    Load data from json file
    7 Posts 3 Posters 6.5k Views 4 Watching
      mattlugar
      I’m not exactly in the same boat, but similar I guess… Maybe we can put our heads together or someone more knowledgeable will notice the thread…
      I’ve got a local weather station that I have putting plain text data (for temperature) on the SD card of MagicMirror . My goal is to put a ‘realtime’ (updated every minute or so) temperature on the display, directly from my own weather station.
      As an initial step to test this out, I went into currentweather.js and changed the following in the processWeather function:
      Removed:
      this.temperature = this.roundValue(data.main.temp);
      Added:
       var fs = new require('fs');
       this.temperature = fs.readFileSync('/var/www/html/wx/temp.txt');
      I anticipated that this would put the contents of my file in place of the temperature data from openweathermap. Unfortunately, it results in the currentweather module sticking at Loading...
      Just to check I’m not insane, I replaced my code with:
      this.temperature = '56.0';
      The module loads with 56.0 as the temperature. This leads me to believe I’m having an issue reading the file from disk. I threw together a quick js file to test I’m doing the fs.readFileSync command right:
      var sys = require("sys");
      var temp = fs.readFileSync('/var/www/html/wx/temp.txt');
      sys.puts(temp);
      Low and behold, my file contents show up just fine.
      As far as I can tell, this SHOULD work, but it clearly isn’t. Maybe you and I are running into similar issues reading from file? Anyone out there that can assist us?
      • paviroP Offline
        paviro
        Hi guys,
        A simple Google search for node parse json file reveals this :smile:
        For a solution without node another Google search for javascript parse local json file reveals this article :slight_smile:
        I hope this helps!
        Please also make sure you use Markdown on code snippets so it is easier to read!
        – The Doctor
          mattlugar @paviro
          @paviro Difference on mine is I’m pulling in a straight value from a text file, not JSON. The file is a text file that has current temperature. No markups tags or anything else.
          I’m no expert at Java so maybe I’m missing something?
          paviroP 1 Reply Last reply Reply Quote 0
          • paviroP Offline
            paviro @mattlugar
            @mattlugar not sure how currentweather.js deals with data it’s @MichMich’s module he might know something. But it would probably be easier to have a look at the module development README and write a simple module for your purpose from scratch.
            – The Doctor
              mattlugar @paviro
              @paviro Ah, well thanks for the feedback. I’m hoping to get a bit of a hybrid between that app and pulling data from my own weather station. I’d like to keep the sunrise/sunset and the current conditions coming in from openweathermap and put my own station’s temp/wind. Was thinking modifying his would be a little easier than from scratch. :) Maybe I’ll get lucky and he’ll see this and point me in the right direction.
