    MMM-Netatmo updated
    56 Posts 15 Posters 41.0k Views 16 Watching
    • zdenekZ Offline
      zdenek @Miller
      @Miller great, thanks, I’m going to test.
      Zdeněk
      zdenekZ 1 Reply Last reply Reply Quote 0
      • zdenekZ Offline
        zdenek @zdenek
        @Miller so, it works almost perfect, Just:
        • I would recomment to add comma (,) next to last bracket on git-hub. Like this:
          when someone copy settings somewhere in the middle of config, he/she has to remember to add comma…
        • for me doesn’t in hotizontal mode works “horizontalOverflow” or I didn’t get the meaning. I’ve set it false and the row of MMM-Netatmo writes values over modules in “right” column". And cause the size is too big for me, I had to remove one of sensors (1 external + 3 internals)
        anyway, thanks a lot - great job
          Miller @zdenek
          @zdenek Thank you for your comments.
          I’ll see if i can improve it later
          • zdenekZ Offline
            zdenek @Miller
            @Miller no problem, I’ll reorganize modules a little bit…
            thanks
              airart
              there is also a netatmo mudule for thermostat ?
                Miller
                Here you can find many available modules.
                For the thermostat there is this Module
                For me that one is not suitable, because it is only for the thermostat, not for the valves.
                Since I didn’t find a module for the valves, I will maybe try to make it myself, but will take some time
                • zdenekZ Offline
                  zdenek @Miller
                  @Miller it will be great. I’ve the one form thermostat, but it only show temp and off/on. Will be great to see “plan”, also the status of valves (actual temp, open/closed, temp by plan…)
                  thanks
                  • zdenekZ Offline
                    zdenek
                    @Miller can u plz help me to customize CSS? I need to “somehow” add to my CSS
                    MMM-netatmo . modules bubbles horizontal . module .secondary .displayAQI .AQI .medium light
                    font-size:15px;
                    MMM-netattmo . modules bubbles horizontal . module .primary . displayTemp . Temperature . data_container . data_left large light bright
                    font-size: 40px;
                    and also overide the module css value
                    .x-medium {
                      font-size:170%;
                    to
                    .x-medium {
                      font-size:100%;
                    the task is decrease the size of font of mentioned DIVs to own defined size (the actual is too big for me)
                    I’ve tried
                    .x-medium {
                      font-size:100%;
                    .MMM-netatmo .bubbles.horizontal .module .primary .displayTemp .data_container .data_left {
                      font-size: 40px;
                    .MMM-netatmo .bubbles.horizontal .module .secondary .displayAQI .AQI {
                      font-size: 15px;
                    thanks a lot - I’m lost :-(
                    • F Offline
                      frogywill Project Sponsor
                      This update looks great, thank you! What should be changed to have it display the temps in fahrenheit ?
                        Miller @frogywill
                        @frogywill To show Fahrenheit, change your default settings of MagicMirror units to “imperial”
                        Or set units: “imperial” in MMM-Netatmo config
                          Miller @zdenek
                          @zdenek
                          The AQI font class is inherited from the default .small class of MM.
                          To override this, add the following to the CSS
                          .MMM-netatmo .displayAQI .small {
                            font-size: 10px;
                            line-height: 15px;
                          To override all the .small classes in MMM-Netatmo
                          .MMM-netatmo .small {
                            font-size: 10px;
                            line-height: 15px;
                          The same goes for the Temperature, this Uses the default .large font class
                          to override add:
                          .MMM-netatmo .large {
                            font-size: 40px;
                          The .x-medium is only applied to .secondary.displayWindAngle.WindAgle
                          The other icons is the normal .medium which comes from MM
                          So you can override
                          .x-medium {
                            font-size:100%;
                          and
                          .MMM-netatmo .medium {
                            font-size: 70%;
                          • zdenekZ Offline
                            zdenek @Miller
                            @Miller that’s perfect, thanks
                            • T Offline
                              Tribun
                              Hi Miller,
                              First of all, I want to tell you that you have built a great module. It looks awesome.
                              However, I have a problem with the display of the air quality.
                              What do I have to enter if I want to take this place?
                              e.g .:
                              https://aqicn.org/city/austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse/
                              I only see “wait”.
                                Miller
                                I cannot take credit for building the module, I only redesigned it a bit.
                                As for the Air Quality, took me some figuring out as well.
                                However, as a location, put the string in behind city, so in your case it would be:
                                location: "austria/laschoberstrasse--ostlich-kreisverkehr-ruster-strasse",
                                • T Offline
                                  Tribun @Miller
                                  @Miller thanks for your help and the great design. ;)
                                  • FoziF Offline
                                    Fozi Project Sponsor
                                    Just came across this post and tried out your fork immediatelly …and it is fantastic. It’s just the way I always wanted! Thanks a lot!
                                      joffe
                                      Hello
                                      Is it possible to remove Air Quality completely?
                                        Aardal1
                                        Thanks for all the great work with this module!
                                        Is there is a way to add some air between the different elements?
                                        Its a lot of information in a small space.
                                        I made this example in ps:
                                        Also, is there a way to remove the update interval text at the bottom?
                                        I could not find this in the description.
                                        Tried the “hideLoadTimer: true,” with no success.
                                        • K Offline
                                          kj3rra
                                          @miller
                                          Hi, I happen to have 3 base stations (home and two cabins) and I wonder if its possible to differentiate between the base station, so I can choose which one to display? It looks to me as if Netatmo have a “hierarchy” on the base stations, where the station you first added will have priority no.1 and the one showing in this module. Removing all base stations and shuffle the hierarchy isnt an option as I have 3 mirrors where I want to display each of the 3 base stations separately.
                                          Any thoughts anyone?
                                            MajorC Project Sponsor
                                            @aardal1 is there a good custom-css style available, to get more space between all the data, like shown in the picture?
                                            • 2 / 3
