    my mirror freezes!
    98 Posts 5 Posters 54.7k Views 4 Watching
      A Former User @mr_cd
      @mr_cd : yes but it will not freeze… just display warning
        sdetweil @mr_cd
        @mr_cd how much swap space do you have? and is used?
        free -m will show info
          mr_cd
          if the mirror is running.
          But lets define the word freeze : I mean the clock is still working - but the modules like wheather or calender ar not updating…
            sdetweil @mr_cd
            @mr_cd but u also said vnc doesn’t work.
              sdetweil @mr_cd
              @mr_cd clock is working from internal timer… others require internet connection to update
                mr_cd
                @sdetweil correct. But when i plug in the USB mouse into rasperry iam able to work. After rebooting the system it works every time without problem
                  sdetweil @mr_cd
                  @mr_cd so, not really a ‘freeze’… MM stops working… system is ok, except for networking, recovers on reboot…
                  sounds like network went to sleep. there is a powersave setting on wifi…
                    mr_cd
                    seems to be ok…
                      sdetweil @mr_cd
                      @mr_cd well, that ain’t it! thx
                        mr_cd
                        @sdetweil but i could be because im working with it. i need to check during the next “freeze” when i connect directly with the mouse if the power save mode is still off.
                          A Former User
                          yes because… we lack ideas. this will allow us to reflect
                            sdetweil @mr_cd
                            @mr_cd it shouldn’t change the config by itself…
                            but thank you, it forced me to check one system I have that seemed/s to have netowkr connection troubles…
                            PM was on… now off
                              mr_cd
                              @Bugsounet @sdetweil Okay thats good :) luckily we could fix one Problem !
                              Lets see i will find a solution - if you having new ideas pleas inform me , if i find the problem i will keep you up to date!
                              • 5 / 5
