    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 42.5k Views 24 Watching
      bibaldo
      Yes, it would be nice to have it as an option. I will do my best
        bibaldo
        @start-the-fire I’ve updated the module in order to have worldStats support. You can enable/disable it via config
        Enjoy
        S S 2 Replies Last reply Reply Quote 2
          sdetweil @bibaldo
          @bibaldo cool… could u not sort the country list
          I have 3 of these showing reports… (all different of course)…
            start-the-fire @bibaldo
            @bibaldo Thank you very much
            Looks great - One visual add-on towards headerRowClass would be the option to change also the size of the country names and the numbers. Those are quite big.
            I think the best would be to add two additional size classes for the country/numbers and one of the main header
            All the best!
              bobwilliams
              how to resize letters
              • A
                almostgithub
                Love how simple this looks! Having a little trouble pulling from the API however… I put in my API key but nothing displays under the “confirmed Deaths recovered active” header bar.
                Not getting any errors, only thing i changed was adding in the x-rapidapi key from the link. do i need to add the host as well?
                Thanks and stay safe! @bibaldo
                  bibaldo
                  @bobwilliams I’ve added new configuration for the letter font-size. Please read again the README
                  @almostgithub you have to put your rapidapikey at your global config file only.
                  If you have more issues, please output here your logs.
                  • A
                    almostgithub @bibaldo
                    @bibaldo No errors or warnings related to the COVID-19 module in my logs. In my main config.js file i just copied your sample and then changed the API key. Was i supposed to do anything else?
                      see another tracker, with line charts
                      https://forum.magicmirror.builders/topic/12387/covid-bell-curve-line-graph-tracker
                        bibaldo
                        @almostgithub no, nothing more than that (if you have the module up-to-date).
                        I would suggest you to perform a curl from your magicmirror (raspi or whatever) and check if the API is responding well.
                          dc331903
                          Nice job! Looking good and thank you for the additions.
                          To add to that ordering of countries by name… allowing the ‘countries’ list to set the order. It looks like ‘orderCountriesbyName’ alphabetizes them, but I wasn’t able to figure out how to have them list in any other way.
                          Great job getting this going so quickly and appreciate it. Always like to have current information showing.
                          My Sample Code:
                              module: 'MMM-COVID19',
                              position: 'top_left',
                                updateInterval: 300000,
                                orderCountriesByName: true,
                                worldStats: true,
                                countries: [ "Canada", "Italy", "USA", "Mexico" ],
                                headerRowClass: "medium",
                                infoRowClass: "small",
                                rapidapiKey : “xxxxxxxxxxx ADD YOUR OWN API KEY xxxxxxxxx”  \
                          • F
                            fireport
                            I have no output in my MagicMirror and no error in log file. I tried a curl and the output it’s ok.
                            curl -H "x-rapidapi-host: coronavirus-monitor.p.rapidapi.com" -H "x-rapidapi-key: mykey"  'https://coronavirus-monitor.p.rapidapi.com/coronavirus/cases_by_country.php'
                            This is my config:
                                   position: 'top_center',
                                 worldStats: true,
                                 countries: [  "Italy" ],
                                 headerRowClass: "small",
                                 rapidapiKey : "my api key"
                            Any suggestion ?
                            • T
                              totof60
                              @fireport
                              i suggest you, in the config, to put the " position" before “config”
                                  module: "MMM-COVID19",
                              	position: "top_center",
                                    worldStats: true,
                                    countries: [ "France", "China", "Italy", "Spain" ],
                                    rapidapiKey : "xxxxxxxxxxxxxxxxxx"
                                start-the-fire
                                @almostgithub
                                First you need to add the module “twice” into your config: MagicMirrorFolder/config/config.js
                                etc ...
                                afterwards you need to enter your preferred settings & variables
                                                      position: "bottom_bar",
                                                      header: "COVID-19 Stats",
                                                      worldStats: true,
                                                      rapidapiKey: "yourverylongapikey",
                                                      orderCountriesByName: "false",
                                                      countries: [ "Austria", "Germany", "Italy" ],
                                                      updateInterval: 10000000,
                                                      lastUpdateInfo: "true",
                                                      infoRowClass: "medium",
                                Let me know if this solves your problem
                                • F
                                  fireport @totof60
                                  @totof60 Thank you. Now it works.
                                  • T
                                    totof60 @fireport
                                    @fireport :winking_face:
                                    • A
                                      @bibaldo checked all that, was all working fine. Ended up rebooting my PI and it came up flawlessly!
                                      Thank you
                                      • LordyL
                                        Lordy
                                        First of all thanks for the exact status.
                                        How can I rename “Confirmed, Deaths, …”, since older people live in the house and only speak your mother tongue?
                                        This is not meant to be evil or racist.
                                        So, once again, our heartfelt thanks to the Forum.
                                        • A
                                          asdean
                                          This is awesome! Anyway to add individual States in the United States? For instance California, Michigan, New York?
                                          rafaelcotaR 1 Reply Last reply Reply Quote 1
                                          • I
                                            irich @Lordy
                                            @Lordy Hello, you can change this in the MMM-COVID19.js (you find it in /MagicMirror/modules/MMM-COVID19) .
                                                headerconfirmedCell.innerHTML = 'Confirmed'
                                                headerNewConfirmedCell.innerHTML = 'New Cases'
                                                headerdeathsCell.innerHTML = 'Deaths'
                                                headerNewDeathsCell.innerHTML = 'New Deaths'
                                                header.recoveredCell.innerHTML = 'Recovered'
                                                headeractiveCell.innerHTML = 'Active'
                                            Just type in the “” the text you would like to see on the module.
                                            i have translated it into german
                                            headerCountryNameCell.innerHTML = ''
                                                headerconfirmedCell.className = 'number confirmed ' + this.config.headerRowClass
                                                headerconfirmedCell.innerHTML = 'Bestätigt'
                                                headerNewConfirmedCell.className = 'number confirmed ' + this.config.headerRowClass
                                                headerNewConfirmedCell.innerHTML = 'Neue Fälle'
                                                headerdeathsCell.className = 'number deaths ' + this.config.headerRowClass
                                                headerdeathsCell.innerHTML = 'Tote'
                                                headerNewDeathsCell.className = 'number deaths ' + this.config.headerRowClass
                                                headerNewDeathsCell.innerHTML = 'Neue Tote'
                                                headerrecoveredCell.className = 'number recovered ' + this.config.headerRowClass
                                                headerrecoveredCell.innerHTML = 'Erholt'
                                                headeractiveCell.className = 'number active ' + this.config.headerRowClass
                                                headeractiveCell.innerHTML = 'Aktiv'
                                            Just replace the part.
                                            Ersetze einfach die Stelle
                                            LordyL Z 2 Replies Last reply Reply Quote 0
                                            • 1 / 4
