    my mirror freezes!
    98 Posts 5 Posters 56.7k Views 4 Watching
      mr_cd
      @sdetweil i understand. but doesnt this means also no updatenotifications for any other modules will be shown?
        A Former User
        not sur it’s related to this modules.
        because it have self protect for this
        it display fatal if an error was found
          A Former User
          if mirror freeze, i think it’s an loop in another module if no connexion
          the better way is inspect MMM-NetworkSignal when no connexion
            sdetweil @mr_cd
            @mr_cd maybe… i haven’t been in the module
              mr_cd
              @Bugsounet Hi. thanks for your reply.
              The Mirror freezes before i installed the MMM-NetworkSignal module.
              I installed it to see if there is a loss of connection or not.
                A Former User
                yes , i inspect helper, it will be protected
                so it’s an other …
                  sdetweil @Guest
                  @Bugsounet yeh, I fixed it a couple year ago cause it got things out of order
                    A Former User
                    personaly, i don’t think, the problem is related to default module
                    Third Party:
                    MMM-ImagesPhotos - in use
                    MMM-Logging - in use
                    MMM-MyWastePickup - in use
                    i will see
                      mr_cd
                      @Bugsounet MMM-Logging was also installed after the Mirror freezes. Maybe i can disable the Third Party modules and see if it still freezes?!
                        A Former User
                        of course try ;)
                          A Former User
                          humm, i think to other things…
                          Do you use Raspotify program ?
                            mr_cd
                            No i dont - but i used MMM-Spotify but i disabled it because of this freezing problem. But it still freezes…
                              mr_cd
                              But there is one suspect thing.
                              When the Mirror freeze, im not able to connect with VNC. But how affect the MM Software the VNC Connection? Maybe there is a Problem with WLAN Connection…?!
                              ? S 2 Replies Last reply Reply Quote 0
                                A Former User
                                so continue to disable modules one by one…
                                and default too … to discover the responsible module
                                  A Former User @mr_cd
                                  @mr_cd : yes but it will not freeze… just display warning
                                    sdetweil @mr_cd
                                    @mr_cd how much swap space do you have? and is used?
                                    free -m will show info
                                      mr_cd
                                      if the mirror is running.
                                      But lets define the word freeze : I mean the clock is still working - but the modules like wheather or calender ar not updating…
                                        sdetweil @mr_cd
                                        @mr_cd but u also said vnc doesn’t work.
                                          sdetweil @mr_cd
                                          @mr_cd clock is working from internal timer… others require internet connection to update
                                            mr_cd
                                            @sdetweil correct. But when i plug in the USB mouse into rasperry iam able to work. After rebooting the system it works every time without problem
                                            • 5 / 5
