    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 43.1k Views 24 Watching
      bibaldo @rafaelcota
      @rafaelcota said in MMM-COVID19:
      n custom.css
      yes, perfect
      • LordyL
        Lordy @bibaldo
        @bibaldo
        I would like to add German to the translations. :thumbs_up_light_skin_tone:
          A Former User @almostgithub
          @almostgithub
          I just had to wait for like 10 minutes while my Internet caught up. Try waiting.
            bibaldo
            @irich @Lordy
            Translations were added
            https://github.com/bibaldo/MMM-COVID19/commit/f6ddc82d47096089ae9122ed94919062dcd827e3
            Z LordyL 2 Replies Last reply
            • Z
              Zinkeler @bibaldo
              @bibaldo thank you :-)
              • LordyL
                Lordy @bibaldo
                @bibaldo Great, Thank You:thumbs_up_light_skin_tone:
                  A Former User @Guest
                    Saeijou
                    I don’t know what I am doing wrong, I can’t get it to work.
                    I have that in my config:
                        module: 'MMM-COVID19',
                        positon: "top_left",
                          updateInterval: 300000,
                          worldStats: true,
                          countries: ["Germany","USA"],
                          headerRowClass: "small",
                          rapidapiKey: "API_KEY"
                    when I execute the curl command posted here I also get an output with my API key.
                    I am not 100% sure what is meant with “posting it twice”, why would that be?
                    Thank you for any help!
                    Edit: MM is loading normally - no errors. the module is just not there
                    H 1 Reply Last reply
                    • H
                      hweigel @Saeijou
                      @Saeijou said in MMM-COVID19:
                      positon
                      Hey @Saeijou,
                      try using
                      instead of
                      That should do the trick :-)
                        Saeijou @hweigel
                        @hweigel OH MY GOODNESS!!! I debugged that thing for HOURS! thank you so much :)
                        • K
                          KD
                          Hi Guys, I cannot get this to work - not sure what i am doing wrong…i can only see the header displaying and nothing else… please help! my config looks like this:
                                                position: "bottom_right",
                                                header: "COVID-19 Stats",
                                                worldStats: true,
                                                rapidapiKey: "My Rapidapikey",
                                                orderCountriesByName: "false",
                                                countries: [ "Austria", "Germany", "Italy" ],
                                                updateInterval: 10000000,
                                                lastUpdateInfo: "true",
                                                infoRowClass: "medium",
                          Many Thanks in advance
                          S mumblebajM 2 Replies Last reply
                            sdetweil @KD
                            @KD please use code block marks , mark the text and hit the </> button
                            K 1 Reply Last reply
                            • K
                              KD @sdetweil
                              @sdetweil Will do thank you - apologies i am new first post actually :)
                                paulie420
                                Ok, I pulled the MMM-Covid19 git. I added the module in config.js, and entered my APIkey… However, it only displays the COVID-19 title and no data.
                                Am I correct in stating that its not working because now rapidapi has made the coronavirus monitor API paid? Because I think I have it all setup correctly, I notice that the API in rapidapi states PAID, and nothing shows… I want Covid data; is there a way, or am I doing something wrong? OR do I just need to pay and then it’ll show up??
                                mumblebajM 1 Reply Last reply
                                • mumblebajM
                                  mumblebaj Module Developer @KD
                                  @KD remove the comma after “medium” and you should be fine.
                                  • mumblebajM
                                    mumblebaj Module Developer @paulie420
                                    @paulie420 The RapidAPI seems to be working fine. No need to pay. Can you post your config?
                                    J A 2 Replies Last reply
                                      Joeri @mumblebaj
                                      @mumblebaj Hello, I’ve got the same problem, this is my config.
                                      module: “MMM-COVID19”,
                                      position: “lower_third”,
                                      worldStats: true,
                                      delta: true,
                                      headerRowClass: ‘small’,
                                      orderCountriesByName: “false”,
                                      lastUpdateInfo: true,
                                      countries: [ “Argentina”, “USA” ],
                                      headerRowClass: “small”,
                                      infoRowClass: “medium”,
                                      rapidapiKey : “MY KEY”,
                                      • A
                                        andfha @mumblebaj
                                        @mumblebaj Same problem here. Looks like its paid now. curl shows “You are not subscribed to this API”
                                          menckow
                                          There are two versions of the api. A paid and a freemium version. The freemium one is the V2!
                                          If you want to use the freemium version you will have to edit the node_helper.js file in the module directory (MMM-COVID19) and change the rapidapihost entry and the GET URL as well
                                          rapidhost
                                          NEW: “x-rapidapi-host”: “coronavirus-monitor-v2.p.rapidapi.com”,
                                          OLD: “x-rapidapi-host”: “coronavirus-monitor.p.rapidapi.com”,
                                          GET URL
                                          NEW: ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                                          OLD: ‘https://coronavirus-monitor.p.rapidapi.com/coronavirus/worldstat.php’
                                          • I
                                            Indiz
                                            Bonjour j’ai le même problème, je n’ai que le titre COVID-19 qui apparait et aucunes données.
                                            Voici ma config:
                                            	module: "MMM-COVID19",
                                            	  worldStats: true,
                                            	  delta: true,
                                            	  countries: [ "USA", "France", "Spain" ],
                                            	  rapidapiKey : "KEY",
                                            • 3 / 4
