    MMM-GooglePhotos
    294 Posts 56 Posters 388.9k Views 59 Watching
      sdetweil @Alex2020
      @Alex2020 vai alla cartella del modulo nella finestra del terminale ed emetti, git pull. se il modulo ha un file package.json, eseguire anche ‘npm install’
      • Alex2020A Offline
        Alex2020
        Salve mi compare un messaggio sul Mirror che ce una versione più recente come si aggiorna il modulo MMM-GooglePhotos ,come si fa l’aggiornamento?Grazie.
          Samwise
          my auth_and_test is not working. it worked like a year ago, but I haven’t used it since. I’m really new and don’t really know what I’m doing. this is what i get:
          pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
          (node:698) UnhandledPromiseRejectionWarning: Error: invalid_grant
          at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
          at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:18:12)
          at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:201:11)
          at IncomingMessage.emit (events.js:198:15)
          at endReadableNT (_stream_readable.js:1139:12)
          at processTicksAndRejections (internal/process/task_queues.js:81:17)
          (node:698) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
          (node:698) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
          Any suggestions?
          S ? 2 Replies Last reply Reply Quote 0
            sdetweil @Samwise
            @Samwise usually means the authentication code has expired.
              [[global:former-user]] @Samwise
              @Samwise
              remove your current token.json and try again.
              • L Offline
                lucBtrl
                Dear Sean,
                It seems the node auth_and_test.js command throws an error on my side :
                /home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:32
                  const oauthClient = new OAuth2Client(key.client_id, key.client_secret, key.redirect_uris[0]);
                TypeError: Cannot read property 'client_id' of undefined
                    at new Auth (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:32:44)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth_and_test.js:16:14)
                    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                    at startup (internal/bootstrap/node.js:283:19)
                    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                It seems it cannot read my client_id from credentials.json file… do you have an idea ?
                Thanks a lot for your help !
                  [[global:former-user]] @lucBtrl
                  @lucBtrl first, remove your credentials and create it again.
                    Samwise
                    ok, so it worked, but then when i tried to set which album i wanted, it said this:
                    pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ nano MMM-GooglePhotos.js
                    nano: error while loading shared libraries: libncursesw.so.5: cannot open shared object file: No such file or directory
                      @Samwise
                      I can’t understand why you did this;
                      You don’t need to (and shouldn’t) modify source code. use your config/config.js.
                      And, the error
                      comes from your system, not my module. Maybe your system has been missing something.
                        Samwise
                        ok i think everything is in order, but the pictures don’t actually show up…
                          @Samwise
                          Don’t know what happens without details. What does the log say?
                            Samwise @Guest
                            @Sean where do i find the log?
                            Also, this popped up: pi@raspberrypi:~/MagicMirror $ npm start
                            magicmirror@2.7.1 start /home/pi/MagicMirror
                            sh run-start.sh
                            /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                            npm ERR! file sh
                            npm ERR! code ELIFECYCLE
                            npm ERR! errno ENOENT
                            npm ERR! syscall spawn
                            npm ERR! magicmirror@2.7.1 start: sh run-start.sh
                            npm ERR! spawn ENOENT
                            npm ERR!
                            npm ERR! Failed at the magicmirror@2.7.1 start script.
                            npm ERR! /home/pi/.npm/_logs/2020-02-29T10_46_17_131Z-debug.log
                            • L Offline
                              lucBtrl @Guest
                              @Sean
                              Thanks a lot Sean !
                              It appears indeed that the credentials generated was not the right type (I may have not selected the right option in google api console). Worked better the second time !
                              Marvelous results of the module
                                ayangu
                                @Sean I logged into my google account and allowed consent. However, once I input the code back into the terminal, all I get is auth_and_test started.
                                What am I doing wrong?
                                  [[global:former-user]] @ayangu
                                  @ayangu
                                  when you did auth_and_test, token.json was created?
                                    New Updates
                                    [2.0.0] - 2020/03/23
                                    • Notice: Whole new build from scratch. new installation and configuration is needed.
                                    • Removed: deprecated dependency request. Instead, using Axios and https
                                    • Changed: More stable displaying photos
                                    • Changed: New looks.
                                    • Changed: Access album by name not by id.
                                    • Added: You can filter photos by condition.
                                    • Added: GPHOTO_NEXT, GPHOTO_PREVIOUS notifications are supported.
                                    • Added: GPHOTO_UPLOAD notification is supported. Now MMM-Selfieshot and MMM-TelegramBot can upload pictures with this module.
                                    • Removed: mode, scanInterval, opacity is removed because no more necessary.
                                    Screenshot
                                    G 1 Reply Last reply Reply Quote 1
                                      roccodicarlo
                                      I am running MM on a RP zero W and I only have the RPi command line. It is running in server mode. When I execute node generate_token.js, it does not bring up a browser window where I can authorize for a token. Do I need to do something different?
                                        sdetweil @roccodicarlo
                                        @roccodicarlo open the chromium-browser to localhost:8080 to get the UI (if this is a graphical desktop pi 0)
                                        when/how did u install? my automated script does the setup to run chromium if the graphical desktop exists
                                          roccodicarlo
                                          No this is not the graphical desktop, it is all CLI.
                                            @roccodicarlo ok, then the token tool won’t work…
                                            are u doing the cli on purpose?
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
