    my mirror freezes!
    98 Posts 5 Posters 54.7k Views 4 Watching
      Manu85
      @sdetweil like that?
      			disabled:true,
      			module: 'MMM-SoccerLiveScore',
      			position: 'top_right',
      			header: 'Scores en direct',
      				leagues: [34, 8],
      		        showNames: true,
      		        showLogos: true,
      		        displayTime: 60 * 1000,
      		        showTables: true
        sdetweil @Manu85
        @Manu85
        yes
          Manu85
          @sdetweil ok i will try thank you again you are a genius
            sdetweil @Manu85
            @Manu85 the module author posted in 2018 that he no longer had time to maintain this module…
            I looked at the code and all the data operations do not check for errors. so there is quite a bit of work to fix the module
              mr_cd
              Hi guys,
              my name is Chris and im from Germany.
              I face the same problem with freezing mirror, i read all your files an did the same at my mirror.
              Now the mirror has created a lot of logfiles, and im not sure which one is the correct one. Also im not able to find the Errors the freezing problem could belong.
              So im asking you guys to support me with this Situation.
              I figured out, that wehen the mirror freezes the MMM-NetworkSignal has also no connection.
              Here is an overwiev of my actual configuration:
              Pi 3b+
              Magic Mirror latest Version
              Modules :
              Default :
              alert - in use
              calender-in use
              clock - in use
              currentweather - in use
              weatherforecast - in use
              newsfeed - in use
              Third Party:
              MMM-ImagesPhotos - in use
              MMM-Logging - in use
              MMM-MyWastePickup - in use
              MMM-Network Signal - in use
              MMM-DWD Warn Weather - installed but commendet out in config file
              MMM-Globe - installed but commendet out in config file
              MMM-MyCalender – installed but commendet out in config file
              MMM-MyScoreboard - installed but commendet out in config file (during corona)
              MMM-MyWheater - installed but commendet out in config file
              MMM-NowPlaying on Spotify - installed but commendet out in config file
              MMM-PIR Sensor - installed but commendet out in config file
              MMM-Remote Control - installed but commendet out in config file
              The Mirror is starting using pm 2.
              Here are some lines from the mm-error logfile located at /home/pi/.pm2/logs
              [2020-04-28 00:39:19.687] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
                syscall: 'getaddrinfo',
                hostname: 'calendar.google.com'
              [2195:0428/003919.718891:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-28 00:39:19.720] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0428/003919.744610:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-28 00:39:19.746] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0428/003919.753595:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0428/003919.784061:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0428/003919.860876:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0428/003919.882695:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0428/003919.891740:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0428/003919.908750:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0428/003919.916802:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0428/004727.451754:INFO:CONSOLE(205)] "weatherforecast is resumed.", source: http://localhost:8080/js/module.js (205)
              [2195:0428/005514.543522:INFO:CONSOLE(205)] "currentweather is resumed.", source: http://localhost:8080/js/module.js (205)
              [2020-04-30 00:08:59.708] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2020-04-30 00:08:59.724] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/000859.736313:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/000859.745465:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/000859.761144:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/000859.775211:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/000859.792361:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/000859.807923:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:09:18.623] [ERROR]  fatal: unable to access 'https://github.com/roramirez/MMM-ImagesPhotos.git/': Could not resolve host: github.com
              [2020-04-30 00:09:18.725] [ERROR]  fatal: unable to access 'https://github.com/jclarke0000/MMM-MyWastePickup.git/': Could not resolve host: github.com
              [2020-04-30 00:09:18.728] [ERROR]  fatal: unable to access 'https://github.com/PoOwAa/MMM-network-signal/': Could not resolve host: github.com
              [2020-04-30 00:09:18.771] [ERROR]  fatal: unable to access 'https://github.com/shbatm/MMM-Logging.git/': Could not resolve host: github.com
              [2020-04-30 00:09:18.844] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Could not resolve host: github.com
              [2195:0430/000920.383795:INFO:CONSOLE(271)] "weatherforecast: Could not load weather.", source: http://localhost:8080/modules/default/weatherforecast//weatherforecast.js (271)
              [2020-04-30 00:09:39.751] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/000939.791582:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/000939.804267:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/000939.824935:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:10:19.793] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2020-04-30 00:10:19.809] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001019.833930:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001019.840701:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001019.857296:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001019.885040:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001019.905215:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001019.919681:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:10:59.835] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001059.840348:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:10:59.847] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001059.858241:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001059.865001:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001059.872447:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001059.881979:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001059.890498:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:11:39.882] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001139.901071:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:11:39.901] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001139.908785:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001139.916964:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001139.929157:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001139.935884:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001139.943338:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:12:19.927] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2020-04-30 00:12:19.936] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001219.953136:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001219.973069:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001219.978405:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001219.989848:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001219.997470:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001220.005115:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:12:59.964] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001259.973595:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:12:59.974] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              [2195:0430/001300.000064:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001300.008861:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001300.023657:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001300.036013:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2195:0430/001300.051823:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
              [2020-04-30 00:13:40.001] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                errno: 'EAI_AGAIN',
                code: 'EAI_AGAIN',
              And here are some lines from the logfile pm2.log
              2020-04-21T21:02:02: PM2 log: Stopping app:mm id:0
              2020-04-21T21:02:02: PM2 log: pid=1523 msg=failed to kill - retrying in 100ms
              2020-04-21T21:02:02: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
              2020-04-21T21:02:02: PM2 log: pid=1523 msg=process killed
              2020-04-21T21:13:08: PM2 log: App [mm:0] starting in -fork mode-
              2020-04-21T21:13:08: PM2 log: App [mm:0] online
              2020-04-22T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-22T20:59:11: PM2 log: [PM2] Upgrade to version 4.3.1
              2020-04-23T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-23T20:59:11: PM2 log: [PM2] Upgrade to version 4.3.1
              2020-04-24T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-24T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
              2020-04-25T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-25T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
              2020-04-26T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-26T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
              2020-04-27T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-27T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
              2020-04-28T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-28T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
              2020-04-29T20:59:12: PM2 log: [PM2] This PM2 is not UP TO DATE
              2020-04-29T20:59:12: PM2 log: [PM2] Upgrade to version 4.4.0
              2020-04-30T07:24:43: PM2 log: Stopping app:mm id:0
              2020-04-30T07:24:43: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
              2020-04-30T07:24:44: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
              2020-04-30T07:24:45: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
              2020-04-30T07:24:45: PM2 log: Process with pid 2175 still alive after 1600ms, sending it SIGKILL now...
              2020-04-30T07:24:45: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
              2020-04-30T07:24:45: PM2 log: pid=2175 msg=process killed
              2020-04-30T07:24:45: PM2 log: PM2 successfully stopped
              2020-04-30T07:25:51: PM2 log: ===============================================================================
              2020-04-30T07:25:51: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
              2020-04-30T07:25:51: PM2 log: Time                 : Thu Apr 30 2020 07:25:51 GMT+0200 (GMT+02:00)
              2020-04-30T07:25:51: PM2 log: PM2 version          : 4.2.3
              2020-04-30T07:25:51: PM2 log: Node.js version      : 10.18.0
              2020-04-30T07:25:51: PM2 log: Current arch         : arm
              2020-04-30T07:25:51: PM2 log: PM2 home             : /home/pi/.pm2
              2020-04-30T07:25:51: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
              2020-04-30T07:25:51: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
              2020-04-30T07:25:51: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
              2020-04-30T07:25:51: PM2 log: Application log path : /home/pi/.pm2/logs
              2020-04-30T07:25:51: PM2 log: Worker Interval      : 30000
              2020-04-30T07:25:51: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
              2020-04-30T07:25:51: PM2 log: Concurrent actions   : 2
              2020-04-30T07:25:51: PM2 log: SIGTERM timeout      : 1600
              2020-04-30T07:25:51: PM2 log: App [mm:0] starting in -fork mode-
              2020-04-30T07:25:51: PM2 log: App [mm:0] online
              2020-04-30T20:06:26: PM2 log: Stopping app:mm id:0
              2020-04-30T20:06:26: PM2 log: pid=823 msg=failed to kill - retrying in 100ms
              2020-04-30T20:06:27: PM2 log: pid=823 msg=failed to kill - retrying in 100ms
              2020-04-30T20:06:28: PM2 log: Process with pid 823 still alive after 1600ms, sending it SIGKILL now...
              2020-04-30T20:06:28: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
              2020-04-30T20:06:28: PM2 log: pid=823 msg=process killed
              2020-04-30T20:06:28: PM2 log: PM2 successfully stopped
              2020-04-30T20:07:36: PM2 log: ===============================================================================
              2020-04-30T20:07:36: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
              2020-04-30T20:07:36: PM2 log: Time                 : Thu Apr 30 2020 20:07:36 GMT+0200 (GMT+02:00)
              2020-04-30T20:07:36: PM2 log: PM2 version          : 4.2.3
              2020-04-30T20:07:36: PM2 log: Node.js version      : 10.18.0
              2020-04-30T20:07:36: PM2 log: Current arch         : arm
              2020-04-30T20:07:36: PM2 log: PM2 home             : /home/pi/.pm2
              2020-04-30T20:07:36: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
              2020-04-30T20:07:36: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
              2020-04-30T20:07:36: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
              2020-04-30T20:07:36: PM2 log: Application log path : /home/pi/.pm2/logs
              2020-04-30T20:07:36: PM2 log: Worker Interval      : 30000
              2020-04-30T20:07:36: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
              2020-04-30T20:07:36: PM2 log: Concurrent actions   : 2
              2020-04-30T20:07:36: PM2 log: SIGTERM timeout      : 1600
              2020-04-30T20:07:36: PM2 log: App [mm:0] starting in -fork mode-
              2020-04-30T20:07:36: PM2 log: App [mm:0] online
              2020-04-30T20:09:14: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
              2020-04-30T20:09:14: PM2 log: App [mm:0] starting in -fork mode-
              2020-04-30T20:09:14: PM2 log: App [mm:0] online
              2020-04-30T20:09:36: PM2 log: Stopping app:mm id:0
              Sorry for posting so much code …
              Thank you in advance for the support,
              Chris
                sdetweil @mr_cd
                @mr_cd said in my mirror freezes!:
                [2020-04-30 00:09:18.623] [ERROR] fatal: unable to access ‘https://github.com/roramirez/MMM-ImagesPhotos.git/’: Could not resolve host: github.com
                looks like it is the updatenotification module
                add
                like this
                			module: "updatenotification",
                			disabled: true,     /// < --- add this line
                			position: "top_bar"
                  mr_cd
                  Hi Sam,
                  thanks for that quick reply.
                  I added the line in the config file.
                  Could you please give me an short explaination how this line is affecting the freezing problem?
                  Thanks and best regards
                  Chris
                    sdetweil @mr_cd
                    @mr_cd it reports a fatal error and this will cause the mirror to stop working…
                      mr_cd
                      @sdetweil that means the error will not be shown - but still exists?
                        sdetweil @mr_cd
                        @mr_cd correct. the mirror ui will die… sometimes it goes back screen, sometimes it just appears to hang…
                          mr_cd
                          @sdetweil i understand. but doesnt this means also no updatenotifications for any other modules will be shown?
                            A Former User
                            not sur it’s related to this modules.
                            because it have self protect for this
                            it display fatal if an error was found
                              A Former User
                              if mirror freeze, i think it’s an loop in another module if no connexion
                              the better way is inspect MMM-NetworkSignal when no connexion
                                sdetweil @mr_cd
                                @mr_cd maybe… i haven’t been in the module
                                  mr_cd
                                  @Bugsounet Hi. thanks for your reply.
                                  The Mirror freezes before i installed the MMM-NetworkSignal module.
                                  I installed it to see if there is a loss of connection or not.
                                    A Former User
                                    yes , i inspect helper, it will be protected
                                    so it’s an other …
                                      sdetweil @Guest
                                      @Bugsounet yeh, I fixed it a couple year ago cause it got things out of order
                                        A Former User
                                        personaly, i don’t think, the problem is related to default module
                                        Third Party:
                                        i will see
                                          mr_cd
                                          @Bugsounet MMM-Logging was also installed after the Mirror freezes. Maybe i can disable the Third Party modules and see if it still freezes?!
                                            A Former User
                                            of course try ;)
                                            • 4 / 5
