    Update MMM
    75 Posts 8 Posters 54.9k Views 9 Watching
      sdetweil @minomit
      @minomit said in Update MMM:
      doing test run = true
      upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
      it should handle all the work… and give you a trial run of all that…
      only applying changes if u request them
      give it a try this works on Mac as well
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      no changes are made to the local repo or the working copy
      **if you WANT to actually apply the changes do**
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      there is a log file (upgrade.log) in the MagicMirror/installers folder…
      I built it to TEST first… and not just blindly apply… give u a chance to figure out what to do…
        @minomit
        notice it highlights a file u might want to look out for
        modules/default/compliments/compliments.js
        did u change this? if so, your changes might be lost
        M 1 Reply Last reply
          minomit @sdetweil
          @sdetweil yes, I tried to put the original file too, same problem
            sdetweil @minomit
            @minomit which ‘same problem’
            if u want the original file back
            git checkout modules/default/compliments/compliments.js
            did u do this
              minomit
              ok ok, perfect thanks
              • Z
                Zinkeler
                after update “npm run start” works, but how can i stop MM ? “npm run stop” did not work.
                Thx
                  sdetweil @Zinkeler
                  @Zinkeler typically is npm start, then ctrl-c will stop it… if you use pm2, them pm2 start 0, and pm2 stop 0
                  Z 1 Reply Last reply
                  • Z
                    Zinkeler @sdetweil
                    @sdetweil thx, it works
                    • StoffbeuteluweS
                      Stoffbeuteluwe Project Sponsor @sdetweil
                      @sdetweil Hi, Sam I used you script …it works fine and very easy to upgrade.
                      Thank you very much for your work :folded_hands_medium-light_skin_tone:
                      thedoorsfanaticT 1 Reply Last reply
                      Reply Quote 2
                      • thedoorsfanaticT
                        thedoorsfanatic @Stoffbeuteluwe
                        @Stoffbeuteluwe
                        Same for me, keep up the good work @sdetweil!
                        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
                        • 4 / 4
