    Add fade from another point instead vertical
    7 Posts 4 Posters 1.5k Views 3 Watching
    • QuesadaQ Offline
      Quesada
      I want to know if there’s any way to put fade from the right to the left. In calendar module i want to add fade effect to long lenght events.
        sdetweil @Quesada
        @Quesada Google search, css animations
        • QuesadaQ Offline
          Quesada
          i don’t want animation. What i want is this:
          https://codepen.io/sebj54/pen/einIw
          • brobergB Offline
            broberg Project Sponsor
            you can play around with gradient backgrounds
            maybe this works (disclaimer : I haven’t tried it, just looked up text fade with css):
            .calendar .title:before {
                content:'';
                width:100%;
                height:100%;
                position:absolute;
                left:0;
                top:0;
                background: linear-gradient(to right, transparent, #000 100%);
            QuesadaQ 1 Reply Last reply Reply Quote 0
              sdetweil @Quesada
              @Quesada but that is animation
              • QuesadaQ Offline
                Quesada @broberg
                @broberg It didn’t work out for me, but that’s okay, I’ll try to see if it works out differently.
                Thanks for help
                • jca2112J Offline
                  jca2112
                  Here is the CSS I use for a vertical gradient:
                  .calendar table:after {
                    content: '';
                    position: absolute;
                    top: 0;
                    left: 0;
                    right: 0;
                    bottom: 0;
                    background: linear-gradient(to bottom, rgba(0,0,0,0) 50%, rgba(0,0,0,0.48) 100%);
                  You could modify the above (using the deg angle) to create a horizontal gradient.
                  https://developer.mozilla.org/en-US/docs/Web/CSS/linear-gradient
