    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 42.5k Views 24 Watching
      start-the-fire
      Hi bibaldo,
      thanks for this minimal COVID19 stat for the MMM.
      Would it be possible to add the world state to the module as well?
      Stay safe & healthy
        bibaldo
        Yes, it would be nice to have it as an option. I will do my best
          bibaldo
          @start-the-fire I’ve updated the module in order to have worldStats support. You can enable/disable it via config
          Enjoy
          S S 2 Replies Last reply Reply Quote 2
            sdetweil @bibaldo
            @bibaldo cool… could u not sort the country list
            I have 3 of these showing reports… (all different of course)…
              start-the-fire @bibaldo
              @bibaldo Thank you very much
              Looks great - One visual add-on towards headerRowClass would be the option to change also the size of the country names and the numbers. Those are quite big.
              I think the best would be to add two additional size classes for the country/numbers and one of the main header
              All the best!
                bobwilliams
                how to resize letters
                • A
                  almostgithub
                  Love how simple this looks! Having a little trouble pulling from the API however… I put in my API key but nothing displays under the “confirmed Deaths recovered active” header bar.
                  Not getting any errors, only thing i changed was adding in the x-rapidapi key from the link. do i need to add the host as well?
                  Thanks and stay safe! @bibaldo
                    bibaldo
                    @bobwilliams I’ve added new configuration for the letter font-size. Please read again the README
                    @almostgithub you have to put your rapidapikey at your global config file only.
                    If you have more issues, please output here your logs.
                    • A
                      almostgithub @bibaldo
                      @bibaldo No errors or warnings related to the COVID-19 module in my logs. In my main config.js file i just copied your sample and then changed the API key. Was i supposed to do anything else?
                        see another tracker, with line charts
                        https://forum.magicmirror.builders/topic/12387/covid-bell-curve-line-graph-tracker
                          bibaldo
                          @almostgithub no, nothing more than that (if you have the module up-to-date).
                          I would suggest you to perform a curl from your magicmirror (raspi or whatever) and check if the API is responding well.
                            dc331903
                            Nice job! Looking good and thank you for the additions.
                            To add to that ordering of countries by name… allowing the ‘countries’ list to set the order. It looks like ‘orderCountriesbyName’ alphabetizes them, but I wasn’t able to figure out how to have them list in any other way.
                            Great job getting this going so quickly and appreciate it. Always like to have current information showing.
                            My Sample Code:
                                module: 'MMM-COVID19',
                                position: 'top_left',
                                  updateInterval: 300000,
                                  orderCountriesByName: true,
                                  worldStats: true,
                                  countries: [ "Canada", "Italy", "USA", "Mexico" ],
                                  headerRowClass: "medium",
                                  infoRowClass: "small",
                                  rapidapiKey : “xxxxxxxxxxx ADD YOUR OWN API KEY xxxxxxxxx”  \
                            • F
                              fireport
                              I have no output in my MagicMirror and no error in log file. I tried a curl and the output it’s ok.
                              curl -H "x-rapidapi-host: coronavirus-monitor.p.rapidapi.com" -H "x-rapidapi-key: mykey"  'https://coronavirus-monitor.p.rapidapi.com/coronavirus/cases_by_country.php'
                              This is my config:
                                     position: 'top_center',
                                   worldStats: true,
                                   countries: [  "Italy" ],
                                   headerRowClass: "small",
                                   rapidapiKey : "my api key"
                              Any suggestion ?
                              • T
                                totof60
                                @fireport
                                i suggest you, in the config, to put the " position" before “config”
                                    module: "MMM-COVID19",
                                	position: "top_center",
                                      worldStats: true,
                                      countries: [ "France", "China", "Italy", "Spain" ],
                                      rapidapiKey : "xxxxxxxxxxxxxxxxxx"
                                  start-the-fire
                                  @almostgithub
                                  First you need to add the module “twice” into your config: MagicMirrorFolder/config/config.js
                                  etc ...
                                  afterwards you need to enter your preferred settings & variables
                                                        position: "bottom_bar",
                                                        header: "COVID-19 Stats",
                                                        worldStats: true,
                                                        rapidapiKey: "yourverylongapikey",
                                                        orderCountriesByName: "false",
                                                        countries: [ "Austria", "Germany", "Italy" ],
                                                        updateInterval: 10000000,
                                                        lastUpdateInfo: "true",
                                                        infoRowClass: "medium",
                                  Let me know if this solves your problem
                                  • F
                                    fireport @totof60
                                    @totof60 Thank you. Now it works.
                                    • T
                                      totof60 @fireport
                                      @fireport :winking_face:
                                      • A
                                        @bibaldo checked all that, was all working fine. Ended up rebooting my PI and it came up flawlessly!
                                        Thank you
                                        • LordyL
                                          Lordy
                                          First of all thanks for the exact status.
                                          How can I rename “Confirmed, Deaths, …”, since older people live in the house and only speak your mother tongue?
                                          This is not meant to be evil or racist.
                                          So, once again, our heartfelt thanks to the Forum.
                                          • A
                                            asdean
                                            This is awesome! Anyway to add individual States in the United States? For instance California, Michigan, New York?
                                            rafaelcotaR 1 Reply Last reply Reply Quote 1
                                            • 1 / 4
