    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 37.7k Views 24 Watching
    • rafaelcotaR Offline
      rafaelcota @rafaelcota
      @rafaelcota nevermind, found it:
      .countUP tr td.digits {
      color: #ffffff;
      in custom.css
      Than you anyway…
        bibaldo
        @asdean the API that I’m consuming the info has an endpoint for USA states (https://coronavirus-monitor.p.rapidapi.com/coronavirus/usastates.php). You can change that if you want but another modifications have to be done at the code. You can open a PR (Pull request) if you want.
        All can be done, but it will require too much effort for just one country (USA in this case). PR are very welcome
          bibaldo @rafaelcota
          @rafaelcota said in MMM-COVID19:
          n custom.css
          yes, perfect
          • LordyL Offline
            Lordy @bibaldo
            @bibaldo
            I would like to add German to the translations. :thumbs_up_light_skin_tone:
              A Former User @almostgithub
              @almostgithub
              I just had to wait for like 10 minutes while my Internet caught up. Try waiting.
                bibaldo
                @irich @Lordy
                Translations were added
                https://github.com/bibaldo/MMM-COVID19/commit/f6ddc82d47096089ae9122ed94919062dcd827e3
                Z LordyL 2 Replies Last reply Reply Quote 1
                • Z Offline
                  Zinkeler @bibaldo
                  @bibaldo thank you :-)
                  • LordyL Offline
                    Lordy @bibaldo
                    @bibaldo Great, Thank You:thumbs_up_light_skin_tone:
                      A Former User @Guest
                        Saeijou
                        I don’t know what I am doing wrong, I can’t get it to work.
                        I have that in my config:
                            module: 'MMM-COVID19',
                            positon: "top_left",
                              updateInterval: 300000,
                              worldStats: true,
                              countries: ["Germany","USA"],
                              headerRowClass: "small",
                              rapidapiKey: "API_KEY"
                        when I execute the curl command posted here I also get an output with my API key.
                        I am not 100% sure what is meant with “posting it twice”, why would that be?
                        Thank you for any help!
                        Edit: MM is loading normally - no errors. the module is just not there
                        • H Offline
                          hweigel @Saeijou
                          @Saeijou said in MMM-COVID19:
                          positon
                          Hey @Saeijou,
                          try using
                          instead of
                          That should do the trick :-)
                            Saeijou @hweigel
                            @hweigel OH MY GOODNESS!!! I debugged that thing for HOURS! thank you so much :)
                            • K Offline
                              KD
                              Hi Guys, I cannot get this to work - not sure what i am doing wrong…i can only see the header displaying and nothing else… please help! my config looks like this:
                                                    position: "bottom_right",
                                                    header: "COVID-19 Stats",
                                                    worldStats: true,
                                                    rapidapiKey: "My Rapidapikey",
                                                    orderCountriesByName: "false",
                                                    countries: [ "Austria", "Germany", "Italy" ],
                                                    updateInterval: 10000000,
                                                    lastUpdateInfo: "true",
                                                    infoRowClass: "medium",
                              Many Thanks in advance
                              S mumblebajM 2 Replies Last reply Reply Quote 0
                                sdetweil @KD
                                @KD please use code block marks , mark the text and hit the </> button
                                • K Offline
                                  KD @sdetweil
                                  @sdetweil Will do thank you - apologies i am new first post actually :)
                                    paulie420
                                    Ok, I pulled the MMM-Covid19 git. I added the module in config.js, and entered my APIkey… However, it only displays the COVID-19 title and no data.
                                    Am I correct in stating that its not working because now rapidapi has made the coronavirus monitor API paid? Because I think I have it all setup correctly, I notice that the API in rapidapi states PAID, and nothing shows… I want Covid data; is there a way, or am I doing something wrong? OR do I just need to pay and then it’ll show up??
                                    • mumblebajM Offline
                                      mumblebaj Module Developer @KD
                                      @KD remove the comma after “medium” and you should be fine.
                                        mumblebaj Module Developer @paulie420
                                        @paulie420 The RapidAPI seems to be working fine. No need to pay. Can you post your config?
                                        J A 2 Replies Last reply Reply Quote 0
                                          Joeri @mumblebaj
                                          @mumblebaj Hello, I’ve got the same problem, this is my config.
                                          module: “MMM-COVID19”,
                                          position: “lower_third”,
                                          worldStats: true,
                                          delta: true,
                                          headerRowClass: ‘small’,
                                          orderCountriesByName: “false”,
                                          lastUpdateInfo: true,
                                          countries: [ “Argentina”, “USA” ],
                                          headerRowClass: “small”,
                                          infoRowClass: “medium”,
                                          rapidapiKey : “MY KEY”,
                                            andfha @mumblebaj
                                            @mumblebaj Same problem here. Looks like its paid now. curl shows “You are not subscribed to this API”
                                            • 3 / 4
