    my mirror freezes!
    98 Posts 5 Posters 58.3k Views 4 Watching
      Manu85
      @sdetweil [0_1586246858572_somefile](Uploading 100%)
        Manu85
        @sdetweil I can’t get you to pass the “somefile” file on the forum, the file must be in jpg, tif format … I tried to convert them to jpg by splitting the files, but it doesn’t work not either, you told me that I could send it to you by email, but I don’t see how to do it, when I go to your profile it just offers me a chat conversation and the cat only accepts 1000 characters and the file does a lot more, I don’t know how to do it, thanks for your help
          sdetweil @Manu85
          @Manu85 you would copy somefile to where you have an email client and then send it like normal mail
          I gave u my email adress
            Manu85
            “u can send it to me by email, to my same userid as here at gmail”?
              sdetweil @Manu85
              @Manu85 correct… what is my userid here? yours is manu85
                Manu85
                I just sent you an email thank you for confirming that it is correct
                  sdetweil @Manu85
                  @Manu85 from the log
                  looks like MMM-SoccerLiveScore/ had a fatal error when no data was presented
                   [ERROR]  2020-04-07T09:00:27 <error> SyntaxError: Unexpected token u in JSON at position 0
                  0|MagicMir |     at JSON.parse (<anonymous>)
                  0|MagicMir |     at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:192:29)
                  and that error killed MM
                  0|MagicMir | [2020-04-07 09:00:27.567] [LOG]    2020-04-07T09:00:27 <log> Whoops! There was an uncaught exception... (/home/pi/MagicMirror/js/app.js:39 process.<anonymous>)
                  0|MagicMir | [2020-04-07 09:00:27.592] [LOG]    2020-04-07T09:00:27 <log> MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? (/home/pi/MagicMirror/js/app.js:41 process.<anonymous>)
                    Manu85
                    @sdetweil well done !!! Do we have to do something?
                      sdetweil @Manu85
                      @Manu85 yes, short term, disable the MMM-SoccerLiveScore module
                      add
                      disabled:true,
                      to its module definition on config.js
                      the system should no longer crash
                      then work with the module author to get a fix
                        Manu85
                        @sdetweil like that?
                        			disabled:true,
                        			module: 'MMM-SoccerLiveScore',
                        			position: 'top_right',
                        			header: 'Scores en direct',
                        				leagues: [34, 8],
                        		        showNames: true,
                        		        showLogos: true,
                        		        displayTime: 60 * 1000,
                        		        showTables: true
                          sdetweil @Manu85
                          @Manu85
                          yes
                            Manu85
                            @sdetweil ok i will try thank you again you are a genius
                              sdetweil @Manu85
                              @Manu85 the module author posted in 2018 that he no longer had time to maintain this module…
                              I looked at the code and all the data operations do not check for errors. so there is quite a bit of work to fix the module
                                mr_cd
                                Hi guys,
                                my name is Chris and im from Germany.
                                I face the same problem with freezing mirror, i read all your files an did the same at my mirror.
                                Now the mirror has created a lot of logfiles, and im not sure which one is the correct one. Also im not able to find the Errors the freezing problem could belong.
                                So im asking you guys to support me with this Situation.
                                I figured out, that wehen the mirror freezes the MMM-NetworkSignal has also no connection.
                                Here is an overwiev of my actual configuration:
                                Pi 3b+
                                Magic Mirror latest Version
                                Modules :
                                Default :
                                alert - in use
                                calender-in use
                                clock - in use
                                currentweather - in use
                                weatherforecast - in use
                                newsfeed - in use
                                Third Party:
                                MMM-ImagesPhotos - in use
                                MMM-Logging - in use
                                MMM-MyWastePickup - in use
                                MMM-Network Signal - in use
                                MMM-DWD Warn Weather - installed but commendet out in config file
                                MMM-Globe - installed but commendet out in config file
                                MMM-MyCalender – installed but commendet out in config file
                                MMM-MyScoreboard - installed but commendet out in config file (during corona)
                                MMM-MyWheater - installed but commendet out in config file
                                MMM-NowPlaying on Spotify - installed but commendet out in config file
                                MMM-PIR Sensor - installed but commendet out in config file
                                MMM-Remote Control - installed but commendet out in config file
                                The Mirror is starting using pm 2.
                                Here are some lines from the mm-error logfile located at /home/pi/.pm2/logs
                                [2020-04-28 00:39:19.687] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                  syscall: 'getaddrinfo',
                                  hostname: 'calendar.google.com'
                                [2195:0428/003919.718891:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-28 00:39:19.720] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0428/003919.744610:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-28 00:39:19.746] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0428/003919.753595:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0428/003919.784061:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0428/003919.860876:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0428/003919.882695:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0428/003919.891740:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0428/003919.908750:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0428/003919.916802:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0428/004727.451754:INFO:CONSOLE(205)] "weatherforecast is resumed.", source: http://localhost:8080/js/module.js (205)
                                [2195:0428/005514.543522:INFO:CONSOLE(205)] "currentweather is resumed.", source: http://localhost:8080/js/module.js (205)
                                [2020-04-30 00:08:59.708] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2020-04-30 00:08:59.724] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/000859.736313:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/000859.745465:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/000859.761144:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/000859.775211:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/000859.792361:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/000859.807923:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:09:18.623] [ERROR]  fatal: unable to access 'https://github.com/roramirez/MMM-ImagesPhotos.git/': Could not resolve host: github.com
                                [2020-04-30 00:09:18.725] [ERROR]  fatal: unable to access 'https://github.com/jclarke0000/MMM-MyWastePickup.git/': Could not resolve host: github.com
                                [2020-04-30 00:09:18.728] [ERROR]  fatal: unable to access 'https://github.com/PoOwAa/MMM-network-signal/': Could not resolve host: github.com
                                [2020-04-30 00:09:18.771] [ERROR]  fatal: unable to access 'https://github.com/shbatm/MMM-Logging.git/': Could not resolve host: github.com
                                [2020-04-30 00:09:18.844] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Could not resolve host: github.com
                                [2195:0430/000920.383795:INFO:CONSOLE(271)] "weatherforecast: Could not load weather.", source: http://localhost:8080/modules/default/weatherforecast//weatherforecast.js (271)
                                [2020-04-30 00:09:39.751] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/000939.791582:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/000939.804267:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/000939.824935:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:10:19.793] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2020-04-30 00:10:19.809] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001019.833930:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001019.840701:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001019.857296:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001019.885040:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001019.905215:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001019.919681:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:10:59.835] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001059.840348:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:10:59.847] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001059.858241:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001059.865001:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001059.872447:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001059.881979:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001059.890498:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:11:39.882] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001139.901071:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:11:39.901] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001139.908785:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001139.916964:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001139.929157:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001139.935884:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001139.943338:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:12:19.927] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2020-04-30 00:12:19.936] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001219.953136:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001219.973069:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001219.978405:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001219.989848:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001219.997470:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001220.005115:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:12:59.964] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001259.973595:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:12:59.974] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                [2195:0430/001300.000064:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001300.008861:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001300.023657:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001300.036013:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2195:0430/001300.051823:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                                [2020-04-30 00:13:40.001] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                                  errno: 'EAI_AGAIN',
                                  code: 'EAI_AGAIN',
                                And here are some lines from the logfile pm2.log
                                2020-04-21T21:02:02: PM2 log: Stopping app:mm id:0
                                2020-04-21T21:02:02: PM2 log: pid=1523 msg=failed to kill - retrying in 100ms
                                2020-04-21T21:02:02: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                2020-04-21T21:02:02: PM2 log: pid=1523 msg=process killed
                                2020-04-21T21:13:08: PM2 log: App [mm:0] starting in -fork mode-
                                2020-04-21T21:13:08: PM2 log: App [mm:0] online
                                2020-04-22T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-22T20:59:11: PM2 log: [PM2] Upgrade to version 4.3.1
                                2020-04-23T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-23T20:59:11: PM2 log: [PM2] Upgrade to version 4.3.1
                                2020-04-24T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-24T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                                2020-04-25T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-25T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                                2020-04-26T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-26T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                                2020-04-27T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-27T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                                2020-04-28T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-28T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                                2020-04-29T20:59:12: PM2 log: [PM2] This PM2 is not UP TO DATE
                                2020-04-29T20:59:12: PM2 log: [PM2] Upgrade to version 4.4.0
                                2020-04-30T07:24:43: PM2 log: Stopping app:mm id:0
                                2020-04-30T07:24:43: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
                                2020-04-30T07:24:44: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
                                2020-04-30T07:24:45: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
                                2020-04-30T07:24:45: PM2 log: Process with pid 2175 still alive after 1600ms, sending it SIGKILL now...
                                2020-04-30T07:24:45: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
                                2020-04-30T07:24:45: PM2 log: pid=2175 msg=process killed
                                2020-04-30T07:24:45: PM2 log: PM2 successfully stopped
                                2020-04-30T07:25:51: PM2 log: ===============================================================================
                                2020-04-30T07:25:51: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                                2020-04-30T07:25:51: PM2 log: Time                 : Thu Apr 30 2020 07:25:51 GMT+0200 (GMT+02:00)
                                2020-04-30T07:25:51: PM2 log: PM2 version          : 4.2.3
                                2020-04-30T07:25:51: PM2 log: Node.js version      : 10.18.0
                                2020-04-30T07:25:51: PM2 log: Current arch         : arm
                                2020-04-30T07:25:51: PM2 log: PM2 home             : /home/pi/.pm2
                                2020-04-30T07:25:51: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                                2020-04-30T07:25:51: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                                2020-04-30T07:25:51: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                                2020-04-30T07:25:51: PM2 log: Application log path : /home/pi/.pm2/logs
                                2020-04-30T07:25:51: PM2 log: Worker Interval      : 30000
                                2020-04-30T07:25:51: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                                2020-04-30T07:25:51: PM2 log: Concurrent actions   : 2
                                2020-04-30T07:25:51: PM2 log: SIGTERM timeout      : 1600
                                2020-04-30T07:25:51: PM2 log: App [mm:0] starting in -fork mode-
                                2020-04-30T07:25:51: PM2 log: App [mm:0] online
                                2020-04-30T20:06:26: PM2 log: Stopping app:mm id:0
                                2020-04-30T20:06:26: PM2 log: pid=823 msg=failed to kill - retrying in 100ms
                                2020-04-30T20:06:27: PM2 log: pid=823 msg=failed to kill - retrying in 100ms
                                2020-04-30T20:06:28: PM2 log: Process with pid 823 still alive after 1600ms, sending it SIGKILL now...
                                2020-04-30T20:06:28: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
                                2020-04-30T20:06:28: PM2 log: pid=823 msg=process killed
                                2020-04-30T20:06:28: PM2 log: PM2 successfully stopped
                                2020-04-30T20:07:36: PM2 log: ===============================================================================
                                2020-04-30T20:07:36: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                                2020-04-30T20:07:36: PM2 log: Time                 : Thu Apr 30 2020 20:07:36 GMT+0200 (GMT+02:00)
                                2020-04-30T20:07:36: PM2 log: PM2 version          : 4.2.3
                                2020-04-30T20:07:36: PM2 log: Node.js version      : 10.18.0
                                2020-04-30T20:07:36: PM2 log: Current arch         : arm
                                2020-04-30T20:07:36: PM2 log: PM2 home             : /home/pi/.pm2
                                2020-04-30T20:07:36: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                                2020-04-30T20:07:36: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                                2020-04-30T20:07:36: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                                2020-04-30T20:07:36: PM2 log: Application log path : /home/pi/.pm2/logs
                                2020-04-30T20:07:36: PM2 log: Worker Interval      : 30000
                                2020-04-30T20:07:36: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                                2020-04-30T20:07:36: PM2 log: Concurrent actions   : 2
                                2020-04-30T20:07:36: PM2 log: SIGTERM timeout      : 1600
                                2020-04-30T20:07:36: PM2 log: App [mm:0] starting in -fork mode-
                                2020-04-30T20:07:36: PM2 log: App [mm:0] online
                                2020-04-30T20:09:14: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                                2020-04-30T20:09:14: PM2 log: App [mm:0] starting in -fork mode-
                                2020-04-30T20:09:14: PM2 log: App [mm:0] online
                                2020-04-30T20:09:36: PM2 log: Stopping app:mm id:0
                                Sorry for posting so much code …
                                Thank you in advance for the support,
                                Chris
                                  sdetweil @mr_cd
                                  @mr_cd said in my mirror freezes!:
                                  [2020-04-30 00:09:18.623] [ERROR] fatal: unable to access ‘https://github.com/roramirez/MMM-ImagesPhotos.git/’: Could not resolve host: github.com
                                  looks like it is the updatenotification module
                                  add
                                  like this
                                  			module: "updatenotification",
                                  			disabled: true,     /// < --- add this line
                                  			position: "top_bar"
                                    mr_cd
                                    Hi Sam,
                                    thanks for that quick reply.
                                    I added the line in the config file.
                                    Could you please give me an short explaination how this line is affecting the freezing problem?
                                    Thanks and best regards
                                    Chris
                                      sdetweil @mr_cd
                                      @mr_cd it reports a fatal error and this will cause the mirror to stop working…
                                        mr_cd
                                        @sdetweil that means the error will not be shown - but still exists?
                                          sdetweil @mr_cd
                                          @mr_cd correct. the mirror ui will die… sometimes it goes back screen, sometimes it just appears to hang…
                                            mr_cd
                                            @sdetweil i understand. but doesnt this means also no updatenotifications for any other modules will be shown?
                                            • 4 / 5
