    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 43.1k Views 24 Watching
    • LordyL
      Lordy @bibaldo
      @bibaldo
      I would like to add German to the translations. :thumbs_up_light_skin_tone:
        A Former User @almostgithub
        @almostgithub
        I just had to wait for like 10 minutes while my Internet caught up. Try waiting.
          bibaldo
          @irich @Lordy
          Translations were added
          https://github.com/bibaldo/MMM-COVID19/commit/f6ddc82d47096089ae9122ed94919062dcd827e3
          Z LordyL 2 Replies Last reply
          • Z
            Zinkeler @bibaldo
            @bibaldo thank you :-)
            • LordyL
              Lordy @bibaldo
              @bibaldo Great, Thank You:thumbs_up_light_skin_tone:
                A Former User @Guest
                  Saeijou
                  I don’t know what I am doing wrong, I can’t get it to work.
                  I have that in my config:
                      module: 'MMM-COVID19',
                      positon: "top_left",
                        updateInterval: 300000,
                        worldStats: true,
                        countries: ["Germany","USA"],
                        headerRowClass: "small",
                        rapidapiKey: "API_KEY"
                  when I execute the curl command posted here I also get an output with my API key.
                  I am not 100% sure what is meant with “posting it twice”, why would that be?
                  Thank you for any help!
                  Edit: MM is loading normally - no errors. the module is just not there
                  H 1 Reply Last reply
                  • H
                    hweigel @Saeijou
                    @Saeijou said in MMM-COVID19:
                    positon
                    Hey @Saeijou,
                    try using
                    instead of
                    That should do the trick :-)
                      Saeijou @hweigel
                      @hweigel OH MY GOODNESS!!! I debugged that thing for HOURS! thank you so much :)
                      • K
                        KD
                        Hi Guys, I cannot get this to work - not sure what i am doing wrong…i can only see the header displaying and nothing else… please help! my config looks like this:
                                              position: "bottom_right",
                                              header: "COVID-19 Stats",
                                              worldStats: true,
                                              rapidapiKey: "My Rapidapikey",
                                              orderCountriesByName: "false",
                                              countries: [ "Austria", "Germany", "Italy" ],
                                              updateInterval: 10000000,
                                              lastUpdateInfo: "true",
                                              infoRowClass: "medium",
                        Many Thanks in advance
                        S mumblebajM 2 Replies Last reply
                          sdetweil @KD
                          @KD please use code block marks , mark the text and hit the </> button
                          K 1 Reply Last reply
                          • K
                            KD @sdetweil
                            @sdetweil Will do thank you - apologies i am new first post actually :)
                              paulie420
                              Ok, I pulled the MMM-Covid19 git. I added the module in config.js, and entered my APIkey… However, it only displays the COVID-19 title and no data.
                              Am I correct in stating that its not working because now rapidapi has made the coronavirus monitor API paid? Because I think I have it all setup correctly, I notice that the API in rapidapi states PAID, and nothing shows… I want Covid data; is there a way, or am I doing something wrong? OR do I just need to pay and then it’ll show up??
                              mumblebajM 1 Reply Last reply
                              • mumblebajM
                                mumblebaj Module Developer @KD
                                @KD remove the comma after “medium” and you should be fine.
                                • mumblebajM
                                  mumblebaj Module Developer @paulie420
                                  @paulie420 The RapidAPI seems to be working fine. No need to pay. Can you post your config?
                                  J A 2 Replies Last reply
                                    Joeri @mumblebaj
                                    @mumblebaj Hello, I’ve got the same problem, this is my config.
                                    module: “MMM-COVID19”,
                                    position: “lower_third”,
                                    worldStats: true,
                                    delta: true,
                                    headerRowClass: ‘small’,
                                    orderCountriesByName: “false”,
                                    lastUpdateInfo: true,
                                    countries: [ “Argentina”, “USA” ],
                                    headerRowClass: “small”,
                                    infoRowClass: “medium”,
                                    rapidapiKey : “MY KEY”,
                                    • A
                                      andfha @mumblebaj
                                      @mumblebaj Same problem here. Looks like its paid now. curl shows “You are not subscribed to this API”
                                        menckow
                                        There are two versions of the api. A paid and a freemium version. The freemium one is the V2!
                                        If you want to use the freemium version you will have to edit the node_helper.js file in the module directory (MMM-COVID19) and change the rapidapihost entry and the GET URL as well
                                        rapidhost
                                        NEW: “x-rapidapi-host”: “coronavirus-monitor-v2.p.rapidapi.com”,
                                        OLD: “x-rapidapi-host”: “coronavirus-monitor.p.rapidapi.com”,
                                        GET URL
                                        NEW: ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                                        OLD: ‘https://coronavirus-monitor.p.rapidapi.com/coronavirus/worldstat.php’
                                        • I
                                          Indiz
                                          Bonjour j’ai le même problème, je n’ai que le titre COVID-19 qui apparait et aucunes données.
                                          Voici ma config:
                                          	module: "MMM-COVID19",
                                          	  worldStats: true,
                                          	  delta: true,
                                          	  countries: [ "USA", "France", "Spain" ],
                                          	  rapidapiKey : "KEY",
                                            dubalda
                                            Hi guys,
                                            I’m not getting much luck getting this to work. I just get the header and no errors in the log.
                                            position: “top_left”,
                                            worldStats: true,
                                            delta: true,
                                            countries: [ “Argentina”, “China”, “Italy”, “Spain” ],
                                            rapidapiKey : “xxx”
                                            I’ve also amended the node_helper.js for the module to include the new rapidhost URLs
                                            var byCountryUrl = ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                                            getGlobalStats: function(key) {
                                            var self = this
                                            var options = {
                                            method: ‘GET’,
                                            url: worldStatsUrl,
                                            headers: {
                                            //‘x-rapidapi-host’: ‘coronavirus-monitor.p.rapidapi.com’,
                                            ‘x-rapidapi-host’: ‘coronavirus-monitor-v2.p.rapidapi.com’,
                                            ‘x-rapidapi-key’: key
                                            getStatsByCoutry: function(key) {
                                            var self = this
                                            var options = {
                                            method: ‘GET’,
                                            url: byCountryUrl,
                                            headers: {
                                            Any help would be great!
                                            • 3 / 4
