    MMM-Netatmo updated
    56 Posts 15 Posters 42.7k Views 16 Watching
      Miller @torte22
      @torte22 You’re welcome
      • zdenekZ Offline
        zdenek
        hi, is there way, how to show rooms in one row, instead of in one column?
        thanks
        Zdeněk
          Miller @zdenek
          @zdenek Not in this version at the moment
          zdenekZ 1 Reply Last reply Reply Quote 0
          • zdenekZ Offline
            zdenek @Miller
            @Miller thanks, so I’ll have to wait, no problem
              Miller @zdenek
              @zdenek I updated the module, now it’s possible to have your Netatmo-Modules (Rooms) in one row.
              For this set “horizontal” to true on your config.js
              This will only display rooms on one row as long as there is allowed space from MM-Module.
              The rooms that don’t fit, will continue on the next row.
              However, you can “Force” everything to stay on one row.
              Then set “horizontalOverflow” to true.
              This forces everything to stay on one row, but of course with the chance it will overflow your other Modules on the mirror.
              Updated Images are in included in my Github-repository (look at the bottom of the Reame.md)
              • T Offline
                torte22
                This is pretty cool, many thanks!!
                • zdenekZ Offline
                  zdenek @Miller
                  @Miller great, thanks, I’m going to test.
                  Zdeněk
                  • zdenekZ Offline
                    zdenek @zdenek
                    @Miller so, it works almost perfect, Just:
                    • I would recomment to add comma (,) next to last bracket on git-hub. Like this:
                      when someone copy settings somewhere in the middle of config, he/she has to remember to add comma…
                    • for me doesn’t in hotizontal mode works “horizontalOverflow” or I didn’t get the meaning. I’ve set it false and the row of MMM-Netatmo writes values over modules in “right” column". And cause the size is too big for me, I had to remove one of sensors (1 external + 3 internals)
                    anyway, thanks a lot - great job
                      Miller @zdenek
                      @zdenek Thank you for your comments.
                      I’ll see if i can improve it later
                      • zdenekZ Offline
                        zdenek @Miller
                        @Miller no problem, I’ll reorganize modules a little bit…
                        thanks
                          airart
                          there is also a netatmo mudule for thermostat ?
                            Miller
                            Here you can find many available modules.
                            For the thermostat there is this Module
                            For me that one is not suitable, because it is only for the thermostat, not for the valves.
                            Since I didn’t find a module for the valves, I will maybe try to make it myself, but will take some time
                            • zdenekZ Offline
                              zdenek @Miller
                              @Miller it will be great. I’ve the one form thermostat, but it only show temp and off/on. Will be great to see “plan”, also the status of valves (actual temp, open/closed, temp by plan…)
                              thanks
                              • zdenekZ Offline
                                zdenek
                                @Miller can u plz help me to customize CSS? I need to “somehow” add to my CSS
                                MMM-netatmo . modules bubbles horizontal . module .secondary .displayAQI .AQI .medium light
                                font-size:15px;
                                MMM-netattmo . modules bubbles horizontal . module .primary . displayTemp . Temperature . data_container . data_left large light bright
                                font-size: 40px;
                                and also overide the module css value
                                .x-medium {
                                  font-size:170%;
                                to
                                .x-medium {
                                  font-size:100%;
                                the task is decrease the size of font of mentioned DIVs to own defined size (the actual is too big for me)
                                I’ve tried
                                .x-medium {
                                  font-size:100%;
                                .MMM-netatmo .bubbles.horizontal .module .primary .displayTemp .data_container .data_left {
                                  font-size: 40px;
                                .MMM-netatmo .bubbles.horizontal .module .secondary .displayAQI .AQI {
                                  font-size: 15px;
                                thanks a lot - I’m lost :-(
                                • F Offline
                                  frogywill Project Sponsor
                                  This update looks great, thank you! What should be changed to have it display the temps in fahrenheit ?
                                    Miller @frogywill
                                    @frogywill To show Fahrenheit, change your default settings of MagicMirror units to “imperial”
                                    Or set units: “imperial” in MMM-Netatmo config
                                      Miller @zdenek
                                      @zdenek
                                      The AQI font class is inherited from the default .small class of MM.
                                      To override this, add the following to the CSS
                                      .MMM-netatmo .displayAQI .small {
                                        font-size: 10px;
                                        line-height: 15px;
                                      To override all the .small classes in MMM-Netatmo
                                      .MMM-netatmo .small {
                                        font-size: 10px;
                                        line-height: 15px;
                                      The same goes for the Temperature, this Uses the default .large font class
                                      to override add:
                                      .MMM-netatmo .large {
                                        font-size: 40px;
                                      The .x-medium is only applied to .secondary.displayWindAngle.WindAgle
                                      The other icons is the normal .medium which comes from MM
                                      So you can override
                                      .x-medium {
                                        font-size:100%;
                                      and
                                      .MMM-netatmo .medium {
                                        font-size: 70%;
                                      • zdenekZ Offline
                                        zdenek @Miller
                                        @Miller that’s perfect, thanks
                                        • T Offline
                                          Tribun
                                          Hi Miller,
                                          First of all, I want to tell you that you have built a great module. It looks awesome.
                                          However, I have a problem with the display of the air quality.
                                          What do I have to enter if I want to take this place?
                                          e.g .:
                                          https://aqicn.org/city/austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse/
                                          I only see “wait”.
                                            Miller
                                            I cannot take credit for building the module, I only redesigned it a bit.
                                            As for the Air Quality, took me some figuring out as well.
                                            However, as a location, put the string in behind city, so in your case it would be:
                                            location: "austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse",
