    my mirror freezes!
    98 Posts 5 Posters 54.7k Views 4 Watching
      mr_cd
      Hi Sam,
      thanks for that quick reply.
      I added the line in the config file.
      Could you please give me an short explaination how this line is affecting the freezing problem?
      Thanks and best regards
      Chris
        sdetweil @mr_cd
        @mr_cd it reports a fatal error and this will cause the mirror to stop working…
          mr_cd
          @sdetweil that means the error will not be shown - but still exists?
            sdetweil @mr_cd
            @mr_cd correct. the mirror ui will die… sometimes it goes back screen, sometimes it just appears to hang…
              mr_cd
              @sdetweil i understand. but doesnt this means also no updatenotifications for any other modules will be shown?
                A Former User
                not sur it’s related to this modules.
                because it have self protect for this
                it display fatal if an error was found
                  A Former User
                  if mirror freeze, i think it’s an loop in another module if no connexion
                  the better way is inspect MMM-NetworkSignal when no connexion
                    sdetweil @mr_cd
                    @mr_cd maybe… i haven’t been in the module
                      mr_cd
                      @Bugsounet Hi. thanks for your reply.
                      The Mirror freezes before i installed the MMM-NetworkSignal module.
                      I installed it to see if there is a loss of connection or not.
                        A Former User
                        yes , i inspect helper, it will be protected
                        so it’s an other …
                          sdetweil @Guest
                          @Bugsounet yeh, I fixed it a couple year ago cause it got things out of order
                            A Former User
                            personaly, i don’t think, the problem is related to default module
                            Third Party:
                            MMM-ImagesPhotos - in use
                            MMM-Logging - in use
                            MMM-MyWastePickup - in use
                            i will see
                              mr_cd
                              @Bugsounet MMM-Logging was also installed after the Mirror freezes. Maybe i can disable the Third Party modules and see if it still freezes?!
                                A Former User
                                of course try ;)
                                  A Former User
                                  humm, i think to other things…
                                  Do you use Raspotify program ?
                                    mr_cd
                                    No i dont - but i used MMM-Spotify but i disabled it because of this freezing problem. But it still freezes…
                                      mr_cd
                                      But there is one suspect thing.
                                      When the Mirror freeze, im not able to connect with VNC. But how affect the MM Software the VNC Connection? Maybe there is a Problem with WLAN Connection…?!
                                      ? S 2 Replies Last reply Reply Quote 0
                                        A Former User
                                        so continue to disable modules one by one…
                                        and default too … to discover the responsible module
                                          A Former User @mr_cd
                                          @mr_cd : yes but it will not freeze… just display warning
                                            sdetweil @mr_cd
                                            @mr_cd how much swap space do you have? and is used?
                                            free -m will show info
                                            • 4 / 5
