    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 39.9k Views 24 Watching
      bibaldo
      @asdean the API that I’m consuming the info has an endpoint for USA states (https://coronavirus-monitor.p.rapidapi.com/coronavirus/usastates.php). You can change that if you want but another modifications have to be done at the code. You can open a PR (Pull request) if you want.
      All can be done, but it will require too much effort for just one country (USA in this case). PR are very welcome
        bibaldo @rafaelcota
        @rafaelcota said in MMM-COVID19:
        n custom.css
        yes, perfect
        • LordyL Offline
          Lordy @bibaldo
          @bibaldo
          I would like to add German to the translations. :thumbs_up_light_skin_tone:
            [[global:former-user]] @almostgithub
            @almostgithub
            I just had to wait for like 10 minutes while my Internet caught up. Try waiting.
              bibaldo
              @irich @Lordy
              Translations were added
              https://github.com/bibaldo/MMM-COVID19/commit/f6ddc82d47096089ae9122ed94919062dcd827e3
              Z LordyL 2 Replies Last reply Reply Quote 1
              • Z Offline
                Zinkeler @bibaldo
                @bibaldo thank you :-)
                • LordyL Offline
                  Lordy @bibaldo
                  @bibaldo Great, Thank You:thumbs_up_light_skin_tone:
                    [[global:former-user]] @Guest
                      Saeijou
                      I don’t know what I am doing wrong, I can’t get it to work.
                      I have that in my config:
                          module: 'MMM-COVID19',
                          positon: "top_left",
                            updateInterval: 300000,
                            worldStats: true,
                            countries: ["Germany","USA"],
                            headerRowClass: "small",
                            rapidapiKey: "API_KEY"
                      when I execute the curl command posted here I also get an output with my API key.
                      I am not 100% sure what is meant with “posting it twice”, why would that be?
                      Thank you for any help!
                      Edit: MM is loading normally - no errors. the module is just not there
                      • H Offline
                        hweigel @Saeijou
                        @Saeijou said in MMM-COVID19:
                        positon
                        Hey @Saeijou,
                        try using
                        instead of
                        That should do the trick :-)
                          Saeijou @hweigel
                          @hweigel OH MY GOODNESS!!! I debugged that thing for HOURS! thank you so much :)
                          • K Offline
                            KD
                            Hi Guys, I cannot get this to work - not sure what i am doing wrong…i can only see the header displaying and nothing else… please help! my config looks like this:
                                                  position: "bottom_right",
                                                  header: "COVID-19 Stats",
                                                  worldStats: true,
                                                  rapidapiKey: "My Rapidapikey",
                                                  orderCountriesByName: "false",
                                                  countries: [ "Austria", "Germany", "Italy" ],
                                                  updateInterval: 10000000,
                                                  lastUpdateInfo: "true",
                                                  infoRowClass: "medium",
                            Many Thanks in advance
                            S mumblebajM 2 Replies Last reply Reply Quote 0
                              sdetweil @KD
                              @KD please use code block marks , mark the text and hit the </> button
                              • K Offline
                                KD @sdetweil
                                @sdetweil Will do thank you - apologies i am new first post actually :)
                                  paulie420
                                  Ok, I pulled the MMM-Covid19 git. I added the module in config.js, and entered my APIkey… However, it only displays the COVID-19 title and no data.
                                  Am I correct in stating that its not working because now rapidapi has made the coronavirus monitor API paid? Because I think I have it all setup correctly, I notice that the API in rapidapi states PAID, and nothing shows… I want Covid data; is there a way, or am I doing something wrong? OR do I just need to pay and then it’ll show up??
                                  • mumblebajM Offline
                                    mumblebaj Module Developer @KD
                                    @KD remove the comma after “medium” and you should be fine.
                                      mumblebaj Module Developer @paulie420
                                      @paulie420 The RapidAPI seems to be working fine. No need to pay. Can you post your config?
                                      J A 2 Replies Last reply Reply Quote 0
                                        Joeri @mumblebaj
                                        @mumblebaj Hello, I’ve got the same problem, this is my config.
                                        module: “MMM-COVID19”,
                                        position: “lower_third”,
                                        worldStats: true,
                                        delta: true,
                                        headerRowClass: ‘small’,
                                        orderCountriesByName: “false”,
                                        lastUpdateInfo: true,
                                        countries: [ “Argentina”, “USA” ],
                                        headerRowClass: “small”,
                                        infoRowClass: “medium”,
                                        rapidapiKey : “MY KEY”,
                                          andfha @mumblebaj
                                          @mumblebaj Same problem here. Looks like its paid now. curl shows “You are not subscribed to this API”
                                            menckow
                                            There are two versions of the api. A paid and a freemium version. The freemium one is the V2!
                                            If you want to use the freemium version you will have to edit the node_helper.js file in the module directory (MMM-COVID19) and change the rapidapihost entry and the GET URL as well
                                            rapidhost
                                            NEW: “x-rapidapi-host”: “coronavirus-monitor-v2.p.rapidapi.com”,
                                            OLD: “x-rapidapi-host”: “coronavirus-monitor.p.rapidapi.com”,
                                            GET URL
                                            NEW: ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                                            OLD: ‘https://coronavirus-monitor.p.rapidapi.com/coronavirus/worldstat.php’
                                            • 3 / 4
