    MMM-GooglePhotos
    294 Posts 56 Posters 418.1k Views 59 Watching
      Samwise
      ok, so it worked, but then when i tried to set which album i wanted, it said this:
      pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ nano MMM-GooglePhotos.js
      nano: error while loading shared libraries: libncursesw.so.5: cannot open shared object file: No such file or directory
      ? 1 Reply Last reply
        A Former User @Samwise
        @Samwise
        I can’t understand why you did this;
        You don’t need to (and shouldn’t) modify source code. use your config/config.js.
        And, the error
        comes from your system, not my module. Maybe your system has been missing something.
          Samwise
          ok i think everything is in order, but the pictures don’t actually show up…
            @Samwise
            Don’t know what happens without details. What does the log say?
              Samwise @Guest
              @Sean where do i find the log?
              Also, this popped up: pi@raspberrypi:~/MagicMirror $ npm start
              magicmirror@2.7.1 start /home/pi/MagicMirror
              sh run-start.sh
              /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
              npm ERR! file sh
              npm ERR! code ELIFECYCLE
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! magicmirror@2.7.1 start: sh run-start.sh
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.7.1 start script.
              npm ERR! /home/pi/.npm/_logs/2020-02-29T10_46_17_131Z-debug.log
              • L
                lucBtrl @Guest
                @Sean
                Thanks a lot Sean !
                It appears indeed that the credentials generated was not the right type (I may have not selected the right option in google api console). Worked better the second time !
                Marvelous results of the module
                • A
                  ayangu
                  @Sean I logged into my google account and allowed consent. However, once I input the code back into the terminal, all I get is auth_and_test started.
                  What am I doing wrong?
                    A Former User @ayangu
                    @ayangu
                    when you did auth_and_test, token.json was created?
                      A Former User
                      New Updates
                      [2.0.0] - 2020/03/23
                      • Notice: Whole new build from scratch. new installation and configuration is needed.
                      • Removed: deprecated dependency request. Instead, using Axios and https
                      • Changed: More stable displaying photos
                      • Changed: New looks.
                      • Changed: Access album by name not by id.
                      • Added: You can filter photos by condition.
                      • Added: GPHOTO_NEXT, GPHOTO_PREVIOUS notifications are supported.
                      • Added: GPHOTO_UPLOAD notification is supported. Now MMM-Selfieshot and MMM-TelegramBot can upload pictures with this module.
                      • Removed: mode, scanInterval, opacity is removed because no more necessary.
                      Screenshot
                      G 1 Reply Last reply
                        roccodicarlo
                        I am running MM on a RP zero W and I only have the RPi command line. It is running in server mode. When I execute node generate_token.js, it does not bring up a browser window where I can authorize for a token. Do I need to do something different?
                          sdetweil @roccodicarlo
                          @roccodicarlo open the chromium-browser to localhost:8080 to get the UI (if this is a graphical desktop pi 0)
                          when/how did u install? my automated script does the setup to run chromium if the graphical desktop exists
                            roccodicarlo
                            No this is not the graphical desktop, it is all CLI.
                              @roccodicarlo ok, then the token tool won’t work…
                              are u doing the cli on purpose?
                                A Former User
                                Copy url and open browser in other pc. Do the process then return to your rpi.
                                  roccodicarlo
                                  ok I will try. The reason I am doing cli was because with desktop gui, I found it very sluggish on the rpi zero.
                                    A Former User @roccodicarlo
                                    @roccodicarlo
                                    I’m worrying, your node version has to be ^8.3 at least.
                                      roccodicarlo
                                      My node version is 10.16…so it should be ok
                                        philmavedzenge
                                        @Sean i really like this module and have been using it for sometime now. I have noticed with the new update that there is a padding of about 10px around the screen. Is there a way of removing that? I use my screen in landscape mode only. Thanks in advance
                                        P 1 Reply Last reply
                                          philmavedzenge @philmavedzenge
                                          @philmavedzenge said in MMM-GooglePhotos:
                                          @Sean nevermind, i fixed it in custom.css
                                          • G
                                            gonzonia @Guest
                                            @Sean Awesome work! Loving the update!
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
