modules are read from netatmo (then all values are loaded).
        Also you can now configure if you want the wind and rain module integrated in “outdoor” or displayed as own weathermodules.
        Also it is possible to configure your wind-speed-units (kmh, mph, Bft, ms or Kt)
        also i redesigned the modules so that the data is displayed grouped as it is in the android-app).
        See also my Readme: https://github.com/RaymondMolenaar/MMM-Netatmo/blob/master/README.md
          sdetweil @Miller
          @Miller great info, thanks…
          pics, yes has been reported multiple times so far… site support hasn’t done anything about it (yet)
            Miller @sdetweil
            @sdetweil said in MMM-Netatmo updated:
            You’re welcome, hope i did a half decent job.
            Thanks for the info about pics upload.
            • T Offline
              torte22
              This week I switched from CFenner’s netatmo module to this fork. I’m very happy with the new MMM-Netatmo. I had a lot of problems with my old configuration, the module “netatmo” stops updating after approx. 10 - 20 hours. After this period I didn’t got data from my own Netatmo station and the only fix was to restart mm. Now it runs with regularly updated data. And - I Like the different Look and Feel :thumbs_up_medium-light_skin_tone:
              Thank you for the “refurbished” module
                Miller @torte22
                @torte22 You’re welcome
                • zdenekZ Offline
                  zdenek
                  hi, is there way, how to show rooms in one row, instead of in one column?
                  thanks
                  Zdeněk
                    Miller @zdenek
                    @zdenek Not in this version at the moment
                    zdenekZ 1 Reply Last reply Reply Quote 0
                    • zdenekZ Offline
                      zdenek @Miller
                      @Miller thanks, so I’ll have to wait, no problem
                        Miller @zdenek
                        @zdenek I updated the module, now it’s possible to have your Netatmo-Modules (Rooms) in one row.
                        For this set “horizontal” to true on your config.js
                        This will only display rooms on one row as long as there is allowed space from MM-Module.
                        The rooms that don’t fit, will continue on the next row.
                        However, you can “Force” everything to stay on one row.
                        Then set “horizontalOverflow” to true.
                        This forces everything to stay on one row, but of course with the chance it will overflow your other Modules on the mirror.
                        Updated Images are in included in my Github-repository (look at the bottom of the Reame.md)
                        • T Offline
                          torte22
                          This is pretty cool, many thanks!!
                          • zdenekZ Offline
                            zdenek @Miller
                            @Miller great, thanks, I’m going to test.
                            Zdeněk
                            • zdenekZ Offline
                              zdenek @zdenek
                              @Miller so, it works almost perfect, Just:
                              • I would recomment to add comma (,) next to last bracket on git-hub. Like this:
                                when someone copy settings somewhere in the middle of config, he/she has to remember to add comma…
                              • for me doesn’t in hotizontal mode works “horizontalOverflow” or I didn’t get the meaning. I’ve set it false and the row of MMM-Netatmo writes values over modules in “right” column". And cause the size is too big for me, I had to remove one of sensors (1 external + 3 internals)
                              anyway, thanks a lot - great job
                                Miller @zdenek
                                @zdenek Thank you for your comments.
                                I’ll see if i can improve it later
                                • zdenekZ Offline
                                  zdenek @Miller
                                  @Miller no problem, I’ll reorganize modules a little bit…
                                  thanks
                                    airart
                                    there is also a netatmo mudule for thermostat ?
                                      Miller
                                      Here you can find many available modules.
                                      For the thermostat there is this Module
                                      For me that one is not suitable, because it is only for the thermostat, not for the valves.
                                      Since I didn’t find a module for the valves, I will maybe try to make it myself, but will take some time
                                      • zdenekZ Offline
                                        zdenek @Miller
                                        @Miller it will be great. I’ve the one form thermostat, but it only show temp and off/on. Will be great to see “plan”, also the status of valves (actual temp, open/closed, temp by plan…)
                                        thanks
                                        • zdenekZ Offline
                                          zdenek
                                          @Miller can u plz help me to customize CSS? I need to “somehow” add to my CSS
                                          MMM-netatmo . modules bubbles horizontal . module .secondary .displayAQI .AQI .medium light
                                          font-size:15px;
                                          MMM-netattmo . modules bubbles horizontal . module .primary . displayTemp . Temperature . data_container . data_left large light bright
                                          font-size: 40px;
                                          and also overide the module css value
                                          .x-medium {
                                            font-size:170%;
                                          to
                                          .x-medium {
                                            font-size:100%;
                                          the task is decrease the size of font of mentioned DIVs to own defined size (the actual is too big for me)
                                          I’ve tried
                                          .x-medium {
                                            font-size:100%;
                                          .MMM-netatmo .bubbles.horizontal .module .primary .displayTemp .data_container .data_left {
                                            font-size: 40px;
                                          .MMM-netatmo .bubbles.horizontal .module .secondary .displayAQI .AQI {
                                            font-size: 15px;
                                          thanks a lot - I’m lost :-(
                                          • F Offline
                                            frogywill Project Sponsor
                                            This update looks great, thank you! What should be changed to have it display the temps in fahrenheit ?
