    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 43.1k Views 24 Watching
    • A
      almostgithub @bibaldo
      @bibaldo No errors or warnings related to the COVID-19 module in my logs. In my main config.js file i just copied your sample and then changed the API key. Was i supposed to do anything else?
        see another tracker, with line charts
        https://forum.magicmirror.builders/topic/12387/covid-bell-curve-line-graph-tracker
          bibaldo
          @almostgithub no, nothing more than that (if you have the module up-to-date).
          I would suggest you to perform a curl from your magicmirror (raspi or whatever) and check if the API is responding well.
          A 1 Reply Last reply
            dc331903
            Nice job! Looking good and thank you for the additions.
            To add to that ordering of countries by name… allowing the ‘countries’ list to set the order. It looks like ‘orderCountriesbyName’ alphabetizes them, but I wasn’t able to figure out how to have them list in any other way.
            Great job getting this going so quickly and appreciate it. Always like to have current information showing.
            My Sample Code:
                module: 'MMM-COVID19',
                position: 'top_left',
                  updateInterval: 300000,
                  orderCountriesByName: true,
                  worldStats: true,
                  countries: [ "Canada", "Italy", "USA", "Mexico" ],
                  headerRowClass: "medium",
                  infoRowClass: "small",
                  rapidapiKey : “xxxxxxxxxxx ADD YOUR OWN API KEY xxxxxxxxx”  \
            • F
              fireport
              I have no output in my MagicMirror and no error in log file. I tried a curl and the output it’s ok.
              curl -H "x-rapidapi-host: coronavirus-monitor.p.rapidapi.com" -H "x-rapidapi-key: mykey"  'https://coronavirus-monitor.p.rapidapi.com/coronavirus/cases_by_country.php'
              This is my config:
                     position: 'top_center',
                   worldStats: true,
                   countries: [  "Italy" ],
                   headerRowClass: "small",
                   rapidapiKey : "my api key"
              Any suggestion ?
              • T
                totof60
                @fireport
                i suggest you, in the config, to put the " position" before “config”
                    module: "MMM-COVID19",
                	position: "top_center",
                      worldStats: true,
                      countries: [ "France", "China", "Italy", "Spain" ],
                      rapidapiKey : "xxxxxxxxxxxxxxxxxx"
                F 1 Reply Last reply
                  start-the-fire
                  @almostgithub
                  First you need to add the module “twice” into your config: MagicMirrorFolder/config/config.js
                  etc ...
                  afterwards you need to enter your preferred settings & variables
                                        position: "bottom_bar",
                                        header: "COVID-19 Stats",
                                        worldStats: true,
                                        rapidapiKey: "yourverylongapikey",
                                        orderCountriesByName: "false",
                                        countries: [ "Austria", "Germany", "Italy" ],
                                        updateInterval: 10000000,
                                        lastUpdateInfo: "true",
                                        infoRowClass: "medium",
                  Let me know if this solves your problem
                  • F
                    fireport @totof60
                    @totof60 Thank you. Now it works.
                    T 1 Reply Last reply
                    • T
                      totof60 @fireport
                      @fireport :winking_face:
                      • A
                        @bibaldo checked all that, was all working fine. Ended up rebooting my PI and it came up flawlessly!
                        Thank you
                        • LordyL
                          Lordy
                          First of all thanks for the exact status.
                          How can I rename “Confirmed, Deaths, …”, since older people live in the house and only speak your mother tongue?
                          This is not meant to be evil or racist.
                          So, once again, our heartfelt thanks to the Forum.
                          I 1 Reply Last reply
                          • A
                            asdean
                            This is awesome! Anyway to add individual States in the United States? For instance California, Michigan, New York?
                            rafaelcotaR 1 Reply Last reply
                            • I
                              irich @Lordy
                              @Lordy Hello, you can change this in the MMM-COVID19.js (you find it in /MagicMirror/modules/MMM-COVID19) .
                                  headerconfirmedCell.innerHTML = 'Confirmed'
                                  headerNewConfirmedCell.innerHTML = 'New Cases'
                                  headerdeathsCell.innerHTML = 'Deaths'
                                  headerNewDeathsCell.innerHTML = 'New Deaths'
                                  header.recoveredCell.innerHTML = 'Recovered'
                                  headeractiveCell.innerHTML = 'Active'
                              Just type in the “” the text you would like to see on the module.
                              i have translated it into german
                              headerCountryNameCell.innerHTML = ''
                                  headerconfirmedCell.className = 'number confirmed ' + this.config.headerRowClass
                                  headerconfirmedCell.innerHTML = 'Bestätigt'
                                  headerNewConfirmedCell.className = 'number confirmed ' + this.config.headerRowClass
                                  headerNewConfirmedCell.innerHTML = 'Neue Fälle'
                                  headerdeathsCell.className = 'number deaths ' + this.config.headerRowClass
                                  headerdeathsCell.innerHTML = 'Tote'
                                  headerNewDeathsCell.className = 'number deaths ' + this.config.headerRowClass
                                  headerNewDeathsCell.innerHTML = 'Neue Tote'
                                  headerrecoveredCell.className = 'number recovered ' + this.config.headerRowClass
                                  headerrecoveredCell.innerHTML = 'Erholt'
                                  headeractiveCell.className = 'number active ' + this.config.headerRowClass
                                  headeractiveCell.innerHTML = 'Aktiv'
                              Just replace the part.
                              Ersetze einfach die Stelle
                              LordyL Z 2 Replies Last reply
                              • LordyL
                                Lordy @irich
                                @irich said in MMM-COVID19:
                                Das ist genau was ich haben wollte.
                                Kann man die Umbenennung auch irgendwie Config eintragen, nicht das Änderung beim nächsten Update abhanden kommt?
                                Thank you:thumbs_up_medium-light_skin_tone:
                                Can you enter the renaming somehow Config, not that the change is lost in the next update?
                                • Z
                                  Zinkeler @irich
                                  @irich Hallo, das hab ich auch schon geschafft. Weiß denn jemand, wie ich die “,” durch “.” ersetzen kann. Will anstatt 434,595 das deutsche Format haben.
                                  Danke für eventuelle Antworten.
                                    A Former User
                                    ? 1 Reply Last reply
                                      bibaldo
                                      @Lordy what language do they speak? I can add the translations for them
                                      LordyL 1 Reply Last reply
                                        bibaldo
                                        @Zinkeler Guten Tag
                                        I will add German to the translations
                                          bibaldo
                                          https://forum.magicmirror.builders/topic/12408/mmm-countup-covid19-example
                                          If you want a counter for your Quarantine
                                          • rafaelcotaR
                                            rafaelcota @asdean
                                            @asdean
                                            I second that, but not only for states in USA, other countries have them too! If the source data is store disaggregated maybe is just a matter of knowing under what names and there’s no need to change anything in module.
                                            For example:
                                            countries: [ “Buenos Aires, Argentina”, “Kentucky, USA”, “Sonora, Mexico” ]
                                            Could this be done?
                                            • 1 / 4
